이메일 알림의 최종 스타일 해결
At least posteo.de web email client renders colors with the first value given in a CSS style definition, which yields unreadable buttons in notifications:
instead of
This image shows a rectangular blue bar with white text that appears to be instructions in German for how to reply to an email, with the German words "Rufe das Thema auf oder antworte auf diese E-Mail, um zu antworten." (Captioned by AI)
Currently, the according style is
font-weight: normal;; text-decoration: none; font-weight: bold; color: #006699;; background-color: #2F70AC; color: #FFFFFF; border-top: 4px solid #2F70AC; border-right: 6px solid #2F70AC; border-bottom: 4px solid #2F70AC; border-left: 6px solid #2F70AC; display: inline-block; font-weight: bold;
If changed to include only the latest definitions
font-weight: normal; text-decoration: none; font-weight: bold; background-color: #2F70AC; color: #FFFFFF; border-top: 4px solid #2F70AC; border-right: 6px solid #2F70AC; border-bottom: 4px solid #2F70AC; border-left: 6px solid #2F70AC; display: inline-block; font-weight: bold;
one gets the desired behavior.
Since there is no benefit by sending later overwritten styles, rendering problems with buggy email viewers could be resolved by sending only the final CSS definitions.
2개의 좋아요
There is an implementation in
https://github.com/thoka/discourse/commit/1b376184a6477c21b41e7acd6121c5775705ddde
1개의 좋아요
If you feel like making a pull request, I’d happily merge it :+1:
It doesn’t solve this issue but having duplicate styling is wasteful and bug-prone anyways.
I would make some slight tweaks to the deduplicate_style function, mostly to make sure both the key and the values are present.
def deduplicate_style(style)
  styles = {}
  style
    .split(";")
    .select(&:present?)
    .map { _1.split(":", 2).map(&:strip) }
    .each { |k, v| styles[k] = v if k.present? && v.present? }
  styles.map { |k, v| "#{k}:#{v}" }.join(";")
https://github.com/discourse/discourse/pull/30003
2개의 좋아요
Thanks, just merged it :git_merged:
1개의 좋아요
This topic was automatically closed after 2 days. New replies are no longer allowed.
