Who can help me? Thanks! Is anyone willing to help me solve an email issue?
我已经安装好discourse了,但是邮件问题一直没有解决,求帮助
There are a few threads about it, and it’s very straightforward, but you need to understand the basics (and write in English if possible).
That’s the Discourse AI reply for your question:
Okey
This is my app.yml
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
  - "templates/web.ssl.template.yml"
  - "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for dhttps://forum.snwiki.org.cn/tails
expose:
  - "80:80"   # http
  - "443:443" # https
params:
  db_shared_buffers: "128MB"
  #db_work_mem: "40MB"
  #version: tests-passed
env:
  LC_ALL: en_US.UTF-8
  LANG: en_US.UTF-8
  LANGUAGE: en_US.UTF-8
  UNICORN_WORKERS: 2
  ## Required. Discourse will not work with a bare IP number.
  DISCOURSE_HOSTNAME: forum.snwiki.org.cn
  ## Uncomment if you want the container to be started with the same
  ## hostname (-h option) as specified above (default "$hostname-$config")
  #DOCKER_USE_HOSTNAME: true
  DISCOURSE_DEVELOPER_EMAILS: 'admin@snwiki.org.cn'
  ## TODO: The SMTP mail server used to validate new accounts and send notifications
  # SMTP ADDRESS is required
  # WARNING: SMTP password should be wrapped in quotes to avoid problems
  DISCOURSE_SMTP_ADDRESS: smtp.163.com
  DISCOURSE_SMTP_PORT: 465
  DISCOURSE_SMTP_USER_NAME: teenweb_server@163.com
  DISCOURSE_SMTP_PASSWORD: "*********"
  #DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default: true)
  DISCOURSE_SMTP_DOMAIN: discourse.example.com # (required by some providers)
  DISCOURSE_NOTIFICATION_EMAIL: noreply@snwiki.org.cn
  #DISCOURSE_SMTP_OPENSSL_VERIFY_MODE: peer        # (optional, default: peer, valid values: none, peer, client_once, fail_if_no_peer_cert)
  #DISCOURSE_SMTP_AUTHENTICATION: plain            # (default: plain, valid values: plain, login, cram_md5)
  ## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
  LETSENCRYPT_ACCOUNT_EMAIL: server@snwiki.org.cn
  ## The http or https CDN address for this Discourse instance (configured to pull)
  ## see https://meta.discourse.org/t/14857 for details
  ## The maxmind geolocation IP account ID and license key for IP address lookups
  ## see https://meta.discourse.org/t/-/173941 for details
  #DISCOURSE_MAXMIND_ACCOUNT_ID: 123456
  #DISCOURSE_MAXMIND_LICENSE_KEY: 1234567890123456
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
run:
Does changing to port 80 or 2525 help?
Did you read the treads I posted before? Like this one:
