Log back in as admin after locking yourself out with read-only mode or an invalid SSO configuration
:bookmark: This guide explains how to log back into Discourse as an admin when you have been locked out.
:person_raising_hand: Required user level: Administrator
If you’ve locked yourself out of your Discourse instance with an invalid SSO configuration, append /u/admin-login to the end of your forum’s root URL:
https://discourse.example.com/u/admin-login
This will take you to an admin login page:
You’ll be sent an email with a login link that circumvents SSO and read-only mode, allowing you to login as needed.
:information_source: If you have 2-factor authentication enabled you’ll still have to enter your auth code.
Alternative method requiring console access
Disable SSO
cd /var/discourse
./launcher enter app
rails c
irb > SiteSetting.enable_discourse_connect = false
irb > SiteSetting.enable_local_logins = true
irb > exit
exit
Disable read-only mode
cd /var/discourse
rails c
irb > Discourse.disable_readonly_mode(Discourse::USER_READONLY_MODE_KEY)
irb > exit
exit
Last checked by @hugh 2024-07-30T05:41:34Z
Hi, I can’t access to my forum.
I have enabled read-only mode but now I can’t access to admin.
When I go to “/u/admin-login” and I insert my admin email, I receive this error:
{“errors”:[“The site is in read only mode. Interactions are disabled.”],“error_type”:“read_only”}
And also via console access it doesn’t work :slightly_frowning_face:
How can I resolve?
Thank you in advance
I think you can run this in the rails console to turn it off:
Does it? When I enter my email and click Send email, I see:
And no email is sent.
Thanks for the report @Moin, that should fix it (once and for all :crossed_fingers:)
