Автоматически пере categorизировать темы из импортированного форума, ориентируясь на ключевые слова в заголовках?
Hi,
I’m importing an old and large forum about unicycling.
The old categories weren’t the best, and a lot of different stuff was mixed together.
So, I’m re-organizing categories.
At first, I was thinking to manually re-categorize the most recent few hundred of topics, and keep the old ones as they are.
The idea would be to aim at the future, not at the past. Doesn’t matter that much if old topics are badly categorized, the most important is that they are still available.
But I’m wondering if re-categorize topics automatically by targeting keywords could do, in fact, a good job.
Currently, the vast majority of our topics -more than half of the total!- are in a single category (:scream:).
I could target these keywords in the titles: “learn”, “learning”, “train”, “training”, “posture”, etc… And put all these topics in a category #riding-advice.
The same could go with “frame”, “wheel”, “tire”, “saddle”, etc… That would go in #unicycles-and-equipments.
I’ll target words wrapped by spaces and try to anticipate multiple words expressions and prevent a bit of “false positives”. Example: “wheelwalking” is a unicycle trick that should probably be found in #riding-advice, so if I target only “wheel” without thinking much, there will be false positives that could have been easily avoided (that said, I could move topics with “wheel” from A to B, and then move topics with “wheelwalking” from B to C…).
Did some people here do such a thing? Do you have suggestions or ideas to minimize the risk of “false positives”? Are there obvious (or not) things that I need to know before doing this?
About 70000 topics must be looked at.
2 лайка
One bit of advise, do not view this as having to be done right the first time.
Your idea of seeking keywords is the same first approach I would take. Do not be afraid to throw out all of the work you did in your first attempt. If the result is not what you seek take what you learned by doing the first attempt and start over from scratch.
EDIT
In doing quick search for some free tools to do word analysis found this information page on Text Analysis. Nice read.
3 лайка
I have previously approached similar projects by using unsupervised learning using K-means clustering. That would be a pretty cool experiment and maybe the algorithm even comes up with a better categorization :wink:
You can read about such an approach here https://towardsdatascience.com/applying-machine-learning-to-classify-an-unsupervised-text-document-e7bb6265f52
Just like @EricGT said: don’t be afraid to iterate, but close enough is close enough, and maybe have some TL3 users ready to re-categorize where necessary.
7 лайков
That’s interesting!
I probably won’t have the time nor the skills to try this approach though (the forum has been down for more than a month, and I still have a lot of work to do!).
After a first try, manually choosing keywords seems to have fairly good results, though I didn’t re-categorized yet and just played with SQL queries.
select title from topics
where category_id = 10
and lower(title) not like '%saddle%'
and lower(title) not like '%crank%'
and lower(title) not like '%pedal%'
and lower(title) not like '%rim%'
and lower(title) not like '%carbon%'
and lower(title) not like '%spoke%'
and lower(title) not like '%wheel%'
and lower(title) not like '%frame%'
and lower(title) not like '%hub%'
and lower(title) not like '%tubeless%'
and lower(title) not like '%disk%'
and lower(title) not like '%hydraulic%'
and lower(title) not like '%duro%'
and lower(title) not like '%dominator%'
and lower(title) not like '%torker%'
and lower(title) not like '%nimbus%'
and lower(title) not like '%bearing%'
and lower(title) not like '%pad%'
and lower(title) not like '%repair%'
and lower(title) not like '%handlebar%'
and lower(title) not like '%kh%'
and lower(title) not like '%kris holm%'
and lower(title) not like '%coker%'
and lower(title) not like '%tube%'
and lower(title) not like '%build%'
and lower(title) not like '%29er%'
and lower(title) not like '%36er%'
and lower(title) not like '%backwards%'
and lower(title) not like '%riding%'
and lower(title) not like '%foot%'
and lower(title) not like '%train%'
and lower(title) not like '%training%'
and lower(title) not like '%learn%'
and lower(title) not like '%learning%'
and lower(title) not like '%dismount%'
and lower(title) not like '%habit%'
and lower(title) not like '%idle%'
and lower(title) not like '%idling%'
and lower(title) not like '%freemount%'
and lower(title) not like '%free mount%'
and lower(title) not like '%free mounting%'
This query returns 33000 topics of 52000 from the main category that could be re-categorized. The number seems realistic, but I still probably need to add more keywords.
The method seems reliable enough.
2 лайка
What did you end up doing here?
If you have unique enough keywords in the topics (I assume you are iterating through all the topic replies and counting keywords in each post), it could be viable to automatically categorize a topic based on the presence of enough unique, specific keywords in that topic.
(This is primarily useful for migrations, though, since on a live forum you’d want the topic in the correct category at the outset.)
2 лайка
I moved topics to other categories by checking keywords in their titles. It worked well enough to be better than the mess it was before.
3 лайка
That’s a good point; a certain specific word consistently appearing in a lot of topic titles is strong evidence that a new category is needed. :thinking:
4 лайка
Did you do this by a query? If so, what was the query template? Was there any other activities required after running the query to ensure db integrity?
1 лайк
It sounds like it was done on an import script, so it would have been modified to infer a category from the title.
Are you doing an import? From what software? If it’s existing in discourse already then you could do it from rails.
1 лайк
As far as I remember since I assisted him in many of his Discourse-related work, I remember him using a Rails script post-importation. He selected the topics by keywords in their titles, then used officially documented commands to move them, such as Administrative Bulk Operations.
I also remember that moving topics having tags, official commands, and rake tasks did not fully update some tables, nor did the related periodic Sidekiq job.
I don’t know if it’s still the case, but that might be something to pay attention to at Bulk tagged topics, then moved topics into another category, but the category tag selector doesn't show tags - #3 by Canapin.
I hope that helps!
1 лайк
