겨울 눈 테마 컴포넌트 ❄️
This theme component adds some animated snow to your forum.
:christmas_tree: Warning: the animations will increase browser CPU usage :santa:
:eye: Demo
:link: Repository
Javascript mode (shared by @cjk77 here):
CSS Mode (adapted from here)
37개의 좋아요
Thanks - now with snow :smiley:
Installation:
Go to: /admin/customize/themes
Choose Compontes - add Install.
Paste in the link: https://github.com/davidtaylorhq/discourse-snow-theme.git
Go back to admin/customize/themes and find your theme.
Click it and you can customize your theme.
Scroll down
Add the new component to your theme.
And your have :snowflake:
10개의 좋아요
I’ve got a couple of users using Firefox and Opera where this isn’t working (configured with js-mode), but the codepen example of the code does work. Works fine in Chrome. Any ideas?
ETA: Both users have confirmed that css mode works for them
1개의 좋아요
It seems to be a Chrome-only component. On Firefox, with JS-mode, there’s nothing, and with CSS mode there’s a wall of jerky snow flakes that covers the screen, so it’s not really usable.
3개의 좋아요
It is now updated so that js-mode works for Firefox. I haven’t tested Opera, but I suspect the same fix will help there as well.
14개의 좋아요
Can confirm it’s now working for both of my users, Firefox and Opera. Thanks for the fix.
5개의 좋아요
I use Opera,
looked great but as David noted
the CPU is too much,
1% without up to 39% with,
Sadly had to go :pensive:
6개의 좋아요
is there a way to make this have random fireworks instead of snow?
and my CPU never increased with the snow, used it on desktops and phones, my entire forum loved it, and not one complaint about CPU usage
10개의 좋아요
Hi! I love this, it’s adorable and really brings things to life. I’m wondering, however, if it’s possible to make it appear only to the right and left/in the unused space beside the board (or go behind it)? That way it doesn’t snow all over the text and make reading difficult.
4개의 좋아요
Seems to work fine with the latest discourse release…
2개의 좋아요
Pretty love this theme component, but is there a way that change the “point” (or should I say “dot”?) to real snow icon?
1개의 좋아요
Is there a way to slow the snow down more so it is not so distracting? Kind of a lazy snow? or a way for users to turn off the snow themselves so some can enjoy it while the others for whom it causes problems can turn it off?
1개의 좋아요
Are you using the CSS or JS version?
switched from JS to CSS! But we can try either, whichever is easier. @famousamos.1 FYI
3개의 좋아요
@dennisjbr on it for me - I should have asked him first, but my list of things to be done is huge. He helps us with our site.
3개의 좋아요
The CSS version is easier to change, but that’s not the same effect. :thinking:
If you are okay with the CSS version and want to slow down the fall, add this CSS to your theme or a new theme component and adjust the value to your needs. The higher the value, the slower.
#snow {
    animation: snow 60s linear infinite;
6개의 좋아요
Thank you so much
3개의 좋아요
사이트에 다시 눈이 왔어요 :slight_smile:
동작은 하지만 이 오류가 발생합니다
@frold 님, 보고해 주셔서 감사합니다. 방금 수정 사항을 적용하여 테마 컴포넌트를 업데이트하시면 해결될 것입니다.
참고로, whos-online 오류도 이미 수정되었을 가능성이 높습니다. 해당 플러그인의 최신 버전을 사용 중이신가요?
1개의 좋아요
이 기능을 정말 좋아하지만, 사용자 불만이 나오고 있어요. 사용자가 직접 비활성화할 수 있는 옵션이 있으면 좋겠어요.
