Let's Encrypte with multiple domains wasn't working for ECC certs
How do I initiate the renewal of the certificate, simply delete the old one from /shared/ssl?
I reckon it does it always when rebuilded so there is no need to delete anything.
the certificate was issued yesterday, so normally it needs a --force in the LE scripts. I have now renamed the old certificates and am testing a rebuild.
Apparently this does not work, I do not get the second domain entered: https://ssl-tools.net/webservers/rpg-foren.com
It also doesnā€™t look like everything is replaced correctly, the ecc file is missing the subdomain:
cat /etc/runit/1.d/letsencrypt
#!/bin/bash
/usr/sbin/nginx -c /etc/nginx/letsencrypt.conf
issue_cert() {
  LE_WORKING_DIR="${LETSENCRYPT_DIR}" /shared/letsencrypt/acme.sh --issue $2 -d rpg-foren.com -d www.rpg-foren.com --keylength $1 -w /var/www/discourse/public
cert_exists() {
  [[ "$(cd /shared/letsencrypt/rpg-foren.com$1 && openssl verify -CAfile <(openssl x509 -in ca.cer) fullchain.cer | grep "OK")" ]]
# RSA cert
issue_cert "4096"
if ! cert_exists ""; then
  # Try to issue the cert again if something goes wrong
  issue_cert "4096" "--force"
fi
LE_WORKING_DIR="${LETSENCRYPT_DIR}" /shared/letsencrypt/acme.sh \
  --installcert \
  -d rpg-foren.com \
  -d www.rpg-foren.com --fullchainpath /shared/ssl/rpg-foren.com.cer \
  --keypath /shared/ssl/rpg-foren.com.key \
  --reloadcmd "sv reload nginx"
# ECDSA cert
issue_cert "ec-256"
if ! cert_exists "_ecc"; then
  issue_cert "ec-256" "--force"
fi
  --installcert --ecc \
  -d rpg-foren.com \
  --fullchainpath /shared/ssl/rpg-foren.com_ecc.cer \
  --keypath /shared/ssl/rpg-foren.com_ecc.key \
if cert_exists "" || cert_exists "_ecc"; then
  grep -q 'force_https' "/var/www/discourse/config/discourse.conf" || echo "force_https = 'true'" >> "/var/www/discourse/config/discourse.conf"
fi
/usr/sbin/nginx -c /etc/nginx/letsencrypt.conf -s stop
I have just executed the following manually, now the certificates fit:
/shared/letsencrypt/acme.sh --issue --force -d rpg-foren.com -d www.rpg-foren.com --keylength 4096 -w /var/www/discourse/public --server letsencrypt
/shared/letsencrypt/acme.sh --issue --force -d rpg-foren.com -d www.rpg-foren.com --keylength ec-256 -w /var/www/discourse/public --server letsencrypt
/shared/letsencrypt/acme.sh --installcert -d rpg-foren.com -d www.rpg-foren.com --fullchainpath /shared/ssl/rpg-foren.com.cer --keypath /shared/ssl/rpg-foren.com.key --reloadcmd "sv reload nginx"
/shared/letsencrypt/acme.sh --installcert -d rpg-foren.com -d www.rpg-foren.com --fullchainpath /shared/ssl/rpg-foren.com_ecc.cer --keypath /shared/ssl/rpg-foren.com_ecc.key --reloadcmd "sv reload nginx"
this is my rewrite for forwarding:
   # tell letsencrypt what additional certs to get
    - replace:
        filename: "/etc/runit/1.d/letsencrypt"
        to: "-d www.rpg-foren.com --keylength"
    - replace:
        to: "-d www.rpg-foren.com --fullchainpath"
    - file:
        path: /etc/nginx/conf.d/discourse_redirect.conf
        contents: |
          server {
            listen 80;
            listen 443 ssl;
            server_name www.rpg-foren.com;
            return 301 $scheme://rpg-foren.com$request_uri;
            ssl_protocols TLSv1.2 TLSv1.3;
            ssl_ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384;
            ssl_prefer_server_ciphers off;
            ssl_certificate /shared/ssl/rpg-foren.com.cer;
            ssl_certificate /shared/ssl/rpg-foren.com_ecc.cer;
            ssl_certificate_key /shared/ssl/rpg-foren.com.key;
            ssl_certificate_key /shared/ssl/rpg-foren.com_ecc.key;
            ssl_session_tickets off;
            ssl_session_timeout 1d;
            ssl_session_cache shared:SSL:1m;
Is it possible that a replace command is only executed once?
It looks like the cert is valid now?
Iā€™m pretty sure that redirects are handled somewhere else in the chain and you donā€™t need to do anything for that to work. I would probably remove that part from your yml file.
It seems like itā€™s working as expected now.
Yes, but I set it up manually and not via the hook, because the hook didnā€™t do it correctly.
you mean from the subdomain www. to the main domain? At least not via nginx. No url is defined there so that the web server responds to all incoming domains.
It works for me (see below).
I mean that anything that resolves to the site redirects to the hostname. For any standard install you can enter the IP address and itā€™ll redirect to the https://hostname. (See below)
I just set this up, creating a new standard install with https://dashboard.literatecomputing.com/, and additionally pasting extrahostname.myforum.us in the domain2 field above and copy/pasting the resulting after_ssl hook immediately after hooks: in web_only.yml (and did it while the script was building the data container, so I didnā€™t have to rebuild after it finished the first time!).
These all work as expected:
Does this mean that the subdomain is stored in /etc/runit/1.d/letsencrypt for both the rsa and ecc installation script?
As you can see above, the hook has only stored the subdomain in the rsa part but not in the ecc part.
  --installcert \
  -d rpg-foren.com \
  -d rpg-foren.com \
  --fullchainpath
Here is /etc/runit/1.d/letsencrypt
#!/bin/bash
issue_cert() {
  LE_WORKING_DIR="${LETSENCRYPT_DIR}" /shared/letsencrypt/acme.sh --issue $2 -d test.myforum.us -d extrahostname.myforum.us --keylength $1 -w /var/www/discourse/public
cert_exists() {
  [[ "$(cd /shared/letsencrypt/test.myforum.us$1 && openssl verify -CAfile <(openssl x509 -in ca.cer) fullchain.cer | grep "OK")" ]]
# RSA cert
issue_cert "4096"
fi
  --installcert \
  -d test.myforum.us \
  -d extrahostname.myforum.us  --fullchainpath /shared/ssl/test.myforum.us.cer \
  --keypath /shared/ssl/test.myforum.us.key \
# ECDSA cert
issue_cert "ec-256"
fi
  --fullchainpath /shared/ssl/test.myforum.us_ecc.cer \
  --keypath /shared/ssl/test.myforum.us_ecc.key \
fi
Ah. I see itā€™s in the RSA (bad) cert, but not in the ECC (good) cert.
OK. now I get it. That --fullcert stanza needs global: true in it. Iā€™m testing it now.
OK. Hereā€™s the new ā€˜/etc/runit/1.d/letsencryptā€™
#!/bin/bash
issue_cert() {
cert_exists() {
# RSA cert
issue_cert "4096"
fi
  --installcert \
# ECDSA cert
issue_cert "ec-256"
fi
  -d extrahostname.myforum.us  --fullchainpath /shared/ssl/test.myforum.us_ecc.cer \
fi
and now I have this, which looks good? https://ssl-tools.net/webservers/extrahostname.myforum.us
Does that look right? If so, Iā€™ll edit the OP to include the global directive.
My Idea:
    - replace:
    - replace:
        to:  |
          --installcert \
    - replace:
        to:  |
Does mine not work? Itā€™s got 1/3 fewer lines of code.
I donā€™t see a rewrite from you? or am I missing something?
i just wanted to make a nice rewrite so that the file looks good at the end^^
I didnā€™t do it yet. I was waiting to see that you thought it worked.
Hereā€™s the change, just adding global: true to the end of the second replace:
    - replace:
        to: "-d =domain2=  --fullchainpath"
        global: true
and hereā€™s the whole thing:
  after_ssl:
    - replace:
        to: "-d extrahostname.myforum.us --keylength"
    - replace:
        to: "-d extrahostname.myforum.us  --fullchainpath"
        global: true
ok so global is the parameter you need for multiple replacements.
looks good from the files you posted, I havenā€™t tried it yet.
Yeah. Sorry that I wasnā€™t paying close enough attention to undertand what you were talking about earlier. From my (bad) test, it ā€œworkedā€, but I didnā€™t notice, and donā€™t know how to check that the ec-whatever cert is really there. Thanks for being persistent.
Does https://ssl-tools.net/webservers/extrahostname.myforum.us make it look like itā€™s got the Right Stuff?
I edited the OP now, so you can give it a shot, and copy/paste from the form above.
If you want to test yourself on a test site and can send me an SSH key, Iā€™ll give you access to the one I just set up. Then you can do a clean install there with your own test domain. Or, you can just do it on your production site and hope for the best. :person_shrugging:
You can find it here:
ls -la /var/discourse/shared/standalone/ssl/
total 24
drwxr-xr-x  2 root root 4096 Sep 24 13:02 .
drwxr-xr-x 15 root root 4096 Sep 23 18:31 ..
-rw-r--r--  1 root root 3941 Sep 25 07:43 rpg-foren.com.cer
-rw-r--r--  1 root root 3941 Sep 25 07:43 rpg-foren.com_ecc.cer
-rw-------  1 root root 3243 Sep 25 07:43 rpg-foren.com_ecc.key
-rw-------  1 root root 3243 Sep 25 07:43 rpg-foren.com.key
the problem is, i donā€™t know how to test ecc and rsa individually.
since the creation file now fits, no further tests are required.
root@test-web-only:/shared/ssl# ls -l
total 16
-rw-r--r-- 1 root root 3953 Sep 25 16:41 test.myforum.us.cer
-rw-r--r-- 1 root root 2877 Sep 25 16:41 test.myforum.us_ecc.cer
-rw------- 1 root root  227 Sep 25 16:41 test.myforum.us_ecc.key
-rw------- 1 root root 3247 Sep 25 16:41 test.myforum.us.key
Cool. If you think this looks good, then Iā€™m going to move this discussion to a new topic since hopefully itā€™s resolved.
you can test the certificate like this:
openssl x509 -in /var/discourse/shared/standalone/ssl/test.myforum.us.cer -noout -text
then the domains should be listed under dns:
DNS:rpg-foren.com, DNS:www.rpg-foren.com
root@test:/var/discourse# openssl x509 -in /var/discourse/shared/web-only/ssl/test.myforum.us.cer -noout -text
Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number:
            03:f8:b5:6a:e0:97:53:7f:22:33:81:22:35:b4:3f:73:75:7f
        Signature Algorithm: sha256WithRSAEncryption
        Issuer: C = US, O = Let's Encrypt, CN = R10
        Validity
            Not Before: Sep 25 14:57:13 2024 GMT
            Not After : Dec 24 14:57:12 2024 GMT
        Subject: CN = test.myforum.us
        Subject Public Key Info:
            Public Key Algorithm: rsaEncryption
                Public-Key: (4096 bit)
                Modulus:
                    00:be:a3:9b:79:78:dd:8f:e2:8f:28:f0:d9:6c:74:
...                    b0:84:33
                Exponent: 65537 (0x10001)
        X509v3 extensions:
            X509v3 Key Usage: critical
                Digital Signature, Key Encipherment
            X509v3 Extended Key Usage:
                TLS Web Server Authentication, TLS Web Client Authentication
            X509v3 Basic Constraints: critical
                CA:FALSE
            X509v3 Subject Key Identifier:
                43:55:B7:D6:54:03:CE:B0:FB:C8:D1:2A:42:F5:B7:C5:60:C7:D8:48
            X509v3 Authority Key Identifier:
                BB:BC:C3:47:A5:E4:BC:A9:C6:C3:A4:72:0C:10:8D:A2:35:E1:C8:E8
            Authority Information Access:
                OCSP - URI:http://r10.o.lencr.org
                CA Issuers - URI:http://r10.i.lencr.org/
            X509v3 Subject Alternative Name:
                DNS:extrahostname.myforum.us, DNS:test.myforum.us
            X509v3 Certificate Policies:
                Policy: 2.23.140.1.2.1
            CT Precertificate SCTs:
                Signed Certificate Timestamp:
                    Version   : v1 (0x0)
                    Log ID    : DF:E1:56:EB:AA:05:AF:B5:9C:0F:86:71:8D:A8:C0:32:
                                4E:AE:56:D9:6E:A7:F5:A5:6A:01:D1:C1:3B:BE:52:5C
                    Timestamp : Sep 25 15:55:44.143 2024 GMT
                    Extensions: none
                    Signature : ecdsa-with-SHA256
                    Version   : v1 (0x0)
                    Log ID    : A2:E3:0A:E4:45:EF:BD:AD:9B:7E:38:ED:47:67:77:53:
                                D7:82:5B:84:94:D7:2B:5E:1B:2C:C4:B9:50:A4:47:E7
                    Timestamp : Sep 25 15:55:45.945 2024 GMT
                    Extensions: none
    Signature Value:
        cf:c6:59:d8
and that includes:
Ah. OK.
openssl x509 -in /var/discourse/shared/web-only/ssl/test.myforum.us_ecc.cer -noout -text
contains:
