Background
Rails system specs are used to simulate the actions of a real user using the app in a browser. We use the Playwright ruby driver which is becoming an industry standard. The tests run locally and in CI out of the box. Capybara is the test framework used on top of rspec to interact with the web browser, and it sends commands to Playwright.
We currently only support running system specs in Chrome, make sure you have Chrome installed before proceeding. Run pnpm i to ensure Playwright is correctly set up.
Since the Discourse app is an Ember Single Page Application, there are some unique constraints and challenges to writing system specs. It’s important to keep in mind that you should always be observing for changes in the DOM in your tests, not manually waiting for things to happen or adding artificial sleep time. Also, the JavaScript build is separate from the Rails server, which means you must be running Ember CLI when writing system specs.
Running system specs
Any system spec can be run with the bin/rspec FILENAME.rb command. By default the specs are run in a headless version of Chrome, meaning no browser window will open while the spec is running.
If you do not already have the Discourse rails server running with
bin/ember-cli -u, you will need to runbin/ember-cli --buildafter every JavaScript change to see these reflected in the headless browser. It is recommended you just keep your local server running while writing system specs.Also, ensure you run rails migrations any time you make modifications to your local database schema.
There are various environment flags that can be used to change how the spec is run.
Commonly Used
- PLAYWRIGHT_HEADLESS- Set to- 0to open a browser while the spec is running. This will allow you to observe what is going on while the browser is being driven by the test harness. Combine with debugging tools and Chrome devtools to help write and debug specs.
Rarely Used
These environment variables aren't often used but provide greater control over Playwright and Capybara
- CAPYBARA_REMOTE_DRIVER_URL- Allows Capybara to control a remote Chrome browser instead of a local one.
- PLAYWRIGHT_DISABLE_VERBOSE_JS_LOGS- By default JS logs are verbose, so errors from JS are shown when running system tests, you can disable this by setting it to- 1.
- CAPYBARA_SERVER_HOST- The hostname of the server that Playwright Webdriver is running on.
- CAPYBARA_SERVER_PORT- The port of the server that Playwright Webdriver is running on.
- CAPYBARA_DEFAULT_MAX_WAIT_TIME- Overrides the default wait time when looking for DOM elements in Capybara.
Writing system specs
Basics
The bare minimum needed for a system spec is adding type: :system to the top level describe block of the spec. This makes sure RSpec uses Capybara et. al. via rails_helper.
# frozen_string_literal: true
describe "Bookmarking posts and topics", type: :system do
  it "allows logged in user to create bookmarks with and without reminders" do
    # browser controls and rspec assertions go here
If you need a logged in user you will need to fabricate one and sign them in. Our convention is to call the variable for the currently logged in user current_user:
  fab!(:current_user) { Fabricate(:user) }
  before do
    sign_in(current_user)
If you want to simulate a mobile device, you need only add mobile: true to the it block:
context "when mobile"
  it "allows logged in user to create bookmarks with and without reminders", mobile: true do
This will change the screen size with Capybara and this.site.isMobileDevice will be true in the Ember app, meaning some components will appear or behave differently.
Best Practices
Many of these will be further expanded throughout this document, but this is a quick reference to come back to.
- Remember that you should never manually sleep or wait for things in system specs, see the Gotchas section below
- Do not store references to elements on the page in variables, they can quickly go “stale” in Playwright. Always findthem again when you need them
- Refactor system spec code into Page Objects once a repetitive pattern is apparent
- RSpec expectations should be used very sparingly in Page Objects and preferably not at all, most expectations should be in the spec file
- Use high specificity CSS classes with BEM, these will aid in finding unique elements when writing system specs
- Make sure you are testing the happy path only, no complicated contextblocks and branching conditionals
- Keep speed in mind, if a system test you have written is running quite slow investigate why and see if there are some things you can improve
- Keep direct execution of JavaScript with things like page.execute_scriptto a minimum
- Use skiporxitfor tests that are known to be flaky in CI environments
- Use Capybara and RSpec matchers effectively to avoid waiting too long or checking for an element too early, see Gotchas section below
Capybara DSL and RSpec Matchers
Capybara has its own DSL which is accessible in every system spec and in every Page Object class, reference for this can be found at RubyDoc.info: File: README – Documentation for teamcapybara/capybara (master) – RubyDoc.info . A good cheat sheet can be found at Capybara cheatsheet .
For example if you are looking for an element on the page you can use find with a CSS class:
expect(find(".my-class")).to have_content(I18n.t("some.key"))
Most Capybara DSL supports passing in an optional wait parameter to override the default time that Capybara waits for an element or selector to be found in the DOM. This should be used rather than using things like sleep. This can be useful in cases where the backend takes a longer time to update the UI. For example:
find(".some-element", wait: 10)
It’s good practice to add CSS classes to elements as identifiers that have good specificity so your system specs are not finding other elements on the page by mistake. We use BEM for this.
This DSL is automatically included in all of our Page Objects, see the Page Object section below for more information.
 Gotchas
 Gotchas
Capybara Selectors and Waiting
It is critically important to remember what RubyDoc.info: File: README – Documentation for teamcapybara/capybara (master) – RubyDoc.info says . Never use this format of checking for an element or CSS on the page:
expect(page.has_css?(".selector")).to eq(true)
expect(!page.has_css?(".selector")).to eq(true)
Always use these formats instead:
expect(page/page_object).to have_css/have_custom_selector
expect(page/page_object).to have_no_css/have_custom_selector
This is because the latter format uses Capybara’s built in wait functionality whereas the former does not, this is important because we have an SPA with lots of AJAX calls, and we need to wait until a maximum timeout for elements or CSS to appear on the page.
Never manually wait for things to happen in a system spec using ruby’s sleep!
Capybara Matcher DSL Negative Slowdowns
The same magic above that allows us to define our own has_X methods have some terrible speed implications when used in the not_to form. For example:
expect(topic_page).not_to have_post_content(post)
This will cause an several seconds of time to be added to the spec. To fix this, we can write a negative DSL matcher directly in our Page Object and that does not take the same hit:
def has_no_post_content?(post)
  post_by_number(post).has_no_content?(post.raw)
expect(topic_page).to have_no_post_content(post)
Using visit in a SPA
In Capybara, you can use visit to go directly to a page. For example:
page.visit("/t/123")
This works fine in our Ember SPA for the initial navigation and page load. However, if you try to use it when navigating to other pages in specs, keep in mind that visit causes a full page refresh, clearing any UI state. To navigate to other pages it’s generally best to click on a link directly:
page.find(".some-link").click
Avoiding direct assertions against database records
Asserting directly against database records within system specs may lead to inconsistent test results if you don’t appropriately wait for the backend updates to synchronize with the frontend.
For example, directly checking database states like this in system tests can be problematic:
expect(Topic.count).to eq(2)
This assertion assumes that the backend update has already occurred, ignoring any asynchronous behavior.
To avoid such issues:
Observe Changes in the UI
 System specs should focus on what the user can observe via the user interface. Use Capybara’s built-in matchers to wait for DOM updates. For example:expect(page).to have_selector(".success-message")or expect(topic_page).to have_topic(topic)
Wait for Backend Synchronization
 If necessary, use a helper liketry_until_successto check database state explicitly but sparingly:try_until_success do expect(Topic.count).to eq(1) end
Page Objects
To make querying and inspecting parts of the page easier and reusable in between system specs, we are using the concept of Page Objects. A basic Page Object looks like this:
module PageObjects
  module Pages
    class Tag < PageObjects::Pages::Base
      def visit_tag(tag)
        page.visit "/tag/#{tag.name}"
        self
      def tag_info_btn
        find("#show-tag-info")
      def add_synonyms_dropdown
        PageObjects::Components::SelectKit.new("#add-synonyms")
      def search_tags(query)
        add_synonyms_dropdown.search(query)
      def tag_box(tag)
        find(".tag-box div[data-tag-name='#{tag}']")
Page Objects are responsible for the following:
- Visiting URLs, either directly or by clicking elements
- Finding common elements based on CSS selectors or XPaths
- Performing common actions in the UI (e.g. finding and clicking on a specific button)
- Filling in or otherwise interacting with input elements
We split our Page Objects into 3 classifications – Page, Component, Modal.
- A “Page” here generally corresponds to an overarching Ember route, e.g. “Topic” for /t/324345/some-topic, and this contains logic for querying components within the topic such as “Posts”. All of these inherit fromPageObjects::Pages::Base.
- A “Modal” is any given modal window that opens within the app. All modal page objects inherit from PageObjects::Modals::Base, which handles open/closed states and clicking outside the modal.
- A “Component” is any reusable component in the Ember app and roughly maps to Ember components, though in some cases it may represent a small section of a Page. All of these inherit from PageObjects::Components::Base.
When using Page Objects inside system specs, you should use let to store instances of them in variables rather than defining them in your specs inline. The start of your spec file may look something like this:
let(:modal) { PageObjects::Modals::Base.new }
let(:composer) { PageObjects::Components::Composer.new }
let(:topic) { PageObjects::Pages::Topic.new }
let(:cdp) { PageObjects::CDP.new }
Then, you can use these variables to interact with the page in a declarative way. For example:
it "bookmarks a post" do
  topic_page.visit(topic.id)
  topic_page.bookmark_post(post.id)
  expect(topic_page.post_by_id(post.id)).to be_bookmarked
Generally a good rule of thumb to follow for creating Page Objects is to write your system spec without them first, then extract commonly referenced elements and actions into a Page Object for the corresponding page, component, or modal. Chrome DevTools and other debugging tools below are your friend in this process.
Capybara DSL and RSpec Matchers in Page Objects
All Capybara DSL is accessible in Page Objects because it is included in the base classes.
Every method we define inside Page Objects in the form has_x? magically  becomes a custom RSpec matcher that respects Capybara’s waiting logic. For example in bookmarks we have these matchers:
def has_post_content?(post)
  post_by_number(post).has_content?(post.raw)
def has_post_bookmarked?(post)
  post_by_number(post).has_css?(".bookmarked")
Which are used like so inside system specs:
expect(topic_page).to have_post_content(post)
expect(topic_page).to have_post_bookmarked(post)
The opposite is true as well – you can define has_no_X? methods and they will do the opposite:
def has_no_d_editor?
  page.has_no_css?(D_EDITOR_SELECTOR)
Which is used like so in a system spec:
expect(category_page).to have_no_d_editor
Simple “boolean” methods like open?, closed? etc. will be usable as .to be_x RSpec matchers, which you can see the reference for at RubyDoc.info: Module: RSpec::Matchers – Documentation for rspec/rspec-expectations (main) – RubyDoc.info .
def open?
  has_css?(".dialog-container")
expect(dialog).to be_open
Discourse Secret Sauce
There are many Discourse-specific things to remember when writing system specs, whether they are commonly used helpers or general knowledge about the app and commonly used components. More may be added to this section over time.
fab!
If you have used let and let! in RSpec before then you will have an inkling of what fab! might do:
- fab!will create an instance variable that is stored and used for all the specs, rather than being recreated before each one like- letis. This is very useful for things like a User or Topic that is used multiple times in the spec without modification in a- contextblock.
- fab!can also be used with the name of a model, and it will use the default Fabricator for that model. For example- fab!(:topic)is the equivalent to doing- fab!(:topic) { Fabricate(:topic) }
You should use this whenever possible to avoid unnecessary database work.
Spec Helpers
Most of these can be found in SystemHelpers.
- sign_in- Directly posts to our- SessionController#becomeendpoint, which only works in the test environment. Used if you need to log in as a user for a test.
- try_until_success- Wrap an RSpec expectation in this block and it will run every 0.1 seconds until the provided timeout, which by default is the Capybara default max wait time. This is useful for checking the database directly to see if a change has been applied or for various other things where it is tricky to find a DOM element that you can wait for in the UI. Should be used sparingly.
- wait_for_attribute- Waits for an attribute to equal a value on a specific DOM element. Uses- try_until_successto wait for a maximum amount of time.
- wait_for_animation- Waits for an element to stop moving on the page, and for other animations to settle. Uses- try_until_successto wait for a maximum amount of time.
- resize_window- Temporarily resizes the browser window to a specific width and height.
- using_browser_timezone- Sets the timezone of the browser to something different to your local timezone using a TZ identifier (e.g.- Africa/Algiers)
- setup_system_test- Run automatically before every system spec, it sets various- SiteSettingvalues that make sense, e.g. disabling “user tips” so they don’t get in the way when searching for DOM elements.
Common Components
For common components, we should utilize Page Objects heavily to abstract repeated behavior. Below are some common components used widely throughout the app, what they do, and if possible a link to their Page Object class.
SelectKit
Used for all dropdowns, multiselects, and search fields in Discourse. See PageObjects::Components::SelectKit. You must expand the dropdown, then select an item from it using a name or a value. You may also want to manually collapse it at times in the case of multiselects. Example usage:
tag_chooser = PageObjects::Components::SelectKit.new(".tag-chooser")
tag_chooser.expand
tag_chooser.select_row_by_name(tag2.name)
tag_chooser.collapse
Toasts
Quick messages shown on the screen based on a user action, which can be success, warning, info, or error. See PageObjects::Components::Toasts. Example usage:
expect(toast).to have_success(I18n.t("some.success.message"))
Dialog
Messages shown to the user, which can be informative or require confirmation. See PageObjects::Components::Dialog. Example usage:
dialog.click_yes
expect(dialog).to be_closed
There are many more examples in spec/system/page_objects/components.
Plugins
Plugin system specs work in the same way as core system specs, but must be run from the directory of the discourse core repo.
I18n
When comparing strings stored in our server.en.yml and client.en.yml localization files for expectations in system specs, you should use our I18n library.
If you need to use a string from client.en.yml, which is where the majority of user-facing strings are stored, you will need to prefix it with either js. or admin_js. depending on whether it is from the admin interface or the rest of the interface:
# Admin string from client.en.yml
expect(sidebar).to have_no_section_link(
  I18n.t("admin_js.admin.community.sidebar_link.moderation_flags"),
# All other strings from client.en.yml
expect(find(".topic-list-header .static-label").text).to eq(
  I18n.t("js.filters.new.topics_with_count", count: 3),
Caveats
There are some caveats and situations where you don’t need to do this. For user-generated or fabricated strings, this is not necessary.
# Fabricated strings
fab!(:topic) { Fabricate(:topic, title: "Best topic ever!")
it "checks the topic title" do
  # Using a fabricated string directly
  expect(topic_page).to have_title(topic.title)
  # Also acceptable
  expect(topic_page).to have_title("Best topic ever!")
# User-generated strings
it "closes topics with message" do
  # Filling in a user-generated string
  topic_bulk_actions_modal.fill_in_close_note("None of these are useful")
  topic_bulk_actions_modal.click_bulk_topics_confirm
  # Check that the topic now has the message, which is user-generated content
  visit("/t/#{topic.slug}/#{topic.id}")
  expect(topic_page).to have_content("None of these are useful")
Finally, some strings are quite big and there’s no need to check that the entire contents are on the page and match correctly. In that case, matching part of the string with direct comparison is fine.
Rate Limiting
Our RateLimiter system is disabled by default in specs. However if you need to turn it on to test some rate limiting specifically in system specs (though you should use request specs for this), use RateLimiter.enable.
Advanced Chrome Interaction
In certain cases you will need to use some advanced features of Chrome in your system specs. Some examples are interacting with the clipboard (copy and paste) and network manipulation (simulating slow connections). This is achieved using the Chrome DevTools Protocol, and sometimes with native Capybara functionality.
These advanced interactions are all stored in the PageObjects::CDP class.
Clipboard example:
it "allows copying message transcripts" do
  cdp.allow_clipboard
  chat_page.visit_channel(channel_1)
  channel_page.messages.copy_text(message_1)
  expect(cdp.read_clipboard.chomp).to eq(message_1.message)
Network example:
it "allows cancelling uploads" do
  visit("/new-topic")
  expect(composer).to be_opened
  file_path_1 = file_from_fixtures("huge.jpg", "images").path
  cdp.with_slow_upload do
    attach_file(file_path_1) { composer.click_toolbar_button("upload") }
    expect(composer).to have_in_progress_uploads
    find("#cancel-file-upload").click
    expect(composer).to have_no_in_progress_uploads
    expect(composer.preview).to have_no_css(".image-wrapper")
Direct JavaScript Execution
You can also directly run arbitrary JavaScript code in the browser with Capybara though this should be done sparingly, since Ember manages the lifecycle of the app. If you must, you can do it like so:
page.execute_script(<<~JS)
  alert("Look ma, JavaScript!");
JS
Debugging
Writing and debugging system specs can be tricky at times, especially when they become “flaky” and start failing in strange ways. These debugging tools help with writing the specs in the first place and figuring out what is wrong.
- :traceallows to capture a trace in a zip file which you can load at https://trace.playwright.dev or locally through- pnpm dlx playwright show-trace /path/to/trace.zip
it "shows bar", trace: true do
  # code
- :videoallows to capture a video of your spec
it "shows bar", video: true do
  # code
- pause_test- This helper can be used in your spec to pause execution using- binding.pryso you can inspect the page and other local spec variables. You can resume execution when done. This can be used with- PWDEBUG=1to start the playwright debugger, this is currently limited.
- debuggerand- {{debugger}}- If you are using- PLAYWRIGHT_HEADLESS=0then any JavaScript debug breakpoints will be hit in the browser. The Ember- {{debugger}}helper in templates works as well.
- Screenshots - Every time a system spec fails Capybara will produce a screenshot, typically in the $REPO/tmp/capybaradirectory. You can also manually callsave_screenshotinside your spec to do this.
- save_and_open_page- Use this to dump the current HTML of the page and open it in your browser.
- PLAYWRIGHT_SLOW_MO_MS=1000allows you to have 1000ms delay on each action, useful to see what’s happening in your test.
Getting screenshots from Github Actions
For system test failures in Github Actions Runners, there are screenshots we can download from job artifacts. In the job’s summary, artifacts are located at the bottom.
This document is version controlled - suggest changes on github.
