Laucher rebuild app fails
The user flob reported a failed Discourse app rebuild due to a database migration error, with the log indicating issues related to the DiscourseVideoUpload plugin. merefield suggested removing the plugin as the cause, and flob confirmed that disabling the plugin resolved the issue, allowing the upgrade to complete successfully.
Hello, I spent some time searching for a solution to my problem, so I decided to post a request for help here. Any help would be greatly appreciated.
thank you.
My Discourse update failed when trying to rebuild using the sudo ./launcher rebuild app command.
here is the error :
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 612 exit 1>
exec failed with the params {"cd"=>"$home", "tag"=>"migrate", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
and here is the complete output.
x86_64 arch detected.
WARNING: containers/app.yml file is world-readable. You can secure this file by running: chmod o-rwx containers/app.yml
Fetching origin
remote: Enumerating objects: 98, done.
remote: Counting objects: 100% (98/98), done.
remote: Compressing objects: 100% (53/53), done.
remote: Total 98 (delta 44), reused 91 (delta 41), pack-reused 0 (from 0)
Unpacking objects: 100% (98/98), 33.85 KiB | 1.30 MiB/s, done.
From https://github.com/discourse/discourse_docker
   595dd6a..cfe8aa0  main               -> origin/main
 * [new branch]      clean-bundle-cache -> origin/clean-bundle-cache
 * [new branch]      launcher2-runtime  -> origin/launcher2-runtime
Updating Launcher...
Updating 595dd6a..cfe8aa0
Fast-forward
 .github/workflows/build.yml             |   8 +++++++-
 .github/workflows/launcher_go.yml       |  45 +++++++++++++++++++++++++++++++++++++++++++++
 image/base/install-nginx                |   2 ++
 image/base/install-oxipng               |   2 +-
 launcher_go/v2/cli_build.go             |  63 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++---
 launcher_go/v2/cli_build_test.go        | 132 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++------------
 launcher_go/v2/config/config.go         |  23 ++++++++++++-----------
 launcher_go/v2/docker/commands.go       |  48 +++++++++++++++++++++++++++++++++++-------------
 launcher_go/v2/main.go                  |   2 ++
 launcher_go/v2/test/containers/test.yml |   3 ++-
 10 files changed, 286 insertions(+), 42 deletions(-)
 create mode 100644 .github/workflows/launcher_go.yml
Launcher updated, restarting...
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 600 app
app
2.0.20240825-0027: Pulling from discourse/base
Digest: sha256:6de68cb49198b5281f79ed9401b3fe818c854d220dcf0238549fe2f2adb19146
Status: Image is up to date for discourse/base:2.0.20240825-0027
docker.io/discourse/base:2.0.20240825-0027
/usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups.rb
/usr/local/bin/pups --stdin
I, [2024-08-30T06:56:18.948183 #1]  INFO -- : Reading from stdin
I, [2024-08-30T06:56:18.964205 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2024-08-30T06:56:18.968049 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2024-08-30T06:56:18.971804 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2024-08-30T06:56:18.975928 #1]  INFO -- : File > /root/install_postgres  chmod: +x  chown:
I, [2024-08-30T06:56:18.980242 #1]  INFO -- : File > /root/upgrade_postgres  chmod: +x  chown:
I, [2024-08-30T06:56:18.981315 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/13/main/postgresql.conf
I, [2024-08-30T06:56:18.982464 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postgresql.conf
I, [2024-08-30T06:56:18.983257 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/13/main/postgresql.conf
I, [2024-08-30T06:56:18.983946 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13/main/postgresql.conf
I, [2024-08-30T06:56:18.984609 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.conf
I, [2024-08-30T06:56:18.985516 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/13/main/postgresql.conf
I, [2024-08-30T06:56:18.986191 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/13/main/postgresql.conf
I, [2024-08-30T06:56:18.986778 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/13/main/postgresql.conf
I, [2024-08-30T06:56:18.987367 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/13/main/postgresql.conf
I, [2024-08-30T06:56:18.988402 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/postgresql/13/main/pg_hba.conf
I, [2024-08-30T06:56:18.988907 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2024-08-30T06:56:18.989381 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2024-08-30T06:56:18.989926 #1]  INFO -- : > if [ -f /root/install_postgres ]; then
  /root/install_postgres && rm -f /root/install_postgres
elif [ -e /shared/postgres_run/.s.PGSQL.5432 ]; then
  socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
fi
I, [2024-08-30T06:56:20.337068 #1]  INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2024-08-30T06:56:20.337989 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2024-08-30T06:56:20.346153 #1]  INFO -- : File > /usr/local/bin/create_db  chmod: +x  chown:
I, [2024-08-30T06:56:20.361384 #1]  INFO -- : File > /var/lib/postgresql/take-database-backup  chmod: +x  chown: postgres:postgres
I, [2024-08-30T06:56:20.368046 #1]  INFO -- : File > /var/spool/cron/crontabs/postgres  chmod:   chown:
I, [2024-08-30T06:56:20.368835 #1]  INFO -- : > sleep 5
2024-08-30 06:56:20.427 UTC [36] LOG:  starting PostgreSQL 13.16 (Debian 13.16-1.pgdg120+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 12.2.0-14) 12.2.0, 64-bit
2024-08-30 06:56:20.427 UTC [36] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2024-08-30 06:56:20.428 UTC [36] LOG:  listening on IPv6 address "::", port 5432
2024-08-30 06:56:20.431 UTC [36] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2024-08-30 06:56:20.436 UTC [45] LOG:  database system was shut down at 2024-08-30 06:56:09 UTC
2024-08-30 06:56:20.444 UTC [36] LOG:  database system is ready to accept connections
I, [2024-08-30T06:56:25.374933 #1]  INFO -- :
I, [2024-08-30T06:56:25.375218 #1]  INFO -- : > /usr/local/bin/create_db
2024-08-30 06:56:25.471 UTC [55] postgres@postgres ERROR:  database "discourse" already exists
2024-08-30 06:56:25.471 UTC [55] postgres@postgres STATEMENT:  CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR:  database "discourse" already exists
2024-08-30 06:56:25.550 UTC [58] postgres@discourse ERROR:  role "discourse" already exists
2024-08-30 06:56:25.550 UTC [58] postgres@discourse STATEMENT:  create user discourse;
NOTICE:  extension "hstore" already exists, skipping
NOTICE:  extension "pg_trgm" already exists, skipping
NOTICE:  extension "vector" already exists, skipping
NOTICE:  version "0.7.4" of extension "vector" is already installed
I, [2024-08-30T06:56:26.292454 #1]  INFO -- : GRANT
ALTER SCHEMA
CREATE EXTENSION
CREATE EXTENSION
CREATE EXTENSION
ALTER EXTENSION
CREATE EXTENSION
CREATE EXTENSION
CREATE EXTENSION
ALTER EXTENSION
UPDATE 0
I, [2024-08-30T06:56:26.293093 #1]  INFO -- : > echo postgres installed!
I, [2024-08-30T06:56:26.295550 #1]  INFO -- : postgres installed!
I, [2024-08-30T06:56:26.300606 #1]  INFO -- : File > /etc/service/redis/run  chmod: +x  chown:
I, [2024-08-30T06:56:26.309609 #1]  INFO -- : File > /etc/service/redis/log/run  chmod: +x  chown:
I, [2024-08-30T06:56:26.315683 #1]  INFO -- : File > /etc/runit/3.d/10-redis  chmod: +x  chown:
I, [2024-08-30T06:56:26.316967 #1]  INFO -- : Replacing daemonize yes with  in /etc/redis/redis.conf
I, [2024-08-30T06:56:26.318451 #1]  INFO -- : Replacing (?-mix:^pidfile.*$) with  in /etc/redis/redis.conf
I, [2024-08-30T06:56:26.319623 #1]  INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2024-08-30T06:56:26.323067 #1]  INFO -- :
I, [2024-08-30T06:56:26.323773 #1]  INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2024-08-30T06:56:26.324542 #1]  INFO -- : Replacing (?-mix:^bind .*$) with  in /etc/redis/redis.conf
I, [2024-08-30T06:56:26.325226 #1]  INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2024-08-30T06:56:26.326011 #1]  INFO -- : Replacing (?-mix:^protected-mode yes) with protected-mode no in /etc/redis/redis.conf
I, [2024-08-30T06:56:26.326740 #1]  INFO -- : Replacing # io-threads 4 with io-threads $redis_io_threads in /etc/redis/redis.conf
I, [2024-08-30T06:56:26.327389 #1]  INFO -- : > echo redis installed
I, [2024-08-30T06:56:26.330197 #1]  INFO -- : redis installed
I, [2024-08-30T06:56:26.330677 #1]  INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2024-08-30T06:56:26.336165 #1]  INFO -- : logfile ""
I, [2024-08-30T06:56:26.336499 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2024-08-30T06:56:26.337966 #1]  INFO -- : > sleep 10
104:C 30 Aug 2024 06:56:26.348 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
104:C 30 Aug 2024 06:56:26.348 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=104, just started
104:C 30 Aug 2024 06:56:26.348 # Configuration loaded
104:M 30 Aug 2024 06:56:26.349 * monotonic clock: POSIX clock_gettime
104:M 30 Aug 2024 06:56:26.349 * Running mode=standalone, port=6379.
104:M 30 Aug 2024 06:56:26.349 # Server initialized
104:M 30 Aug 2024 06:56:26.350 # WARNING Memory overcommit must be enabled! Without it, a background save or replication may fail under low memory condition. Being disabled, it can can also cause failures without low memory condition, see https://github.com/jemalloc/jemalloc/issues/1328. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
104:M 30 Aug 2024 06:56:26.350 * Loading RDB produced by version 7.0.7
104:M 30 Aug 2024 06:56:26.350 * RDB age 17 seconds
104:M 30 Aug 2024 06:56:26.350 * RDB memory usage when created 3.73 Mb
104:M 30 Aug 2024 06:56:26.362 * Done loading RDB, keys loaded: 2858, keys expired: 0.
104:M 30 Aug 2024 06:56:26.362 * DB loaded from disk: 0.012 seconds
104:M 30 Aug 2024 06:56:26.362 * Ready to accept connections
I, [2024-08-30T06:56:36.342328 #1]  INFO -- :
I, [2024-08-30T06:56:36.342654 #1]  INFO -- : > thpoff echo "thpoff is installed!"
I, [2024-08-30T06:56:36.348798 #1]  INFO -- : thpoff is installed!
I, [2024-08-30T06:56:36.349280 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2024-08-30T06:56:36.454702 #1]  INFO -- :
I, [2024-08-30T06:56:36.454873 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end'
I, [2024-08-30T06:56:36.556018 #1]  INFO -- :
I, [2024-08-30T06:56:36.556202 #1]  INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Aborting! CDN must have a protocol specified. Once fixed you should rebake your posts now to correct all posts."; exit 1; end'
I, [2024-08-30T06:56:36.657888 #1]  INFO -- :
I, [2024-08-30T06:56:36.658084 #1]  INFO -- : > rm -f /etc/cron.d/anacron
I, [2024-08-30T06:56:36.660378 #1]  INFO -- :
I, [2024-08-30T06:56:36.662911 #1]  INFO -- : File > /etc/cron.d/anacron  chmod:   chown:
I, [2024-08-30T06:56:36.668033 #1]  INFO -- : File > /etc/runit/1.d/copy-env  chmod: +x  chown:
I, [2024-08-30T06:56:36.672293 #1]  INFO -- : File > /etc/service/unicorn/run  chmod: +x  chown:
I, [2024-08-30T06:56:36.676557 #1]  INFO -- : File > /etc/service/nginx/run  chmod: +x  chown:
I, [2024-08-30T06:56:36.680699 #1]  INFO -- : File > /etc/runit/3.d/01-nginx  chmod: +x  chown:
I, [2024-08-30T06:56:36.684848 #1]  INFO -- : File > /etc/runit/3.d/02-unicorn  chmod: +x  chown:
I, [2024-08-30T06:56:36.684970 #1]  INFO -- : Replacing # postgres with if [ -f /root/install_postgres ]; then
  rm /root/install_postgres
fi
sv start postgres || exit 1
 in /etc/service/unicorn/run
I, [2024-08-30T06:56:36.686390 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git reset --hard
Updating files: 100% (34680/34680), done.
I, [2024-08-30T06:56:40.963927 #1]  INFO -- : HEAD is now at 274e18622 FIX: Video uploads sometimes hang indefinitely (#28523)
I, [2024-08-30T06:56:40.964459 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git clean -f
I, [2024-08-30T06:56:41.127206 #1]  INFO -- :
I, [2024-08-30T06:56:41.128273 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [ $(git rev-parse --is-shallow-repository) == "true" ]; then
      git remote set-branches --add origin main
      git remote set-branches origin tests-passed
      git fetch --depth 1 origin tests-passed
  else
      git fetch --tags --prune-tags --prune --force origin
  fi
 - [deleted]             (none)     -> origin/0-a-gjs-ace
 - [deleted]             (none)     -> origin/better-respect-End-key-in-topics
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/ember-cli-deprecation-workflow-3.0.2
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/ember/test-helpers-4.0.1
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/eslint-9.7.0
 - [deleted]             (none)     -> origin/feature/site-text-result-selected-lang
 - [deleted]             (none)     -> origin/fix/add-user-to-user-directory-when-activated
 - [deleted]             (none)     -> origin/issue/fix-bookmark-clearing-reminder
 - [deleted]             (none)     -> origin/native-class-components-2
 - [deleted]             (none)     -> origin/native-class-components-3
 - [deleted]             (none)     -> origin/notifications_id_bigint
 - [deleted]             (none)     -> origin/prevent-desktop-notifications-on-mobile
 - [deleted]             (none)     -> origin/ux/admin-plugins-ui-guidelines
   274e18622..361e954c5  main                    -> origin/main
 * [new branch]          add-ability-to-watch-chat-threads -> origin/add-ability-to-watch-chat-threads
   3729ac14c..0fafa0bb4  category-experts-approved-webhook-event -> origin/category-experts-approved-webhook-event
 * [new branch]          class-initializer       -> origin/class-initializer
 * [new branch]          dependabot/bundler/ruby-readability-0.7.2 -> origin/dependabot/bundler/ruby-readability-0.7.2
 * [new branch]          dependabot/npm_and_yarn/ace-builds-1.36.1 -> origin/dependabot/npm_and_yarn/ace-builds-1.36.1
 * [new branch]          dependabot/npm_and_yarn/babel-fcd205ed66 -> origin/dependabot/npm_and_yarn/babel-fcd205ed66
 * [new branch]          dependabot/npm_and_yarn/puppeteer-core-23.2.1 -> origin/dependabot/npm_and_yarn/puppeteer-core-23.2.1
 * [new branch]          dev-make-user-1-1-with-user-password -> origin/dev-make-user-1-1-with-user-password
 * [new branch]          dev/glimmer-post-menu   -> origin/dev/glimmer-post-menu
 * [new branch]          dev/port-outlet-wrapper-to-stable -> origin/dev/port-outlet-wrapper-to-stable
 * [new branch]          dev/remove-deprecated-respect-plugin-positional-argument -> origin/dev/remove-deprecated-respect-plugin-positional-argument
 * [new branch]          drop-old-notification-id-columns -> origin/drop-old-notification-id-columns
 * [new branch]          ember-native-class      -> origin/ember-native-class
 * [new branch]          feature/add-user-to-topic_tags_changed-event -> origin/feature/add-user-to-topic_tags_changed-event
 * [new branch]          feature/support-multiple-moderation-groups-on-category -> origin/feature/support-multiple-moderation-groups-on-category
 * [new branch]          fix-bookmarks-filtering -> origin/fix-bookmarks-filtering
 * [new branch]          fix/check-existing-custom-flags-before-creation -> origin/fix/check-existing-custom-flags-before-creation
 * [new branch]          login-buttons-multiple-class -> origin/login-buttons-multiple-class
 + a25ac32bc...97bd38cf4 mt/converter            -> origin/mt/converter  (forced update)
   d3ad2ecda..15f036baf  stable                  -> origin/stable
   274e18622..361e954c5  tests-passed            -> origin/tests-passed
 * [new branch]          translations-from-crowdin-stable -> origin/translations-from-crowdin-stable
 * [new branch]          unique-tag-user-notification -> origin/unique-tag-user-notification
 * [new branch]          ux-1pw-ignore           -> origin/ux-1pw-ignore
 * [new branch]          ux/convert-chat-plugin-ui -> origin/ux/convert-chat-plugin-ui
 * [new branch]          ux_form_template_flash  -> origin/ux_form_template_flash
 t [tag update]          beta                    -> beta
 t [tag update]          latest-release          -> latest-release
 * [new tag]             v3.3.1                  -> v3.3.1
 * [new tag]             v3.4.0.beta1            -> v3.4.0.beta1
I, [2024-08-30T06:56:42.073269 #1]  INFO -- :
I, [2024-08-30T06:56:42.073714 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [[ $(git symbolic-ref --short HEAD) == tests-passed ]] ; then
      git pull
  else
      git -c advice.detachedHead=false checkout tests-passed
  fi
Switched to a new branch 'tests-passed'
I, [2024-08-30T06:56:44.851651 #1]  INFO -- : branch 'tests-passed' set up to track 'origin/tests-passed'.
I, [2024-08-30T06:56:44.852217 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git config user.discourse-version tests-passed
I, [2024-08-30T06:56:44.865672 #1]  INFO -- :
I, [2024-08-30T06:56:44.865986 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp
I, [2024-08-30T06:56:44.868951 #1]  INFO -- :
I, [2024-08-30T06:56:44.869247 #1]  INFO -- : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2024-08-30T06:56:44.872276 #1]  INFO -- :
I, [2024-08-30T06:56:44.872501 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2024-08-30T06:56:44.875816 #1]  INFO -- :
I, [2024-08-30T06:56:44.876029 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2024-08-30T06:56:44.879320 #1]  INFO -- :
I, [2024-08-30T06:56:44.879578 #1]  INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2024-08-30T06:56:44.882918 #1]  INFO -- :
I, [2024-08-30T06:56:44.883194 #1]  INFO -- : > cd /var/www/discourse && mkdir -p                    /shared/log/rails
I, [2024-08-30T06:56:44.886219 #1]  INFO -- :
I, [2024-08-30T06:56:44.886447 #1]  INFO -- : > cd /var/www/discourse && bash -c "touch -a           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log"
I, [2024-08-30T06:56:44.890808 #1]  INFO -- :
I, [2024-08-30T06:56:44.891103 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log /var/www/discourse/log"
I, [2024-08-30T06:56:44.895797 #1]  INFO -- :
I, [2024-08-30T06:56:44.896013 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/{uploads,backups}"
I, [2024-08-30T06:56:44.900610 #1]  INFO -- :
I, [2024-08-30T06:56:44.901011 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/{uploads,backups} /var/www/discourse/public"
I, [2024-08-30T06:56:44.905409 #1]  INFO -- :
I, [2024-08-30T06:56:44.905624 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/tmp/{backups,restores}"
I, [2024-08-30T06:56:44.910429 #1]  INFO -- :
I, [2024-08-30T06:56:44.910686 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/tmp/{backups,restores} /var/www/discourse/tmp"
I, [2024-08-30T06:56:44.915057 #1]  INFO -- :
I, [2024-08-30T06:56:44.915356 #1]  INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp
I, [2024-08-30T06:56:44.938455 #1]  INFO -- :
I, [2024-08-30T06:56:44.938891 #1]  INFO -- : > cd /var/www/discourse && [ ! -d public/plugins ] || find public/plugins/ -maxdepth 1 -xtype l -delete
I, [2024-08-30T06:56:44.941762 #1]  INFO -- :
I, [2024-08-30T06:56:44.942235 #1]  INFO -- : Replacing # redis with sv start redis || exit 1 in /etc/service/unicorn/run
I, [2024-08-30T06:56:44.942951 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_manager.git
Cloning into 'docker_manager'...
I, [2024-08-30T06:56:45.959336 #1]  INFO -- :
I, [2024-08-30T06:56:45.959554 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-calendar
Cloning into 'discourse-calendar'...
I, [2024-08-30T06:56:46.979465 #1]  INFO -- :
I, [2024-08-30T06:56:46.979867 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/paviliondev/discourse-events
Cloning into 'discourse-events'...
I, [2024-08-30T06:56:47.680698 #1]  INFO -- :
I, [2024-08-30T06:56:47.681126 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/xomads/discourse-video-upload
Cloning into 'discourse-video-upload'...
I, [2024-08-30T06:56:48.323561 #1]  INFO -- :
I, [2024-08-30T06:56:48.324134 #1]  INFO -- : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2024-08-30T06:56:48.328453 #1]  INFO -- :
I, [2024-08-30T06:56:48.329067 #1]  INFO -- : > rm /etc/nginx/sites-enabled/default
I, [2024-08-30T06:56:48.331726 #1]  INFO -- :
I, [2024-08-30T06:56:48.332230 #1]  INFO -- : > mkdir -p /var/nginx/cache
I, [2024-08-30T06:56:48.335070 #1]  INFO -- :
I, [2024-08-30T06:56:48.335953 #1]  INFO -- : Replacing pid /run/nginx.pid; with daemon off; in /etc/nginx/nginx.conf
I, [2024-08-30T06:56:48.336609 #1]  INFO -- : Replacing (?m-ix:upstream[^\}]+\}) with upstream discourse { server 127.0.0.1:3000; } in /etc/nginx/conf.d/discourse.conf
I, [2024-08-30T06:56:48.337166 #1]  INFO -- : Replacing (?-mix:server_name.+$) with server_name _ ; in /etc/nginx/conf.d/discourse.conf
I, [2024-08-30T06:56:48.337686 #1]  INFO -- : Replacing (?-mix:client_max_body_size.+$) with client_max_body_size $upload_size ; in /etc/nginx/conf.d/discourse.conf
I, [2024-08-30T06:56:48.338218 #1]  INFO -- : Replacing (?-mix:worker_connections.+$) with worker_connections $nginx_worker_connections ; in /etc/nginx/nginx.conf
I, [2024-08-30T06:56:48.338673 #1]  INFO -- : > echo "done configuring web"
I, [2024-08-30T06:56:48.340760 #1]  INFO -- : done configuring web
I, [2024-08-30T06:56:48.341186 #1]  INFO -- : > cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,""); print $0 }' Gemfile.lock)
I, [2024-08-30T06:56:48.663785 #1]  INFO -- :
I, [2024-08-30T06:56:48.663958 #1]  INFO -- : > cd /var/www/discourse && find /var/www/discourse ! -user discourse -exec chown discourse {} \+
I, [2024-08-30T06:56:50.010467 #1]  INFO -- :
I, [2024-08-30T06:56:50.010985 #1]  INFO -- : > cd /var/www/discourse && if [ "tests-passed" != "tests-passed" ]; then
  rm -rf app/assets/javascripts/node_modules
fi
I, [2024-08-30T06:56:50.012899 #1]  INFO -- :
I, [2024-08-30T06:56:50.013108 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'yarn config set network-timeout 60000 -g'
I, [2024-08-30T06:56:50.386384 #1]  INFO -- : yarn config v1.22.22
success Set "network-timeout" to "60000".
Done in 0.08s.
I, [2024-08-30T06:56:50.386945 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'yarn install --frozen-lockfile && yarn cache clean'
warning Resolution field "unset-value@2.0.1" is incompatible with requested version "unset-value@^1.0.0"
warning " > @discourse/lint-configs@1.3.9" has incorrect peer dependency "ember-template-lint@6.0.0".
warning " > @glint/environment-ember-loose@1.4.0" has unmet peer dependency "@glimmer/component@^1.1.2".
warning " > discourse-markdown-it@1.0.0" has unmet peer dependency "xss@*".
warning "workspace-aggregator-f15441dd-2a2f-4d3b-8279-019453a69d41 > discourse > @uppy/aws-s3@3.0.6" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-f15441dd-2a2f-4d3b-8279-019453a69d41 > discourse > @uppy/aws-s3-multipart@3.1.3" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-f15441dd-2a2f-4d3b-8279-019453a69d41 > discourse > @uppy/xhr-upload@3.1.1" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-f15441dd-2a2f-4d3b-8279-019453a69d41 > discourse-plugins > ember-this-fallback@0.4.0" has unmet peer dependency "ember-source@^3.28.11 || ^4.0.0".
warning "workspace-aggregator-f15441dd-2a2f-4d3b-8279-019453a69d41 > admin > ember-source > router_js@8.0.3" has unmet peer dependency "rsvp@^4.8.5".
warning "workspace-aggregator-f15441dd-2a2f-4d3b-8279-019453a69d41 > discourse > @uppy/aws-s3 > @uppy/xhr-upload@3.3.0" has incorrect peer dependency "@uppy/core@^3.2.1".
I, [2024-08-30T06:59:00.836576 #1]  INFO -- : yarn install v1.22.22
[1/5] Validating package.json...
[2/5] Resolving packages...
[3/5] Fetching packages...
[4/5] Linking dependencies...
[5/5] Building fresh packages...
$ ./app/assets/javascripts/run-patch-package && rm -rf app/assets/javascripts/node_modules
patch-package 8.0.0
Applying patches...
babel-plugin-debug-macros@0.3.4 ✔
content-tag@2.0.1 ✔
decorator-transforms@2.0.0 ✔
ember-this-fallback@0.4.0 (1 deprecation-name) ✔
ember-this-fallback@0.4.0 (2 themes) ✔
ember-this-fallback@0.4.0 (3 exclude-strict-mode) ✔
virtual-dom@2.1.1 ✔
Done in 121.86s.
yarn cache v1.22.22
success Cleared cache.
Done in 7.97s.
I, [2024-08-30T06:59:00.838203 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle install --jobs $(($(nproc) - 1)) --retry 3'
I, [2024-08-30T06:59:08.967237 #1]  INFO -- : Fetching gem metadata from https://rubygems.org/........
Fetching net-imap 0.4.15
Installing net-imap 0.4.15
Fetching css_parser 1.19.0
Installing css_parser 1.19.0
Fetching uri 0.13.1
Installing uri 0.13.1
Fetching faraday-net_http 3.3.0
Installing faraday-net_http 3.3.0
Fetching faraday 2.11.0
Installing faraday 2.11.0
Fetching google-protobuf 4.28.0 (x86_64-linux)
Installing google-protobuf 4.28.0 (x86_64-linux)
Fetching highline 3.1.1
Installing highline 3.1.1
Fetching thor 1.3.2
Installing thor 1.3.2
Fetching omniauth-oauth 1.2.1
Installing omniauth-oauth 1.2.1
Bundle complete! 142 Gemfile dependencies, 184 gems now installed.
Gems in the groups 'test' and 'development' were not installed.
Bundled gems are installed into `./vendor/bundle`
1 installed gem you directly depend on is looking for funding.
  Run `bundle fund` for details
I, [2024-08-30T06:59:08.967865 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'LOAD_PLUGINS=0 bundle exec rake plugin:pull_compatible_all'
I, [2024-08-30T06:59:13.800474 #1]  INFO -- : discourse-calendar is already at latest compatible version
discourse-events is already at latest compatible version
discourse-video-upload is already at latest compatible version
docker_manager is already at latest compatible version
I, [2024-08-30T06:59:13.801181 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2024-08-30T06:59:13.803288 #1]  INFO -- : > sleep 10
608:C 30 Aug 2024 06:59:13.823 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
608:C 30 Aug 2024 06:59:13.823 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=608, just started
608:C 30 Aug 2024 06:59:13.823 # Configuration loaded
608:M 30 Aug 2024 06:59:13.824 * monotonic clock: POSIX clock_gettime
608:M 30 Aug 2024 06:59:13.824 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
608:M 30 Aug 2024 06:59:13.824 # Failed listening on port 6379 (TCP), aborting.
I, [2024-08-30T06:59:23.807920 #1]  INFO -- :
I, [2024-08-30T06:59:23.808747 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
rake aborted!
[DiscourseVideoUpload] Javascript files under `assets/javascripts` are automatically included in JS bundles.
Manual register_asset calls should be removed. (attempted to add javascripts/lib/vimeo-upload.js)
/var/www/discourse/lib/plugin/instance.rb:717:in `register_asset'
/var/www/discourse/plugins/discourse-video-upload/plugin.rb:13:in `activate!'
/var/www/discourse/lib/plugin/instance.rb:778:in `instance_eval'
/var/www/discourse/lib/plugin/instance.rb:778:in `activate!'
/var/www/discourse/lib/discourse.rb:348:in `block in activate_plugins!'
/var/www/discourse/lib/discourse.rb:345:in `each'
/var/www/discourse/lib/discourse.rb:345:in `activate_plugins!'
/var/www/discourse/config/application.rb:232:in `block in <class:Application>'
/var/www/discourse/lib/plugin.rb:6:in `initialization_guard'
/var/www/discourse/config/application.rb:232:in `<class:Application>'
/var/www/discourse/config/application.rb:75:in `<module:Discourse>'
/var/www/discourse/config/application.rb:74:in `<top (required)>'
/var/www/discourse/Rakefile:7:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/exe/rake:27:in `<top (required)>'
I, [2024-08-30T06:59:55.564695 #1]  INFO -- : gem install uuidtools -v 2.2.0 -i /var/www/discourse/plugins/discourse-events/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed uuidtools-2.2.0
1 gem installed
gem install iso-639 -v 0.3.5 -i /var/www/discourse/plugins/discourse-events/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed iso-639-0.3.5
1 gem installed
gem install ice_cube -v 0.16.4 -i /var/www/discourse/plugins/discourse-events/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed ice_cube-0.16.4
1 gem installed
gem install icalendar -v 2.8.0 -i /var/www/discourse/plugins/discourse-events/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
ActiveSupport is required for TimeWithZone support, but not required for general use.
Successfully installed icalendar-2.8.0
1 gem installed
gem install icalendar-recurrence -v 1.1.3 -i /var/www/discourse/plugins/discourse-events/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed icalendar-recurrence-1.1.3
1 gem installed
gem install date -v 3.3.4 -i /var/www/discourse/plugins/discourse-events/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Building native extensions. This could take a while...
Successfully installed date-3.3.4
1 gem installed
gem install time -v 0.2.0 -i /var/www/discourse/plugins/discourse-events/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed time-0.2.0
1 gem installed
gem install stringio -v 3.1.1 -i /var/www/discourse/plugins/discourse-events/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed stringio-3.1.1
1 gem installed
gem install omnievent -v 0.1.0.pre3 -i /var/www/discourse/plugins/discourse-events/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed omnievent-0.1.0.pre3
1 gem installed
gem install omnievent-icalendar -v 0.1.0.pre5 -i /var/www/discourse/plugins/discourse-events/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed omnievent-icalendar-0.1.0.pre5
1 gem installed
gem install omnievent-api -v 0.1.0.pre2 -i /var/www/discourse/plugins/discourse-events/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed omnievent-api-0.1.0.pre2
1 gem installed
gem install omnievent-eventbrite -v 0.1.0.pre2 -i /var/www/discourse/plugins/discourse-events/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed omnievent-eventbrite-0.1.0.pre2
1 gem installed
gem install omnievent-eventzilla -v 0.1.0.pre2 -i /var/www/discourse/plugins/discourse-events/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed omnievent-eventzilla-0.1.0.pre2
1 gem installed
gem install omnievent-meetup -v 0.1.0.pre1 -i /var/www/discourse/plugins/discourse-events/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed omnievent-meetup-0.1.0.pre1
1 gem installed
gem install omnievent-outlook -v 0.1.0.pre2 -i /var/www/discourse/plugins/discourse-events/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed omnievent-outlook-0.1.0.pre2
1 gem installed
I, [2024-08-30T06:59:55.565538 #1]  INFO -- : Terminating async processes
I, [2024-08-30T06:59:55.565618 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 36
I, [2024-08-30T06:59:55.565721 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 104
104:signal-handler (1725001195) Received SIGTERM scheduling shutdown...
2024-08-30 06:59:55.566 UTC [36] LOG:  received fast shutdown request
2024-08-30 06:59:55.568 UTC [36] LOG:  aborting any active transactions
2024-08-30 06:59:55.572 UTC [36] LOG:  background worker "logical replication launcher" (PID 51) exited with exit code 1
2024-08-30 06:59:55.578 UTC [46] LOG:  shutting down
104:M 30 Aug 2024 06:59:55.599 # User requested shutdown...
104:M 30 Aug 2024 06:59:55.599 * Saving the final RDB snapshot before exiting.
2024-08-30 06:59:55.612 UTC [36] LOG:  database system is shut down
104:M 30 Aug 2024 06:59:55.622 * DB saved on disk
104:M 30 Aug 2024 06:59:55.622 # Redis is now ready to exit, bye bye...
FAILED
df03c3401b35e1722e269363f40677ac73227c543d2bac52730700a30795f531
No I don’t think it’s that. Why do you say that @pinder99 ?
It’s DiscourseVideoUpload, remove that plugin.
You can see from the log it has issues.
I don’t see any issues in the log related to events.
I have disabled the DiscourseVideoUpload plugin as suggested and the upgrade did complete successfully. My site is back thank you.
