Topic Status Filter
:discourse2: Summary Topic Status Filter will filter topics by their “open” or “closed” status.
:eyeglasses: Preview Preview on Discourse Theme Creator
:hammer_and_wrench: Repository Link https://github.com/discourse/discourse-topic-status-filter
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme component
Features
This theme component will help you to filter the topics by their status “open” or “closed”. It will add a dropdown filter next to the existing categories and tags dropdown. You can limit this component to particular categories using the theme setting enabled categories, else it will be displayed in all categories.
Settings
Name Description
enabled categories
Translation Default
topic_status_filter.all all
topic_status_filter.open open
topic_status_filter.closed closed
:discourse2: Hosted by us? Theme components are available to use on our Standard, Business, and Enterprise plans.
29개의 좋아요
Love it! Thanks!
It’s a real live-saver. We use Discourse as an internal project and taskmanagement system.
11개의 좋아요
Very cool, I hate to gift you the gift of work but I wonder would you be able to do a post on meta explaining how you are using Discourse internally, what is working well for you and what needs help? We may be able to give you more ideas to help with your workflow!
15개의 좋아요
Reply here:
Seems like it merited a new topic.
11개의 좋아요
Can we filter group tags theme component?
Discourse already having the tags filter. What do you mean by group tags theme component? And what is the use case?
2개의 좋아요
I think he means so the ‘open’ ‘closed’ component would work in tag-pages and tag-intersections. I second that, its something i’d love to put in our forum.
We currently just add the tag ‘backlog’ ‘sprint’ ‘doing’ or ‘done’ to show the status of a topic.
1개의 좋아요
Would it be possible to extend this to tags as well, not just categories?
It would also be really cool to have an option as to which filter should be selected by default.
You can select tag in the tagl ist
1개의 좋아요
But when I enter via the tag, I don’t have the choice.
Just to be sure, does this component keeps the filter state of ‘open’ even if the page is reloaded/closed?
저녁입니다. 카테고리에 들어갔을 때 기본적으로 열려 있는 주제만 보이도록 설정할 수 있는 방법이 있을까요?
1개의 좋아요
