Hi, is there a way to have a “my friends” group in my user profile? (not necessarily to follow them). Thank you.
You mean like a group or are you referring to the follow plugin?
I am using the Follow plug-in. But my ask was more to mark some users as my friends (my relations) without following their content.
What behaviour would that trigger?
None. Like you can have bookmarks, I would like to have bookmarked friends.
I can’t think of anything that would serve that purpose, no.
You could create a listing in About me in your profile.
Use Hide details.
Friends
Profile - patrickemin - Discourse Meta
Profile - ondrej - Discourse Meta
Profile - HAWK - Discourse Meta
These lists would need to be made manually. For profile links copy the link address of the profile avatar.
https://meta.discourse.org/u/ondrej
There is I believe a link method that should more display the usercard. But cannot recall it off hand.
You can always just make a list in your inbox using a pm to yourself and link to it with a custom sidebar link. If you list them as @mentions, you can easily click on them for actions without actually notifying them, since it’s your inbox and you are the only recipient of the message. I have an inbox notebook organized and indexed into sections with my checklist of tasks, all kinds of notes, blog updates and links, etc. I use a private Discourse instance like a personal organizer tool that pretty much does everything. I don’t know what your use case is, whether you want a private list for yourself, or a public list a la facebook style.
Yes thanks. Actually I could create a group. This came to my mind as I think there is no simpler solution.
Groups can work for sure. Though could be messy if wanting all users to have their own friends/family groups.
Yes that’s the problem.
If you have an available budget consider marketplace.
Someone might be able to create a plugin that will Automatically create a group using as a base
- username-friends. Maybe once user reached TL3 & account x days old.
- Making that user owner with setting “request to join” & leave freely.
- Hide group from group page and add link to usercard and/or user profile.
- Additional consideration if owner cannot change group visibility to have option to make group only show to members(private vs public viewable).
Such a plugin option would make it possible to closer simulate FB and would be a great addon for the Fakebook themes.
Yes, thank you for the detailed suggestion.
