Discourse 3.4.0.beta2-dev에서 검색창이 깨진 건가요?
I am using version 3.4.0.beta2-dev but I don’t understand why the Search part has an error. The website has the title of that article but searching for that title still cannot be found in the Search bar of version 3.4.0.beta2-dev.
In previous versions, this error did not occur, the search was quite accurate when typing the title into the search bar.
I hope it will be fixed in the next version of Discourse.
1개의 좋아요
It works here and on my own. Could this be language dependent :thinking:
3개의 좋아요
I use it for Vietnamese language (I attach the image so you can see this problem)
Does it work on safe mode?
It not, it can be a language issue. For obvious reason my forum isn’t vietnamise :smirking_face: so I can’t test it.
1개의 좋아요
I just tried again in Safe-mode but it’s still the same.
1개의 좋아요
Can you check if someone toggled the search_ignore_accents setting recently? Also, when was your last deploy with this search query working properly?
I tested a few recent changes to search, but I don’t see any regressions in recent changes.
2개의 좋아요
Thanks, let me go to this section and check again.
1개의 좋아요
