No it doesn’t. You can fork the theme and install your own version at your forum. But you would have to update your forked theme when the original one is updated. That usually shouldn’t be that complicated.
But the best solution is to actually make those strings translateable. @awesomerobot would that be pr-welcome ?
For 1 week i tried all themes, and for me your theme was the most efficient in terms of UX quality (the fullwith component was a bit problematic, but I solved it with custom css).
The only thing left is some strings that need to be translated.
I’ve just made an update to the theme that makes this text translatable.
“replies” and “share” will use our default translations, so those should work automatically… and the rest of the text can be edited from the bottom of the theme’s settings page at admin/customize/themes
When I was on the site, I saw the update notification live. I said, I wonder if it’s what I think it is? Yes! I’m new here and I’m curious. Why don’t you sell these themes for a fee? Or can’t you sell them? I haven’t seen anyone selling. But the effort you put in definitely deserves it.
Everything works perfectly. I can only give a little feedback. The field in the right sidebar could not be translated. But that’s okay. It’s a great job. I love you…
