Engineering a persona to lean on chat history
jrgong seeks advice on efficiently using Slack chat history logs for an AI persona, considering cost and effectiveness. They present two options: directly copying logs into Discourse or pre-processing them. sam recommends processing the logs with a ‘Creative’ persona using a large context LLM like Sonnet 4, then uploading the processed files to a persona for RAG search. They advise against stuffing the system prompt with too much data, suggesting a 10k token limit for system prompts to keep costs manageable. jrgong clarifies the embedding process and token limits, and sam explains that uploaded files are processed via embedding and chunked, with relevant chunks injected into the prompt. jrgong confirms their next steps and sam emphasizes experimenting with different embedding models to improve results. jrgong expresses appreciation and offers to share their progress. Later, jrgong asks about adding version or model numbers to metadata separators, and sam confirms that using the same format for humans is acceptable.
Quick question what would be a “better” structure for our use case:
We have a bunch of exported chat history logs from Slack Channels which contains a lot of know-how, mentioned problems and solutions, etc. Obviously those chats contain a lot of useless “fluff” that would unecomical to just dump into topics/posts and have the AI bot use that.
We have about 10 files each approx 1-2MB in size. In terms of AI persona usage, we will have only about 30 people doing about 10 chats per day (hard to estimate token volume here)
At this point I am wondering what a somewhat reasonable 80/20 approach would be how to make use of those chat logs while keeping it somewhat economical. It came down to 2 options:
  1. Copy and paste the logs into Discourse topics/post: Quick’n’dirty, no custom development required, could end up in a lot of API cost
  2. Somehow pre-process the chat logs and put them into a proper format or structure and upload to persona
  3. Or maybe some form of hybrid: With each AI bot request, evaluate and save the output as txt file and then upload it to the persona
Which option do you guys recommend? Or maybe something completely different?
I would recommend the following approach:
  1. Process the 10 files using a “Creative” persona using a large context / large output LLM like Sonnet 4 thinking. The goal of this processing would be to “tidy” up the information and prepare it for a RAG
  2. Then using our built in upload, upload the 10 processed files to a persona, so RAG can search through the content.
Given there is tons of data here I recommend against stuffing a system prompt. As a guideline a system prompt should not be super long, it becomes costly. 10k tokens is workable, 100k tokens is not workable with current frontier LLMs. Every interaction will cost you too much and the LLMs would get extra confused.
Let us know how you go!
Please share the prompts you used to shrink / tidy the chat logs.
Thx, that helps!
Just to clarify, are all the uploaded files injected into the system prompt? Or are they processed through the configured ai_embeddings_model first and then injected?
I am a bit confused about your recommended 10k token limit recommendation especially with the part below:
The files in Discourse AI Persona, upload support are only limited by your upload size, they can be huge, they are processed via embedding, we inject chunks into the prompt per configuration.
What I was talking about was trying to coerce all the information into a single system prompt here:
that is limited…
Ah, that clears is it up, thanks!
So basically, my next steps should be to run a few tests with different embeddings models and see what token size I end up injected into the system prompt, right?
And when creating those txt files with chunks, I should make sure that they stay within a reasonable 10k-ish limit?
The embedding model controls quality, not quantity
you can roll up all your data into a single file, we will chunk it in the background and retrieve the most relevant chunks and add the to your prompt
experimenting here would be about improving results, some cleanup may work better than others clean ups some embedding models will be smarter at finding more relevant pieces
Thx sam, I really appreciate it :heart:
If you have any further helpful resources, feel free to share them here. Once I make progress, I will try and publish my experience here on meta. :slight_smile:
@sam how do you suggest adding version or model numbers to metadata separators?
Your original example:
[[metadata about cats]]
a long story about cats
[[metadata about dogs]]
a long story about dogs
Now if we want to enrich them with version numbers or specific model numbers, do I just use the same format or structure that humans would use when typing them?
E.g.:
[[metadata about cats v1.0]]
[[metadata about cats xxl v2.1]]
[[metadata about dogs v 1.1beta]]
Also, when version numbers are missing in metadata (see metadata about dogs), would that chunk be used in a response for all dog-related requests, no matter which “dog version”?
Yes, this is the way to go!
