Users report a persistent issue where, after replying to a topic and immediately returning to the topics list, a notification appears indicating “1 new or updated topic”—even though no actual unread content exists. This occurs consistently across multiple Discourse versions and is reproducible when closing a topic and returning to the list. While some users consider it a minor annoyance or working as designed, others find it confusing, especially when using keyboard shortcuts to return to the list. The issue appears to be related to timing and caching, with suggestions that the system incorrectly flags a topic as updated after a reply. Some users suspect it may be linked to server load or race conditions, though it’s not consistently reproducible. Despite being discussed for years, the problem remains unresolved, with developers acknowledging it’s tricky to fix due to maintaining scroll position and cache behavior. Chili first reported the issue, and others like watchmanmonitor, kensims, and Geoffrey_Challen confirm it, noting it’s a common workflow for frequent contributors.
I apologise if this has been covered before, I’ve looked but I have not seen this talked about. It has been happening since as long as I can remember.
Read to bottom of topic
Type a reply and as soon as you finish and click “Reply” immediately return to the main list of topics.
The user is given the notification that there is a new/updated topic at the top.
When user clicks that item the the topic list is refreshed but there are no new notifications next to any topic.
(also works when submitting a new topic)
I am using Chrome, and we are on the latest version of Discourse 1.4b3 (although it has happened consistently through several versions). As such I’m not sure it classifies as a “bug” but it can be confusing to users.
I’ve seen that more than I would like to in the past few months. This is even easier to reproduce when you close a topic and then go back to the topics list. The automated message that is posted on your behalf should not generate a notification.
I think it is worth fixing, but its a bit tricky to fix, after you reply we got to poison the “back” cache. But then … the issue is that we still got to maintain scroll position, so its tricky .. cc @eviltrout
I see it all the time because I open the topic in another tab. After I’ve posted a reply and closed the tab so that I’m back at the list, there’s the notification.
While it may be confusing, I consider it to be WAD (Working As Designed).
I do, every time. I answer a lot of topics, so the typical workflow is to enter a topic, read to the end, write and post a reply, hit the logo in the top left to go back to the topic list. Then get the “1 new or updated”, every time.
Aaaand just like that, I saw the flash here on meta after my last post. I don’t think I did anything different than what I’ve done in the past, but sure enough, I flashed myself.
Succede a volte con Hub/iPad, forse ogni decima volta che scrivo qui. Ma dato che non sono molto attivo non ho reagito, tanto scompare dopo un po’.
Tuttavia… l’ho riscontrato solo qui. Non nella mia configurazione personale, né su altri forum dove faccio più che leggere passivamente. Quindi la mia ipotesi, molto poco informata, è che sia correlato al carico, all’ora di punta o a qualsiasi altra cosa che accade quando troppe cose succedono contemporaneamente. Oppure succede e basta
C’è anche la possibilità che io stia parlando di un incidente simile, ma totalmente diverso, rispetto a tutti gli altri.
