Implantar Discourse sem Docker
Though it is more convenient and safer to deploy Discourse following the official install guide, I want to dive deeper into the container and see how it can be deployed in Linux without Docker. I want to share the steps just for your information. You adapt it and use it at your own risk.
Dive into how Discourse is run in container
I take a look at the output of ./launcher start-cmd webonly:
true run --shm-size=512m --link data:data -d --restart=always -e LANG=en_US.UTF-8 -e RAILS_ENV=production … --name webonly -t -v /var/discourse/shared/webonly:/shared … local_discourse/webonly /sbin/boot
then look at /sbin/boot and /etc/service/unicorn/run, I get the core cmd to start Discourse:
LD_PRELOAD=$RUBY_ALLOCATOR HOME=/home/discourse USER=discourse exec thpoff chpst -u discourse:www-data -U discourse:www-data bundle exec config/unicorn_launcher -E production -c config/unicorn.conf.rb
prepare system
FYI, I use Ubuntu 24.04 and zsh.
Follow PG’s offical installation guide to install postgres from PostgreSQL Apt Repository. I installed the version 18, which works quite well, though the offical install uses 15 at time of writing.
Install redis(8.2 at time of writing, official install uses 7.0), nginx and create dedicated user discourse:
apt install nginx libnginx-mod-http-brotli-static redis zsh zsh-autosuggestions zsh-syntax-highlighting
systemctl enable --now postgresql redis nginx
useradd -m -s /bin/zsh discourse
Install ImageMagick 7 (I use IMEI) and check the version. Mine is:
magick --version
Version: ImageMagick 7.1.2-3 Q16-HDRI
then, change user(su - discourse) and install pnpm, rvm.
curl -fsSL https://get.pnpm.io/install.sh | zsh -
curl -sSL https://get.rvm.io | bash
then adapt and add the following config to your .zshrc
/home/discourse/.zshrc
# pnpm
export PNPM_HOME="/home/discourse/.local/share/pnpm"
case ":$PATH:" in
  *":$PNPM_HOME:"*) ;;
  *) export PATH="$PNPM_HOME:$PATH" ;;
esac
# pnpm end
alias npm='pnpm'
alias npx='pnpx'
# Add RVM to PATH for scripting. Make sure this is the last PATH variable change.
export PATH="$PATH:$HOME/.rvm/bin"
export ALLOW_EMBER_CLI_PROXY_BYPASS=1
export RAILS_ENV=production
export UNICORN_SIDEKIQ_MAX_RSS=1000
export UNICORN_WORKERS=4
export UNICORN_SIDEKIQS=1
export PUMA_SIDEKIQ_MAX_RSS=1000
export PUMA_WORKERS=4
export PUMA_SIDEKIQS=1
#export RUBY_YJIT_ENABLE=1
#export RUBY_CONFIGURE_OPTS="--enable-yjit"
export DISCOURSE_HOSTNAME=example.com
export DISCOURSE_DEVELOPER_EMAILS=discourse-admin@example.com
export DISCOURSE_MAXMIND_ACCOUNT_ID=<id>
export DISCOURSE_MAXMIND_LICENSE_KEY=<key>
export DISCOURSE_ENABLE_CORS=true
export DISCOURSE_MAX_REQS_PER_IP_MODE=none
export DISCOURSE_MAX_REQS_PER_IP_PER_MINUTE=20000
export DISCOURSE_MAX_REQS_PER_IP_PER_10_SECONDS=5000
export DISCOURSE_MAX_ASSET_REQS_PER_IP_PER_10_SECONDS=20000
export DISCOURSE_MAX_REQS_RATE_LIMIT_ON_PRIVATE=false
export DISCOURSE_MAX_USER_API_REQS_PER_MINUTE=200
export DISCOURSE_MAX_USER_API_REQS_PER_DAY=28800
export DISCOURSE_MAX_ADMIN_API_REQS_PER_MINUTE=600
export DISCOURSE_MAX_DATA_EXPLORER_API_REQ_MODE=none
export DISCOURSE_MAX_REQS_PER_IP_EXCEPTIONS="127.0.0.1 ::1"
cd /var/www/discourse
logout and login again as discourse for .zshrc to take effect.
Install node and ruby:
pnpm env use --global latest # will install node 24.9 at time of writing. offical install uses 22
rvm get master
rvm install 3.4 # will install ruby 3.4.6 at time of writing. official install uses 3.3
rvm use 3.4 --default
prepare db (and restore a backup)
sudo -u postgres createuser -s discourse
sudo -u postgres createdb discourse
$sudo -u postgres psql discourse
psql>
ALTER USER discourse WITH PASSWORD 'xxx';
CREATE EXTENSION hstore;CREATE EXTENSION pg_trgm;
CREATE EXTENSION plpgsql;
CREATE EXTENSION unaccent;
CREATE EXTENSION vector;
# to restore database extracted from a backup:
$ gunzip < dump.sql.gz | psql discourse
To restore backup, you also need to copy the public and plugins folder as well.
install Discourse
I consulted discourse_docker/templates/web.template.yml at 20e33fbfd98d3b8d9c57f7a111beff8aa51a5b98 · discourse/discourse_docker · GitHub
as user root:
cd /var/www/
git clone https://github.com/discourse/discourse
mkdir -p /var/www/discourse/public
chown -R discourse:discourse /var/www/discourse/
chown -R discourse:www-data /var/www/discourse/public
configure config/discourse.conf:
max_data_explorer_api_req_mode = 'none'
max_user_api_reqs_per_day = '28800'
hostname = '127.0.0.1'
hostname = 'example.com'
redis_host = '127.0.0.1'
db_password = '<password>'
db_socket = ''
max_reqs_per_ip_per_10_seconds = '5000'
max_asset_reqs_per_ip_per_10_seconds = '20000'
max_reqs_rate_limit_on_private = 'false'
developer_emails = 'discourse-admin@example.com'
max_user_api_reqs_per_minute = '200'
maxmind_license_key = '<key>'
maxmind_account_id = '<id>'
max_reqs_per_ip_per_minute = '20000'
db_host = '127.0.0.1'
enable_cors = 'true'
db_port = ''
max_reqs_per_ip_mode = 'none'
max_admin_api_reqs_per_minute = '600'
smtp_user_name = '<name>'
smtp_address = 'postal.example.com'
smtp_port = '25'
smtp_password = '<password>'
smtp_domain = 'postalsend.example.com'
notification_email = 'noreply@postalsend.example.com'
Do the bundle / pnpm install, db migration, assets precompile stuff. This is also how you upgrade discourse and plugins.
as user discourse:
git stash
git pull
git checkout tests-passed
cd plugins
for plugin in *
do
    echo $plugin; cd ${plugin}; git pull; cd ..
done
cd ../
sed -i '/gem "rails_multisite"/i gem "rails"' Gemfile
bundle install --jobs $(($(nproc) - 1))
pnpm i
bundle exec rake db:migrate
bundle exec rake themes:update
bundle exec rake assets:precompile
I don’t want to use unicorn. Heroku recommends using the Puma web server instead of Unicorn. Here is my config/puma.rb written after consulting config/unicorn.conf.rb:
config/puma.rb
# frozen_string_literal: true
require "fileutils"
#require 'puma/acme'
discourse_path = File.expand_path(File.expand_path(File.dirname(__FILE__)) + "/../")
enable_logstash_logger = ENV["ENABLE_LOGSTASH_LOGGER"] == "1"
puma_stderr_path = "#{discourse_path}/log/puma.stderr.log"
puma_stdout_path = "#{discourse_path}/log/puma.stdout.log"
# Load logstash logger if enabled
if enable_logstash_logger
  require_relative "../lib/discourse_logstash_logger"
  FileUtils.touch(puma_stderr_path) if !File.exist?(puma_stderr_path)
  # Note: You may need to adapt the logger initialization for Puma
  log_formatter =
    proc do |severity, time, progname, msg|
      event = {
        "@timestamp" => Time.now.utc,
        "message" => msg,
        "severity" => severity,
        "type" => "puma",
      "#{event.to_json}\n"
else
  stdout_redirect puma_stdout_path, puma_stderr_path, true
# Number of workers (processes)
workers ENV.fetch("PUMA_WORKERS", 6).to_i
# Set the directory
directory discourse_path
# Bind to the specified address and port
bind ENV.fetch(
       "PUMA_BIND",
       "tcp://#{ENV["PUMA_BIND_ALL"] ? "" : "127.0.0.1:"}#{ENV.fetch("PUMA_PORT", 3000)}",
#bind 'tcp://0.0.0.0:80'
#plugin :acme
#acme_server_name 'example.com'
#acme_tos_agreed true
#bind 'acme://0.0.0.0:443'
# PID file location
FileUtils.mkdir_p("#{discourse_path}/tmp/pids")
pidfile ENV.fetch("PUMA_PID_PATH", "#{discourse_path}/tmp/pids/puma.pid")
# State file - used by pumactl
state_path "#{discourse_path}/tmp/pids/puma.state"
# Environment-specific configuration
if ENV["RAILS_ENV"] == "production"
  # Production timeout
  worker_timeout 30
else
  # Development timeout
  worker_timeout ENV.fetch("PUMA_TIMEOUT", 60).to_i
# Preload application
preload_app!
# Handle worker boot and shutdown
before_fork do
  Discourse.preload_rails!
  Discourse.before_fork
  # Supervisor check
  supervisor_pid = ENV["PUMA_SUPERVISOR_PID"].to_i
  if supervisor_pid > 0
    Thread.new do
      loop do
        unless File.exist?("/proc/#{supervisor_pid}")
          puts "Kill self supervisor is gone"
          Process.kill "TERM", Process.pid
        sleep 2
  # Sidekiq workers
  sidekiqs = ENV["PUMA_SIDEKIQS"].to_i
  if sidekiqs > 0
    puts "starting #{sidekiqs} supervised sidekiqs"
    require "demon/sidekiq"
    Demon::Sidekiq.after_fork { DiscourseEvent.trigger(:sidekiq_fork_started) }
    Demon::Sidekiq.start(sidekiqs)
    if Discourse.enable_sidekiq_logging?
      Signal.trap("USR1") do
        # Delay Sidekiq log reopening
        sleep 1
        Demon::Sidekiq.kill("USR2")
  # Email sync demon
  if ENV["DISCOURSE_ENABLE_EMAIL_SYNC_DEMON"] == "true"
    puts "starting up EmailSync demon"
    Demon::EmailSync.start(1)
  # Plugin demons
  DiscoursePluginRegistry.demon_processes.each do |demon_class|
    puts "starting #{demon_class.prefix} demon"
    demon_class.start(1)
  # Demon monitoring thread
  Thread.new do
    loop do
      begin
        sleep 60
        if sidekiqs > 0
          Demon::Sidekiq.ensure_running
          Demon::Sidekiq.heartbeat_check
          Demon::Sidekiq.rss_memory_check
          Demon::EmailSync.ensure_running
          Demon::EmailSync.check_email_sync_heartbeat
        DiscoursePluginRegistry.demon_processes.each(&:ensure_running)
      rescue => e
        Rails.logger.warn(
          "Error in demon processes heartbeat check: #{e}\n#{e.backtrace.join("\n")}",
  # Close Redis connection
  Discourse.redis.close
on_worker_boot do
  DiscourseEvent.trigger(:web_fork_started)
  Discourse.after_fork
# Worker timeout handling
worker_timeout 30
# Low-level worker options
threads 8, 32
To run Discourse, run puma -C config/puma.rb
Using systemd, you can run it on boot and restart it on failure. Here is the service file:
/etc/systemd/system/discourse.service
[Unit]
Description=Discourse with Puma Server
After=network.target postgresql.service
Requires=postgresql.service
[Service]
Type=simple
User=discourse
Group=discourse
WorkingDirectory=/var/www/discourse
# requires running `rvm 3.4.6 --default` before this service is run
ExecStart=/usr/bin/zsh -lc 'source /home/discourse/.zshrc && /home/discourse/.rvm/gems/ruby-3.4.6/bin/puma -C config/puma.rb'
ExecReload=/usr/bin/zsh -lc 'source /home/discourse/.zshrc && /home/discourse/.rvm/gems/ruby-3.4.6/bin/pumactl restart'
# Restart configuration
Restart=always
RestartSec=5s
# Basic security measures
NoNewPrivileges=true
ProtectSystem=full
ProtectHome=read-only
[Install]
WantedBy=multi-user.target
Now the puma server listens on 127.0.0.1:3000. Adapt the nginx config file from Docker:
/etc/nginx/sites-enabled/discourse.conf
# Additional MIME types that you'd like nginx to handle go in here
types {
    text/csv csv;
    #application/wasm wasm;
upstream discourse { server 127.0.0.1:3000; }
# inactive means we keep stuff around for 1440m minutes regardless of last access (1 week)
# levels means it is a 2 deep hierarchy cause we can have lots of files
# max_size limits the size of the cache
proxy_cache_path /var/nginx/cache inactive=1440m levels=1:2 keys_zone=one:10m max_size=600m;
# Increased from the default value to acommodate large cookies during oAuth2 flows
# like in https://meta.discourse.org/t/x/74060 and large CSP and Link (preload) headers
proxy_buffer_size 32k;
proxy_buffers 4 32k;
# Increased from the default value to allow for a large volume of cookies in request headers
# Discourse itself tries to minimise cookie size, but we cannot control other cookies set by other tools on the same domain.
large_client_header_buffers 4 32k;
# attempt to preserve the proto, must be in http context
map $http_x_forwarded_proto $thescheme {
  default $scheme;
  "~https$" https;
log_format log_discourse '[$time_local] "$http_host" $remote_addr "$request" "$http_user_agent" "$sent_http_x_discourse_route" $status $bytes_sent "$http_referer" $upstream_response_time $request_time "$upstream_http_x_discourse_username" "$upstream_http_x_discourse_trackview" "$upstream_http_x_queue_time" "$upstream_http_x_redis_calls" "$upstream_http_x_redis_time" "$upstream_http_x_sql_calls" "$upstream_http_x_sql_time"';
# Allow bypass cache from localhost
#geo $bypass_cache {
#  default         0;
#  127.0.0.1       1;
#  ::1             1;
limit_req_zone $binary_remote_addr zone=flood:10m rate=12r/s;
limit_req_zone $binary_remote_addr zone=bot:10m rate=200r/m;
limit_req_status 429;
limit_conn_zone $binary_remote_addr zone=connperip:10m;
limit_conn_status 429;
server {
  access_log /var/log/nginx/access.log log_discourse;
  #listen unix:/var/nginx/nginx.http.sock;
  listen 443 ssl;
  listen [::]:443 ssl;
  server_name example.com;
  ssl_certificate /etc/nginx/ssl/example.com.cer;
  ssl_certificate_key /etc/nginx/ssl/example.com.key;
  ssl_protocols       TLSv1 TLSv1.1 TLSv1.2 TLSv1.3;
  ssl_ciphers         HIGH:!aNULL:!MD5;
  set_real_ip_from unix:;
  set_real_ip_from  127.0.0.1/32;
  set_real_ip_from  ::1/128;
  real_ip_header    X-Forwarded-For;
  real_ip_recursive on;
  gzip on;
  gzip_vary on;
  gzip_min_length 1000;
  gzip_comp_level 5;
  gzip_types application/json text/css text/javascript application/x-javascript application/javascript image/svg+xml application/wasm;
  gzip_proxied any;
  # Uncomment and configure this section for HTTPS support
  # NOTE: Put your ssl cert in your main nginx config directory (/etc/nginx)
  # rewrite ^/(.*) https://enter.your.web.hostname.here/$1 permanent;
  # listen 443 ssl;
  # ssl_certificate your-hostname-cert.pem;
  # ssl_certificate_key your-hostname-cert.key;
  # ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
  # ssl_ciphers HIGH:!aNULL:!MD5;
  server_tokens off;
  sendfile on;
  keepalive_timeout 65;
  # maximum file upload size (keep up to date when changing the corresponding site setting)
  client_max_body_size 128m ;
  # path to discourse's public directory
  set $public /var/www/discourse/public;
  # without weak etags we get zero benefit from etags on dynamically compressed content
  # further more etags are based on the file in nginx not sha of data
  # use dates, it solves the problem fine even cross server
  etag off;
  # prevent direct download of backups
  location ^~ /backups/ {
    internal;
  # bypass rails stack with a cheap 204 for favicon.ico requests
  location /favicon.ico {
    return 204;
    access_log off;
    log_not_found off;
  location / {
    root $public;
    add_header ETag "";
    # auth_basic on;
    # auth_basic_user_file /etc/nginx/htpasswd;
    location ~ ^/uploads/short-url/ {
      proxy_set_header Host $http_host;
      proxy_set_header X-Real-IP $remote_addr;
      proxy_set_header X-Request-Start "t=${msec}";
      proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
      proxy_set_header X-Forwarded-Proto $thescheme;
      proxy_pass http://discourse;
      break;
    location ~ ^/(secure-media-uploads/|secure-uploads)/ {
      break;
    location ~* (fonts|assets|plugins|uploads)/.*\.(eot|ttf|woff|woff2|ico|otf)$ {
      expires 1y;
      add_header Cache-Control public,immutable;
      add_header Access-Control-Allow-Origin *;
    location = /srv/status {
      access_log off;
      log_not_found off;
      break;
    # some minimal caching here so we don't keep asking
    # longer term we should increase probably to 1y
    location ~ ^/javascripts/ {
      expires 1d;
    location ~ ^/assets/(?<asset_path>.+)$ {
      expires 1y;
      # asset pipeline enables this
      brotli_static on;
      gzip_static on;
      # HOOK in asset location (used for extensibility)
      # TODO I don't think this break is needed, it just breaks out of rewrite
      break;
    location ~ ^/plugins/ {
      expires 1y;
    # cache emojis
    location ~ /images/emoji/ {
      expires 1y;
    location ~ ^/uploads/ {
      # NOTE: it is really annoying that we can't just define headers
      # at the top level and inherit.
      # proxy_set_header DOES NOT inherit, by design, we must repeat it,
      # otherwise headers are not set correctly
      proxy_set_header X-Sendfile-Type X-Accel-Redirect;
      proxy_set_header X-Accel-Mapping $public/=/downloads/;
      expires 1y;
      ## optional upload anti-hotlinking rules
      #valid_referers none blocked mysite.com *.mysite.com;
      #if ($invalid_referer) { return 403; }
      # custom CSS
      location ~ /stylesheet-cache/ {
          try_files $uri =404;
      # this allows us to bypass rails
      location ~* \.(gif|png|jpg|jpeg|bmp|tif|tiff|ico|webp|avif)$ {
      # SVG needs an extra header attached
      location ~* \.(svg)$ {
      # thumbnails & optimized images
      location ~ /_?optimized/ {
      break;
    location ~ ^/admin/backups/ {
      break;
    # This big block is needed so we can selectively enable
    # acceleration for backups, avatars, sprites and so on.
    # see note about repetition above
    location ~ ^/(svg-sprite/|letter_avatar/|letter_avatar_proxy/|user_avatar|highlight-js|stylesheets|theme-javascripts|favicon/proxied|service-worker) {
      # if Set-Cookie is in the response nothing gets cached
      # this is double bad cause we are not passing last modified in
      proxy_ignore_headers "Set-Cookie";
      proxy_hide_header "Set-Cookie";
      proxy_hide_header "X-Discourse-Username";
      proxy_hide_header "X-Runtime";
      # note x-accel-redirect can not be used with proxy_cache
      proxy_cache one;
      proxy_cache_key "$scheme,$host,$request_uri";
      proxy_cache_valid 200 301 302 7d;
      #proxy_cache_bypass $bypass_cache;
      break;
    # we need buffering off for message bus
    location /message-bus/ {
      proxy_http_version 1.1;
      proxy_buffering off;
      break;
    # this means every file in public is tried first
    try_files $uri @discourse;
  location /downloads/ {
    internal;
    alias $public/;
  location @discourse {
  limit_conn connperip 20;
  limit_req zone=flood burst=12 nodelay;
  limit_req zone=bot burst=100 nodelay;
Now your Discourse can be accessed from example.com:443.
maintenance
To access rails console, simply run rails c as user discourse in /var/www/discourse. The discourse cmd which can be found in official doc is basically bundle exec script/discourse.
To upgrade Discourse, consult #upgrade-cmd, then restart puma using either puma restart or puma phased-restart. For the difference, consult puma/docs/restart.md at main · puma/puma · GitHub .
8 curtidas
Isso deveria ser movido para Community wiki > Sysadmins, talvez?
Olá. Obrigado por compartilhar.
Estou escrevendo um script para isso para ser instalado no Debian 12 em um contêiner LXC. Está quase pronto e funciona bem. Publicarei quando estiver pronto.
Consegui exibir a primeira página para o registro do administrador. Mas o e-mail de confirmação é enviado para discourse@myhostname e para myhostname como smtp_server, então é um absurdo. As variáveis em .bashrc (ou .zshrc), nem em discourse.conf são levadas em consideração para o envio do e-mail. O email_adress para o desenvolvedor está correto, mas todos os outros parâmetros estão errados e não consegui alterá-los. Você teria alguma ideia de como conseguir isso?
1 curtida
De acordo com o código
O SMTP deve ser configurado em config/discourse.conf.
Para mim, tenho estas linhas nele:
smtp_user_name = '...com'
smtp_address = '...com'
smtp_port = '587'
smtp_password = '...'
smtp_domain = '...com'
notification_email = 'noreply@....com'
Você já verificou os logs? Para esta instalação personalizada, o log está em production.log, production.log, puma.stdout.log no diretório log.
Muito obrigado pela sua resposta.
Já tenho essas configurações em config/discourse.conf. Fiz exatamente o que você escreveu, exceto com zsh.
Meus logs não falam sobre smtp, e o único (production.log) é
\u003e Started GET “/” for 192.168.1.14 at 2025-09-15 17:12:51 +0000
\u003e Processing by FinishInstallationController#index as HTML
\u003e Rendered layout layouts/finish_installation.html.erb (Duration: 57.8ms | GC: 1.0ms)
\u003e Completed 200 OK in 164ms (Views: 61.7ms | ActiveRecord: 0.0ms (0 queries, 0 cached) | GC: 8.7ms)
\u003e Started GET “/finish-installation/register” for 192.168.1.14 at 2025-09-15 17:12:53 +0000
\u003e Processing by FinishInstallationController#register as HTML
\u003e Rendered layout layouts/finish_installation.html.erb (Duration: 63.8ms | GC: 1.5ms)
\u003e Completed 200 OK in 166ms (Views: 68.0ms | ActiveRecord: 0.0ms (0 queries, 0 cached) | GC: 5.4ms)
\u003e Started POST “/finish-installation/register” for 192.168.1.14 at 2025-09-15 17:12:54 +0000
\u003e Parameters: {“authenticity_token”=\u003e“U9_0mqt8iE5Y_jdNSV5uZxOgz9rspJbEsohs0jU8QTOPaOXdyaG-oLSFYtn9dQ2-mdHYvCzjFsRaqzp6YlNzbQ”, “email”=\u003e“webmaster@domain.app”, “username”=\u003e“ioio”, “password”=\u003e“\[FILTERED\]”, “commit”=\u003e“Register”}
\u003e Redirected to http://myhostname/finish-installation/confirm-email
\u003e Completed 302 Found in 140ms (ActiveRecord: 0.0ms (0 queries, 0 cached) | GC: 4.4ms)
\u003e Started GET “/finish-installation/confirm-email” for 192.168.1.14 at 2025-09-15 17:12:54 +0000
\u003e Processing by FinishInstallationController#confirm_email as HTML
\u003e Rendered layout layouts/finish_installation.html.erb (Duration: 62.1ms | GC: 1.5ms)
Os logs do meu servidor de e-mail não mostram nenhuma entrada do servidor discourse (funciona para todos os meus outros servidores (todos os contêineres lxc). Posso enviar um e-mail com sucesso via comando de terminal mail.
com puma -C config/puma.rb:
\u003e Use ‘before_worker_boot’, ‘on_worker_boot’ is deprecated and will be removed in v8
\u003e \[498\] Puma starting in cluster mode…
\u003e \[498\] \* Puma version: 7.0.0 (“Romantic Warrior”)
\u003e \[498\] \* Ruby version: ruby 3.3.9 (2025-07-24 revision f5c772fc7c) \[x86_64-linux\]
\u003e \[498\] \* Min threads: 8
\u003e \[498\] \* Max threads: 32
\u003e \[498\] \* Environment: production
\u003e \[498\] \* Master PID: 498
\u003e \[498\] \* Workers: 8
\u003e \[498\] \* Restarts: (:check_mark:) hot (:multiply:) phased (:multiply:) refork
\u003e \[498\] \* Preloading application
\u003e \[498\] \* Listening on http://127.0.0.1:3000
\u003e \[498\] ! WARNING: Detected 2 Thread(s) started in app boot:
\u003e \[498\] ! #\u003cThread:0x00007f43cec88b38 /home/discourse/.rvm/gems/ruby-3.3.9/gems/message_bus-4.4.1/lib/message_bus.rb:738 sleep\u003e - /home/discourse/.rvm/gems/ruby-3.3.9/gems/redis-client-0.25.2/lib/redis_client/ruby_connection/buffered_io.rb:213:in wait_readable' [498] ! #\u003cThread:0x00007f43cec887f0 /home/discourse/.rvm/gems/ruby-3.3.9/gems/message_bus-4.4.1/lib/message_bus/timer_thread.rb:38 sleep\u003e - /home/discourse/.rvm/gems/ruby-3.3.9/gems/message_bus-4.4.1/lib/message_bus/timer_thread.rb:130:in sleep’
\u003e \[498\] Use Ctrl-C to stop
meu discourse.conf:
\u003e max_data_explorer_api_req_mode = ‘none’
\u003e max_user_api_reqs_per_day = ‘28800’
\u003e hostname = ‘xxxxxxxxxxxxxxxxx.xxxx.app’
\u003e redis_host = ‘localhost’
\u003e smtp_user_name = ‘xxxxx@xxxxx.app’
\u003e db_password = ‘password’
\u003e smtp_address = ‘mail.xxxxx.app’
\u003e db_socket = ‘’
\u003e max_reqs_per_ip_per_10_seconds = ‘5000’
\u003e max_asset_reqs_per_ip_per_10_seconds = ‘20000’
\u003e max_reqs_rate_limit_on_private = ‘false’
\u003e developer_emails = ‘webmaster@xxx.app’
\u003e max_user_api_reqs_per_minute = ‘200’
\u003e maxmind_license_key = ‘’
\u003e smtp_port = ‘465’
\u003e maxmind_account_id = ‘50’
\u003e smtp_password = ‘xxxxxx’
\u003e max_reqs_per_ip_per_minute = ‘20000’
\u003e notification_email = ‘no-reply-discourse@xxx.app’
\u003e db_host = ‘localhost’
\u003e enable_cors = ‘true’
\u003e db_port = ‘’
\u003e max_reqs_per_ip_mode = ‘none’
\u003e smtp_domain = ‘xxx.app’
\u003e max_admin_api_reqs_per_minute = ‘600’
.bashrc é como seu .zhrc
modificar as entradas de developer_emails ou db_password funciona (o e-mail correto é exibido na página de registro de administrador do site), mas outros parâmetros smtp são ignorados.
Seu arquivo config/puma.rb contém alguns erros (por volta da linha com a porta 3000). Você poderia fornecê-lo novamente?
Eu registrei o admin com rails c e depois disso recebo a página “Oops…” na página inicial. Nenhuma página é renderizada corretamente.
Por favor, me ajude.
@lion , tente este:\n\n```
require “fileutils”
discourse_path = File.expand_path(File.expand_path(File.dirname(FILE)) + “/../”)
enable_logstash_logger = ENV[“ENABLE_LOGSTASH_LOGGER”] == “1”
puma_stderr_path = “#{discourse_path}/log/puma.stderr.log”
puma_stdout_path = “#{discourse_path}/log/puma.stdout.log”
Carrega o logger logstash se habilitado
require_relative “../lib/discourse_logstash_logger”
Nota: Você pode precisar adaptar a inicialização do logger para o Puma
log_formatter = proc do |severity, time, progname, msg|
event = {
@timestamp” => Time.now.utc,
“message” => msg,
“severity” => severity,
“type” => “puma”
“#{event.to_json}\n”
else
Número de workers (processos)
workers ENV.fetch(“PUMA_WORKERS”, 8).to_i
Define o diretório
Vincula ao endereço e porta especificados
bind ENV.fetch(“PUMA_BIND”, “tcp://#{ENV[‘PUMA_BIND_ALL’] ? ‘’ : ‘127.0.0.1:’}3000”)
Localização do arquivo PID
FileUtils.mkdir_p(“#{discourse_path}/tmp/pids”)
pidfile ENV.fetch(“PUMA_PID_PATH”, “#{discourse_path}/tmp/pids/puma.pid”)
Arquivo de estado - usado pelo pumactl
state_path “#{discourse_path}/tmp/pids/puma.state”
Configuração específica do ambiente
if ENV[“RAILS_ENV”] == “production”
Timeout de produção
worker_timeout 30
else
Timeout de desenvolvimento
worker_timeout ENV.fetch(“PUMA_TIMEOUT”, 60).to_i
Pré-carrega a aplicação
preload_app!
Lida com a inicialização e o desligamento do worker
before_fork do
Verificação do supervisor
supervisor_pid = ENV[“PUMA_SUPERVISOR_PID”].to_i
Thread.new do
loop do
unless File.exist?(“/proc/#{supervisor_pid}”)
puts “Kill self supervisor is gone”
Process.kill “TERM”, Process.pid
sleep 2
Workers Sidekiq
sidekiqs = ENV[“PUMA_SIDEKIQS”].to_i
if sidekiqs > 0
puts “starting #{sidekiqs} supervised sidekiqs”
    # Atraso na reabertura do log do Sidekiq
    sleep 1
Demon de sincronização de e-mail
if ENV[“DISCOURSE_ENABLE_EMAIL_SYNC_DEMON”] == “true”
puts “starting up EmailSync demon”
Demônios de plugins
puts “starting #{demon_class.prefix} demon”
Thread de monitoramento de demônios
Thread.new do
loop do
begin
sleep 60
    if sidekiqs > 0
  rescue => e
    Rails.logger.warn("Error in demon processes heartbeat check: #{e}\n#{e.backtrace.join("\n")}")
Fecha a conexão Redis
on_worker_boot do
Tratamento de timeout do worker
worker_timeout 30
Opções de worker de baixo nível
threads 8, 32
Obrigado. Esqueci de dizer que está atrás do haproxy para vários servidores.
  1. Recebo “mix content” do console do navegador. O que posso mudar no arquivo nginx?
  2. Recebo este log sobre magick na inicialização do comando puma. Ele também está instalado no início.
/var/www/discourse/log/puma.stderr.log
=== inicialização do puma: 2025-09-19 01:40:45 +0200 ===
OID desconhecido 16720: falha ao reconhecer o tipo de ‘embeddings’. Ele será tratado como String.
#<Thread:0x00007fc59a2f5a78 /var/www/discourse/lib/discourse.rb:1190 run> terminou com exceção (report_on_exception é true):
/var/www/discourse/lib/letter_avatar.rb:112:in ``‘: No such file or directory - magick (Errno::ENOENT)
from /var/www/discourse/lib/letter_avatar.rb:112:in image_magick_version' from /var/www/discourse/lib/discourse.rb:1190:in block in preload_rails!’
Li que isso pode ser uma causa para as páginas não serem exibidas.
Você força o SSL nas configurações do Discourse?
Você pode executar magick --version como usuário discourse? Para mim, a saída é:
Version: ImageMagick 7.1.1-45 Q16-HDRI x86_64 3cbce5696:20250308 https://imagemagick.org
Copyright: (C) 1999 ImageMagick Studio LLC
License: ImageMagick | License
Features: Cipher DPC HDRI Modules OpenMP(4.5)
Delegates (built-in): bzlib cairo djvu fftw fontconfig freetype gslib gvc heic jbig jng jp2 jpeg jxl lcms lqr ltdl lzma openexr pangocairo png ps raqm raw rsvg tiff webp wmf x xml zip zlib zstd
Compiler: gcc (13.3)
Sim, exatamente o que eu estava pensando.
Encontrei muitas dependências não atendidas durante a instalação “manual”. Estou escrevendo um Ansible para poder implantar o Discourse em múltiplos ambientes.
Meus sistemas são almalinux/redhat, mas compartilharei o que encontrei quando considerar que está quase pronto.
1 curtida
Em haproxy.cfg, a porta 443 é com crt, portanto criptografada, redirecionada para o contêiner através da porta 8080:
backend BACKEND_XXX
option forwardfor
http-request set-header X-Forwarded-Port %[dst_port]
http-request add-header X-Forwarded-Proto https if { ssl_fc }
server xxx 192.168.1.48:8080 weight 1 #adicionando “check ssl verify none” se ssl no nginx discourse
  1. Em nginx/…/discourse.conf, copiei a versão desta postagem e modifiquei a porta, o servername e a localização dos arquivos de certificado.
    => PB1: obtive conteúdos misturados e logs com o mesmo problema do magick
    => PB2: na página “/confirm-email”, recebo um erro “site não encontrado” do navegador.
  2. Em seguida, modifiquei o arquivo removendo o ssl na porta e comentei todas as linhas com “$thescheme”, para criptografar apenas no haproxy.
    => Erro 502 na primeira página, mesmos logs com magick
  3. Em seguida, instalei o magick a partir do código fonte (7.1.2.3), adicionei a pasta de binários ao PATH em .bashrc para os usuários root e discourse. Não funcionou via apt install (sem efeito como este).
    => O erro 502 desapareceu, ainda com conteúdo misturado e “site não encontrado” do navegador.
    => Logs ainda indicam magick não encontrado, mas de forma diferente.
==> /var/www/discourse/log/puma.stderr.log <==
=== puma startup: 2025-09-19 12:06:05 +0200 ===
OID desconhecido 16720: falha ao reconhecer o tipo de ‘embeddings’. Será tratado como String.
#<Thread:0x00007f611a21c0f0 /var/www/discourse/lib/discourse.rb:1190 run> terminou com exceção (report_on_exception é true):
==> /var/www/discourse/log/puma.stdout.log <==
[8967] AVISO hook before_fork falhou com exceção (Errno::ENOENT) No such file or directory - magick
Conclusão:
Como tornar o magick encontrável pelo puma?
Como desativar o ssl no nginx por causa do haproxy?
Consegui fazer funcionar como descrito na minha primeira postagem, mas aqui sem SSL no Nginx, copiando o nginx.config.sample com apenas a alteração do nome do host e da porta.
Portanto, tanto com SSL quanto sem SSL no Nginx, eu chego à primeira página para registro de administrador até a página de reenvio de e-mail, mas AMBOS:
  1. exibem “conteúdo misto” (para arquivos de imagem, por exemplo),
  2. outras páginas além do registro de administrador mostram “Oops…”
  3. nenhum e-mail de confirmação é enviado
  4. o Magick ainda não é encontrado
Em algum lugar em uma de suas postagens você menciona contêiner.
Você está usando contêineres para alguma das partes envolvidas?
Hoje quero finalizar minha implantação no ambiente de pré-produção e talvez eu tenha mais informações para compartilhar.
O mesmo que você :unamused_face:
  • Não envia e-mail de confirmação (estou usando o mailtrap, tenho certeza que funciona).
  • Criou usuário administrador com rake
  • Ops em / depois disso…
  • Também vi o problema do magick e o magick está instalado (tenho certeza que falta algum rubygem…)
Estou implantando usando docker e depois comparando. Eu odeio docker :expressionless_face: mas vou perder muito tempo precioso…
Eu mal conheço o Docker (se é que conheço!) e não precisei dele para executar um fórum Discourse em produção. Basta seguir as instruções suportadas, que ele lhe dará o que você precisa.
Sim, acredito em você. Mas preciso saber o que estou implantando e como funciona.
É a melhor maneira de encontrar e resolver problemas :squinting_face_with_tongue:
Porque você terá problemas, sempre, talvez não agora, mas tenho certeza de que o futuro você encontrará alguém.
De qualquer forma, como não terei suporte usando um método de instalação alternativo, seguirei as instruções oficiais e tentarei ajudar os outros :winking_face_with_tongue:
Eu também gastei muito tempo nesses problemas.
Sobre o Docker, veja este problema no Docker (um erro ou um backdoor ?..), corrigido no momento: https://youtu.be/dTqxNc1MVLE
Essa é uma das minhas razões para não usar o Docker.
Estou usando contêineres lxd (lxc) e me sinto bem com isso. Vou instalar o Docker em um contêiner lxc primeiro e exportar o banco de dados depois, quando a instalação sem Docker em um lxc for possível.
Bem, eu não estou forçando o Discourse a usar SSL porque quero que meu haproxy faça isso, pois o passthrough do haproxy não funciona com o protocolo HTTP para redirecionar requisições GET, e eu estou gerenciando múltiplos websites, então preciso do protocolo HTTP no haproxy, o que requer o tratamento de SSL no lado do haproxy. Eu gostaria de evitar um gateway SSL duplo.
Então o haproxy (em um lxc) escuta na porta 443: redireciona para 8080 (sem SSL) para o meu container Discourse (lxc).
Curiosamente, o nginx-config-sample fornecido na pasta do Discourse está configurado sem SSL e na porta 80, então deveria funcionar bem, mas estou tendo os problemas mencionados acima.
Você precisa fazer isso para dizer ao Discourse para enviar apenas links HTTPS. Não está mudando os redirecionamentos, mas a necessidade deles.
Você precisa ativar a configuração de forçar HTTPS.
HTTPS: Sim, mas por favor, diga-me como ativá-lo?
ÓTIMAS NOTÍCIAS! RESOLVI OS PROBLEMAS!!! A origem foi o programa magick. Após a instalação correta do magick a partir da versão 7 da fonte (não instale o imagemagick com apt, é a versão 6), meu site discourse exibe todas as páginas corretamente! E-mails, registro de administrador, etc. funcionam! Após a resolução do problema de "conteúdo misto", publicarei meu script para instalação em um container lxd-lxc (Debian 12) atrás do haproxy. em outro container lxd-lxc.
1 curtida
