| Summary | The Original AI Chatbot for Discourse | |
| Repository Link | GitHub - merefield/discourse-chatbot: An AI bot with RAG capability for Topics, Chat & Customer Support in Discourse, currently powered by OpenAI ¡ GitHub | |
| Install Guide | How to install plugins in Discourse | |
| Sponsorship | Please consider becoming an ongoing sponsor of my open source work at a level that suits your or your organisationâs resources and needs to ensure this plugin gets the maintenance it deserves and continues to work for your site in the future. |
Enjoying this plugin? Please
it on GitHub ! ![]()
As this is an independently contributed plugin, please make support, bug, ux, and feature requests here in this topic. NB This plugin is not available on Discourse.org hosting. You can install it if you are self-hosted and possibly if you are on third party hosting (but check with your provider).
What is it?
- The original Discourse AI Chatbot!
- You can use this bot for some Customer Support information tasks (see this guide Building a technical support chatbot)
- Converse with the bot in any Topic or Chat Channel, one to one or with others! Supports Threads.
- Customise the character of your bot to suit your forum!
- want it to sound like William Shakespeare, or Winston Churchill? can do!
- The âRAG Modeâ bot can:
- Search your forum** for answers so the bot can be an expert on the subject of your forum.
- Rerank the searches to favour particular groups of authors or Topic tags
- not just be aware of the information on the current Topic or Channel.
- Ask your users privately about their outstanding incomplete User Fields.
- Render and edit AI pictures
- Search Wikipedia
- Search current news*
- Search Google*
- Crawl remotes sites*
- Return current End Of Day market data for stocks.*
- Do âcomplexâ maths accurately (with no made up or âhallucinatedâ answers!)
- These âtoolsâ can be extended with a plugin, see below.
- Vision support - the bot can see your pictures and answer questions on them!
- Automatically respond to new Topics in specific Categories
- Uses cutting edge Open AI API and functions capability of their excellent, industry leading Large Language Models.
- Includes a special quota system to manage access to the bot: more trusted and/or paying members can have greater access to the bot!
- Meter usage by Query or by Tokens.
- Also supports Azure and proxy server connections.
- Use third party proxy processes to translate the calls to support alternative LLMs like Gemini e.g. this one
*sign-up for external (not affiliated) API services required. Links in settings.
RAG mode is very smart and knows facts posted on your forum:
Basic bot mode can sometimes make mistakes, but is cheaper to run because it makes fewer calls to the Large Language Model:
(Sorry China!
**Botâs âvisionâ - what it can see (potentially share) and privacy
This bot can be used in public spaces on your forum. To make the bot especially useful there is RAG mode (one setting per bot trust level). This is not set by default.
In this mode the bot is, by default, privy to all content a Trust Level 1 user would see, working from this setting:
Thus, if interacted with in a public facing Topic, there is a possibility the bot could âleakâ information if you tend to gate content at the Trust Level 0 or 1 level via Category permissions. This level was chosen because through experience most sites usually do not gate sensitive content at low trust levels but it depends on your specific needs.
For this mode, make sure you have at least one user with Trust Level 1 and no additional group membership beyond the automated groups. (bear in mind the bot will then know everything a TL1 level user would know and can share it). You can choose to lower chatbot embeddings benchmark user trust level if you have a Trust Level 0 user with no additional group membership beyond automated groups.
Alternatively:
- Switch
chatbot embeddings strategytocategoryand populatechatbot embeddings categorieswith Categories you wish the bot to know about. (Be aware that if you add any private Categories, it should know about those and anything the bot says in public, anywhere might leak to less privileged users so just be a bit careful on what you add). - only use the bot in normal mode (but the bot then wonât see any posts)
- mitigate with moderation
In addition, note anything it can âseeâ gets shared with Open AI.
You can see that this setup is a compromise. In order to make the bot useful it needs to be knowledgeable about the content on your site. Currently it is not possible for the bot to selectively read members only content and share that only with members which some admins might find limiting but there is no way to easily solve the that whilst the bot is able to talk in public. Contact me if you have special needs and would like to sponsor some work in this space. Bot permissioning with semantic search is a non-trivial problem. The system is currently optimised for speed. NB Private Messages are never read by the bot.
FYIâs
- May not work on mulit-site installs (not explicitly tested), but PR welcome to improve support
- Open AI API response can be slow at times on more advanced models due to high demand. However Chatbot supports GPT 3.5 too which is fast and responsive and perfectly capable.
- Is extensible and supporting other cloud bots is intended (hence the generic name for the plugin), but currently âonlyâ supports interaction with Open AI Large Language Models (LLM) such as GPT-4 natively. Please contact me if you wish to add additional bot types or want to support me to add more. PR welcome. Can already use proxy servers to access other services without code changes though!
- Is extensible to support the searching of other content beyond just the current set provided.
Setup
Prerequisites
Aside from the normal changes to app.yml you need to be aware of the following:
To build with Chatbot or AI Topic Summary you need at least version 0.5.1 of the pgvector postgres extension.
Most people will have at least this version already. However, occasionally some installs have an older version installed. This will prevent you building with an error similar to: PG::UndefinedObject: ERROR: access method "hnsw" does not exist
First make sure your container is running:
./launcher restart app
then enter your container
./launcher enter app
then go into the database and update the version of pgvector:
:/var/www/discourse# su postgres -c 'psql discourse'
\dx
ALTER EXTENSION vector UPDATE;
\dx
exit
now leave the container with exit
You should now be able to rebuild.
Creating the Embeddings
If you wish Chatbot to know about the content on your site, turn this setting ON:
chatbot_embeddings_enabled
Only necessary if you want to use the RAG type bot and ensure it is aware of the content on your forum, not just the current Topic.
Initially, we need to create the embeddings for all in-scope posts, so the bot can find forum information. This now happens in the background once this setting is enabled and you do not need to do anything.
This seeding job can take a period of days for very big sites.
Embeddings Scope
This is determined by several settings:
chatbot_embeddings_strategywhich can be either âbenchmark_userâ or âcategoryâchatbot_embeddings_benchmark_user_trust_levelsets the relevant trust level for the formerchatbot_embeddings_categoriesifcategorystrategy is set, gives the bot access to consider all posts in specified Category.
If you change these settings, over time, the population of Embeddings will morph.
To speed population up
Enter the container:
and run the following rake command:
rake chatbot:refresh_embeddings[1]
which at present will run twice due to unknown reason (sorry! feel free to PR) but the [1] ensures the second time it will only add missing embeddings (ie none immediately after first run) so is somewhat moot.
In the unlikely event you get rate limited by OpenAI (unlikely!) you can complete the embeddings by doing this:
rake chatbot:refresh_embeddings[1,1]
which will fill in the missing ones (so nothing lost from the error) but will continue more cautiously putting a 1 second delay between each call to Open AI.
Compared to bot interactions, embeddings are not expensive to create, but do watch your usage on your Open AI dashboard in any case.
NB Embeddings are only created for Posts and only those Posts for which a Trust Level One user would have access. This seemed like a reasonable compromise. It will not create embeddings for posts from Trust Level 2+ only accessible content.
Useful Data Explorer query to monitor embeddings population
@37Rb writes: âHereâs a SQL query Iâm using with the Data Explorer plugin to monitor & verify embeddings⌠in case it helps anyone else.â
SELECT e.id, e.post_id AS post, p.topic_id AS topic, p.post_number,
p.topic_id, e.created_at, e.updated_at, p.deleted_at AS post_deleted
FROM chatbot_post_embeddings e LEFT JOIN posts p ON e.post_id = p.id
Error when you are trying to get an embedding for too many characters.
You might get an error like this:
OpenAI HTTP Error (spotted in ruby-openai 6.3.1): {"error"=>{"message"=>"This model's maximum context length is 8192 tokens, however you requested 8528 tokens (8528 in your prompt; 0 for the completion). Please reduce your prompt; or completion length.", "type"=>"invalid_request_error", "param"=>nil, "code"=>nil}}
This is how you resolve it âŚ
As per your error message, the embedding model has a limit of:
8192 tokens
You need to drop the current value of this setting:
chatbot_open_ai_embeddings_char_limit:
by about 4 x the diff and see if it works (a token is roughly 4 characters).
So, in this example, 4 x (8528 - 8192) = 1344
So drop chatbot_open_ai_embeddings_char_limit current value by 1500 to be safe. However, the default value was set according to a lot of testing for English Posts, but for other languages it may need lowering.
This will then cut off more text and request tokens and hopefully the embedding will go through. If not you will need to confirm the difference and reduce it further accordingly. Eventually it will be low enough so you donât need to look at it again.
How To Switch Embeddings model
You donât need to do anything but change the setting: the background job will take care of things, if gradually.
If you really want to speed the process up, do:
- Change the setting
chatbot_open_ai_embeddings_modelto your new preferred model - Itâs best to first delete all your current embeddings:
- go into the container
./launcher enter app - enter the rails console
rails c - run
::DiscourseChatbot::PostEmbedding.delete_all exit(to return to root within container)
- run
rake chatbot:refresh_embeddings[1] - if for any Open AI side reason that fails part way through, run it again until you get to 100%
- the new model is known to be more accurate, so you might have to drop
chatbot_forum_search_function_similarity_thresholdor you might get no results :). I dropped my default value from0.8to0.6, but your mileage may vary.
Bot Type
Take a moment to read through the entire set of Plugin settings. The chatbot bot type setting is key, and there is one for each chatbot âTrust Levelâ:
RAG mode is superior but will make more calls to the API, potentially increasing cost. That said, the reduction in its propensity to ultimately output âhallucinationsâ may facilitate you being able to drop down from GPT-4 to GPT-3.5 and you may end up spending less despite the significant increase in usefulness and reliability of the output. GPT 3.5 is also a better fit for the Agent type based on response times. A potential win-win! Experiment!
For Chatbot to work in Chat you must have Chat enabled.
How to get the bot to respond
Basic rules
- If permissioned in plugin settings, the bot will Reply to every Post or Message if invoked in a Topic or Chat Channel with only a single User until more people join.
- the bot will always be invoked if you @ mention it
Special per Category auto-responder
- Per Category, you can get Chatbot to Reply to every new Topic and you can give it special instructions on what to do, governed by a Category specific prompt that you set up in the Category settings.
Should start something like:
âWelcome me by saying hello and introduce yourself. Share with me 5 posts on the forum by using local forum search relevant to my first post, include linksâ
ie you need to write it in first person as if user is asking for help. It is not a system prompt. It is not describing how the bot should behave (thatâs for the system prompt which is still sent). It is a user asking for specific help (albeit hidden) Basically you write it as if a user post without having to mention the bot.
Botâs speed of response
This is governed mostly by a setting: âchatbot_reply_job_time_delayâ over which you have discretion.
The intention of having this setting is to:
- protect you from reaching rate limits of Open AI
- protect your site from users that would like to spam the bot and cost you money.
- allow Discourse enough time to upload hotlinked images so the bot can see them.
It is now default â2â seconds and can now be reduced to zero
, but be aware of the above risks. Bot vsion (if you are using it) is particularly sensitive to this setting. If you find the bot is not seeing your images, try increasing this value.
Setting this zero and the bot, even in âagentâ mode, becomes a lot more âsnappyâ.
Obviously this can be a bit artificial and no real person would actually type that fast ⌠but set it to your taste and wallet size.
NB I cannot directly control the speed of response of Open AIâs API - and the general rule used to be the more sophisticated the model you set the slower this response will usually be. What is more generally the case now is the âminiâ models tend to be quicker.
AI powered User Fields collection (experimental)
If a User has some Optional User Fields that are currently blank, enabling this setting, will cause the bot to start asking the user for the information. It will progress through the outstanding User Fields until they are completed and then revert to normal behaviour.
(sorry for slowness of response - this was recorded in dev)
NB This feature only supports:
- Text
- Dropdowns
- Confirmations
Multi-select is not yet supported.
The fields must be optional
The order of the User Fields determines priority.
Ollama & llama3 support
Ollama support for (the completely AWESOME!) llama3 is now shipping:
This is for when the bot is run locally in dev or in the cloud with ollama server ⌠and in Basic mode:
- make sure model is
llama3:
- custom URL needs to be set
http://localhost:11434:
If you have a big enough server, you could be serving ollama in the cloud there.
DeepSeek Hype
Get in on the act with Chatbot ![]()
You can use the bot in at least Basic mode at least to access V3 and R1
Iâve used:
(no affiliate)
which hosts their models.
Set up like so:
Be sure to set Basic bot mode and substitute your key.
But you may be able to use DeepSeek AI directly if you can access their website to sign up ![]()
Base URL would be âhttps://api.deepseek.comâ.
OpenAI
You must get a token from https://platform.openai.com/ in order to use the current bot. A default language model is set (one of the most sophisticated), but you can try a cheaper alternative, the list is here
There is an automated part of the setup: upon addition to a Discourse, the plugin currently sets up a AI bot user with the following attributes
- Name: âChatbotâ
- User Id: -4
- Bio: âHi, Iâm not a real person. Iâm a bot that can discuss things with you. Donât take me too seriously. Sometimes, Iâm even right about stuff!â
- Group Name: âai_bot_groupâ
- Group Full Name: âAI Botsâ
You can edit the name, avatar and bio (see locale string in admin â customize â text) as you wish but make it easy to mention.
Itâs not free, so thereâs a quota system, and you have to set this up
Initially no-one will have access to the bot, not even staff.
Calling the Open AI API is not free after an initial free allocation has expired! So, Iâve implemented a quota system to keep this under control, keep costs down and prevent abuse. The cost is not crazy with these small interactions, but it may add up if it gets popular. You can read more about OpenAI pricing on their pricing page.
In order to interact with the bot you must belong to a group that has been added to one of the three levels of trusted sets of groups, low, medium & high trust group sets. You can modify each of the number of allowed interactions per week per trusted group sets in the corresponding settings.
You must populate the groups too. That configuration is entirely up to you. They start out blank so initially no-one will have access to the bot:
In this example Iâve made staff have high trust access, whilst trust_level_0 have low trust. They get the corresponding quotas in three additional settings.
Note the user gets the quota based on the highest trusted group they are a member of.
âPrompt Engineeringâ
There are several locale text âsettingsâ that influence what the bot receives and how the bot responds.
The most important one you should consider changing is the botâs system prompt. This is sent every time you speak to the bot.
For the basic bot, you can try a system prompt like:
âYou are an extreme Formula One fan, you love everything to do with motorsport and its high octane levels of excitementâ instead of the default.
(For the rag bot you must keep everything after âYou are a helpful assistant.â or you may break the agent behaviour. Reset it if you run into problems. Again experiment!)
Try one that is most appropriate for the subject matter of your forum. Be creative!
Note that there are now two system prompts for each bot type. One .open is used when talking to the bot in âpublicâ. The other .private is applied when talking to the bot in Personal Messages or Direct Message chat. This is so that you can customize private behaviour for e.g. a support bot.
Changing these locale strings can make the bot behave very differently but cannot be amended on the fly. I would recommend changing only the system prompt as the others play an important role in agent behaviour or providing information on who said what to the bot.
NB In Topics, the first Post and Topic Title are sent in addition to the window of Posts (determined by the lookback setting) to give the bot more context.
You can edit these strings in Admin â Customize â Text under chatbot.prompt., the most important of which are the system prompts which are in: chatbot.prompt.system.
Supports both Posts & Chat Messages!
The bot supports Chat Messages and Topic Posts, including Private Messages (if configured).
You can prompt the bot to respond by replying to it, or @ mentioning it. You can set how far the bot looks behind to get context for a response. The bigger the value the more costly will be each call.
Thereâs a floating quick chat button that connects you immediately to the bot. Its styling is a little experimental (modifying some z-index values of your base forum on mobile) and it may clash on some pages. This can be disabled in settings. You can choose whether to load the bot into a 1 to 1 chat or a Personal Message.
Now you can choose your preferred icon (default
) or if setting left blank, will pick up the bot userâs avatar! ![]()
avatar:
OR icon:And remember, you can also customise the text that appears when it is expanded:
⌠using Admin â Customize â Text
(though you may need to customise the CSS a little to accommodate colours and sizing you want).
Some debugging help
- make sure setting
chatbot include inner thoughts in private messagesis ON - make sure setting
chatbot enable verbose rails loggingis ON - ssh into your server
cd /var/discourse/shared/standalone/log/rails- in parallel ask the bot something in the PM
- go back to console immediately
- look for these kind of messages:
- general chat =
tail -n 2000 production.log | grep {\"model\":\" - vision calls =
tail -n 2000 production.log | grep {\"type\":\"image_url\"
- general chat =
- check âinner thoughtsâ in the PM
Extending Chatbotâs toolset with plugins
Chatbot plugin has the ability to add other functions in separate plugins, so you donât have to maintain a fork of the Chatbot repo.
Example function plugin here:
https://github.com/merefield/discourse-chatbot-function-extension-example
but of course you could add this to any plugin âŚ
This feature was added in this PR
If you need help with extending Chatbot, you can hire me to help you.
Uninstalling the plugin - Important!
Due to recent efforts to simplify the plugin, the only steps necessary to uninstall the plugin are now to remove the clone statement.
Thanks for your interest in the plugin!
Disclaimer: Iâm not responsible for what the bot responds with. Consider the plugin to be at Beta stage and things could go wrong. It will improve with feedback. But not necessarily the bots response
Please understand the proâs and conâs of a LLM and what they are and arenât capable of and their limitations. They are very good at creating convincing text but can often be factually wrong.
Important Privacy Note: whatever you write on your forum may get forwarded to Open AI as part of the bots scan of the last few posts once it is prompted to reply (obviously this is restricted to the current Topic or Chat Channel). Whilst it almost certainly wonât be incorporated into their pre-trained models, they will use the data in their analytics and logging. Be sure to add this fact into your forumâs TOS & privacy statements. Related links: https://openai.com/policies/terms-of-use, https://openai.com/policies/privacy-policy, https://platform.openai.com/docs/data-usage-policies
Copyright: Open AI made a statement about Copyright here: https://help.openai.com/en/articles/5008634-will-openai-claim-copyright-over-what-outputs-i-generate-with-the-api
TODO/Roadmap Items
- Add front and back-end tests
- Add âbot typingâ indicator and âresponse streamingâ (@Aizada_M, @MarcP)
- forgot to mention the bot? Get bot to respond to edits that add its @ mention (@frold )
- Add a badge? You did mention @botname (@frold )
- Add setting to include Category and Pinned Posts prompt? (@Ed_S)
- Ditto Bios to each message history prompt? (@Ed_S , @codergautam). Will this even work. Letâs get evidence.
- Update Discourse Frotz with this better codebase?
Move to use.pgvectorin favour ofpgembeddingfor vector search now that former supports fast HNSW lookup
Add semantic search so that the bot can read your forum Posts and become an âexpertâ
Add agent behaviour to reduce hallucinations and leverage reliable, factual information.
Add extra logic to convert suspected usernames into @ mentions (@frold )
Add GPT-4 support (when Open AI deems me worthy enough of access!
Add custom model name support.
Add option to strip out quotes from Posts before passing text to API.
Improve error transparency & handling for when Open AI returns an error state
Add retry capability for timed out API requests
Add support for ChatGPT
Lint the plugin to Discourse core standards
Add CI workflows
Add settings to influence the nature of the bots response (e.g. how wacky it is).
include Topic Title & first Posts to prompt
Add setting to switch from raw Post/Message data to cooked to potentially leverage web training data better (suggestion by @MarcP). NB May cost more and limit what is returned as input tokens are counted and cooked is much bigger.think weâve abandoned this idea
Credits:
- Thanks to @MarcP for his enthusiastic support and detailed testing feedback.
- The guys whoâve contributed to the emerging standard Ruby API for Open AI which this leverages
- The floating button design is mostly taken from Discourseâs own GitHub - discourse/material-design-stock-theme ¡ GitHub (so they are not currently compatible, doh!)
- The fixtures code is based on @vinothkannans work here
- If @P16 hadnât hired me many moons ago to help him with a chat bot this might not exist
*It still uses OpenAIâs chat GPT engine, but can now leverage local functions and data from API calls to limit hallucinations.
