Personalizando Discobot para tu sitio
:bookmark: This guide explains how to customize Discobot, the built-in assistant bot in Discourse, to better match your community’s persona and needs.
:person_raising_hand: Required user level: Administrator
Discobot is a special user in your Discourse community that helps new members learn about the platform. As an administrator, you can customize various aspects of Discobot to better fit your community’s style and requirements.
Modifying Discobot’s user profile
To customize Discobot’s profile:
  1. Go to Admin > Users and select the Discobot user.
  2. Select “Preferences” or click “Visit this user’s preferences page to edit their profile”:
Once in the Preferences section, you can modify the following settings:
Account settings
  • Name: Click the “Edit” button to change Discobot’s name.
  • Image: Click the “Edit” button to upload a new avatar image.
  • After making changes, click the “Save Changes” button.
Profile settings
Customize Discobot’s profile information as needed.
Email settings
Adjust email-related settings as needed.
Updating Discobot’s welcome message
To change the welcome message sent by Discobot:
  1. Go to Discobot’s profile (https://example.discourse.com/u/discobot/summary) and select “Messages”.
  2. Click on “Sent”.
  3. Find a greeting message that you want to modify.
  4. Copy a unique part of the message, such as “I’m only a robot”.
  5. Navigate to the Admin Interface (https://example.discourse.com/admin)
  6. Go to Appearance > Site Texts (https://example.discourse.com/admin/customize/site_texts)
  7. Paste the copied text into the search window. When the greeting message appears, click “Edit”.
  8. Update the greeting message and click “Save Changes”.
Limitations and additional information
  • You can reuse existing variables in messages (like %{title}), but you cannot add new ones.
  • Discobot must remain an administrator; this role cannot be removed.
For further customization needs or feature requests, consider posting in the Feature category.
38 Me gusta
Is it possible to make a new conversation discobot with With members and make a new certificate for them ?
I am admin to an educational forum and I want to make a new conversation with a new certificate :slight_smile:
3 Me gusta
No, you cannot currently customise the full experience.
3 Me gusta
Is it possible to know the codes for messages such as %{title}
Excuse me for my many questions :slight_smile:
Questions are fine. :slight_smile:
You can reuse any existing variables in the message but you cannot add new ones.
5 Me gusta
many thanks @HAWK
Is it possible to define the existing variables if possible? :slight_smile:
1 me gusta
I suggest adding that either
  1. People need to update the Discobot’s profile About me because it’ll still say message or mention @discobot even after you change its name
or
  1. Maybe Discourse could remove the username from the default message? I went ahead and edited our About me to just say
Hi, I’m not a real person. I’m a bot that can teach you about this site. To interact with me, send me a message or mention me anywhere.
Just in case we have to change it again, we don’t need to remember to also change the About me.
4 Me gusta
Is this something that’s going to be possible in the future? The current question/answer format of fortune and quote is sufficient for what I have in mind.
1 me gusta
@codinghorror is extending the discobot functionality on our roadmap at all?
2 Me gusta
That’s a good point we should make that copyedit, @tshenry can you take it? No need to deal with it retroactively just for new ones. Say “mention me by name” so editing the name doesn’t require editing the “about me”.
@hawk we don’t plan on extending discobot at the moment.
7 Me gusta
Should be done with the following!
https://github.com/discourse/discourse/pull/11820
8 Me gusta
Does Discobot have to be a Moderator or can I take this role away from him? I mean, will he still work then?
2 Me gusta
As far as I can tell from looking at the code and the UI, Discobot should never be able to become a moderator.
If you meant an admin, then no, unfortunately there is no way to take the admin role away from DIscobot at this time.
7 Me gusta
Gracias por responder. Desde las últimas publicaciones, ¿es posible personalizar el entrenamiento de usuarios de Discobot y el entrenamiento de usuarios avanzados o sigue siendo estándar? Recibimos mucho tráfico de búsqueda con la palabra “capybara”, pero quizás nos gustaría probar otro término.
1 me gusta
En realidad, creo que lo que estoy mencionando podría estar aquí: Customizing Discobot for your site - #7
2 Me gusta
¿Hay alguna forma en que un administrador pueda activar o desactivar una parte particular del tutorial?
Por ejemplo, el tutorial de la Bandera requiere que el usuario seleccione la Bandera “Inapropiada”. Esta Bandera está oculta en nuestra instancia porque no se adapta a nuestro caso de uso. En consecuencia, nuestros usuarios no pueden completar el Tutorial. Si pudiera simplemente deshabilitar/omitir esta sección, podríamos volver a habilitar el tutorial.
2 Me gusta
Podrías cambiar las instrucciones del paso, de forma similar a como se puede omitir dar “me gusta” a una publicación cuando los “me gusta” están deshabilitados. Deshabilitar “me gusta” - actualizar el tutorial de discobot
3 Me gusta
No puedes eliminar ni añadir pasos, pero puedes personalizar el contenido del cuerpo de los pasos existentes (pero no los desencadenantes).
4 Me gusta
Me encantaría atender esto y entrenarlo para responder preguntas relacionadas con el tema principal del foro utilizando LM / chatgpt, etc… ¿es posible?
Es mejor crear tu propia IA/bot en lugar de intentar personalizar discobot.
1 me gusta
