Dialoogvenster dat verschijnt na het activeren van de '9 links'-besturing op bericht nummer 1 is niet toegankelijk via het toetsenbord
Title: Dialog box which appears after activating the ‘9 links’ control present at post number 1 is not accessible through keyboard, i.e., focus is not moving inside the dialog box.
Windows Test Environment:
OS: Windows 11 Enterprise Insider Preview Version 24H2 (OS Build 26100.3775)
Browser Microsoft Edge Version 135.0.3179.85 (Official build) (64-bit)
URL: 3.8 Tier List by Infil - General Discussion - Killer Instinct Forums
User Impact:
Keyboard dependent users will be impacted if dialog box which appears after activating the ‘9 links’ control present at post number 1 is not accessible through keyboard due to which users will not get the information of the controls present inside the dialog box.
Steps to Reproduce:
  1. Open the given URL: 3.8 Tier List by Infil - General Discussion - Killer Instinct Forums in latest edge browser.
  2. Press tab key to reach ‘9 links’ control present at post number 1 and press Enter key to activate it.
  3. Press tab key to navigate through the dialog which appears on screen.
  4. Verify using tab key whether dialog box which appears after activating the ‘9 links’ control present at post number 1 is accessible through keyboard or not.
Actual Result:
Dialog box which appears after activating the ‘9 links’ control present at post number 1 is not accessible through keyboard, i.e., focus is not moving inside the dialog box. keyboard stays on ‘9links’ control.
Refer Attachment:
1.Dialog box which appears after activating the 9 links control present at post number 1 is not accessible through keyboard, i.e., focus is not moving inside the dialog box.png
2.Dialog box which appears after activating the 9 links control present at post number 1 is not accessible through keyboard, i.e., focus is not moving inside the dialog box.mp4
Expected Result:
Dialog box which appears after activating the ‘9 links’ control present at post number 1 should be accessible through keyboard, i.e., focus should move inside the dialog box and screen reader should properly announce the information present inside the dialog box.
Other instance:
  1. Same issue replicate as dialog box which appears after activating the ‘32.7k views’ control is not accessible through keyboard.
Thanks for reporting this, we have a fix that has recently been merged and will be available the next time Discourse is updated on that site.
I also noticed that there’s a minor theme issue on the Killer Instinct site that makes the header title difficult to read:
This can be fixed with a minor theme adjustment, like
.d-header {
  background: var(--secondary);
(we don’t manage this site’s theme directly, so it’s not a fix we can apply ourselves)
Dit onderwerp werd automatisch gesloten na 3 dagen. Nieuwe reacties zijn niet meer toegestaan.
