Discourse interface don't start after upgrading to v3.4.0.beta3-dev
For being able to upgrad to 3.4.0 I had to upgrade docker to 20.0.7 and for doing this, I had to upgrade Ubuntu to 20.04
Now everything is upgraded, no aparent error message on the console.
When I start my discourse from an anonymous windows y get the login windows
When I type my autentication info it seams I am going to log but the screen remain as next image.
I tried with different explorers (firefox, brave) but problem is the same. As soon as I enter the login info my sesion is hang.
If I don’t log, I can navigate and see public information.
Thank you for any suggestion
I am very worried to return to my previous system after all the work of upgrading.
Thanks
Try reloading it again, or wait it out, the forum might be in extreme load at the time.
Are there any errors in the browser console after logging in?
Did you try safe mode?
You seem to have a few relatively unknown plugins. At least one of them is known to cause issues which are very similar to yours:
So you might try uninstalling that one.
What does your browser console say?
I forgot this option. Thanks to remember it allow me to continue debugging the problem and to be more relax (at least everything was there :rofl: )
You are correct. Uninstalling these plugin solve the point. Thanks a lot for everybody help.
