Users list has gone missing
I just upgraded to:
a22deb520b)
from
4cb4a5912d49f
and now the users list is missing from my site:
https://forum.example.org/admin/users/list/active
However I am able to see all my users through:
https://forum.example.org/admin/groups
Is this by design?
I would assume active users means all of my users. The search functionality from the groups menu is only by user or email.
As luck would have it, I’ve just updated my site just now (version 8f89e287d3)
I can’t repro this. Visiting my /admin/users/list/active displays the user list as expected.
Does this also happen in safe mode for you? (Or possibly a fresh update just in case something was recently fixed)
Thanks, safe-mode didn’t help. I can’t see the new versions on the update page, so I will login to the server and rebuild. This commit looks interesting:
https://github.com/discourse/discourse/commit/f82249599ac52e49814c54f723397eed4de01fdc
Are there errors in the browser console or in /logs?
Updating to 9ebce86fd fixed the issue. Thanks everyone for their help.
This is the second recent upgrade that has resulted in issues, and it appears that it is not easy to get on a more stable release without timing it properly with the other branches.
I’m glad that sorted it. :partying_face:
The major releases (aka stable) are usually slotted in for around the end of January and the end of July each year. So if you do want to switch tracks your next opportunity would be in a couple of months. :spiral_calendar:
Though generally the default tests-passed is reasonably stable and any significant issues that crop up are normally fixed pretty rapidly. It is unfortunate that you’ve been bit twice in a few weeks, but hopefully this isn’t something that becomes a pattern for you. :crossed_fingers:
@JammyDodger, thanks for your help. This is a great software, and I am grateful for it to be available to self-hosters to build their community.
