Is there a webhook that could fire when someone creates a Whisper post? I’m guessing not but just in case I’m asking.
I don’t think it’s possible to configure a webhooks so that it only fires when a whisper post is created, but you can create a Post Events webhook and then filter for whisper posts in the code that receives the webhook.
The payload for whisper posts will have the post_type
field set to 4
. For example:
"post": {
"id": 740,
"name": null,
"username": "scossar",
"avatar_template": "/letter_avatar_proxy/v4/letter/s/b77776/{size}.png",
"created_at": "2024-10-18T17:00:36.065Z",
"cooked": "<p>testing whispers and webhooks</p>",
"post_number": 5,
"post_type": 4,
The possible values for the post_type
field are:
[2] pry(main)> Post.types
=> {:regular=>1,
:moderator_action=>2,
:small_action=>3,
:whisper=>4}
Many thanks @simon
That is simpler than I thought. I didn’t realize/see that 4 is the code for whisper.
Rene
