升级到3.3对我来说失败了
我尝试通过 UI 进行升级,但失败了,具体情况请参见:
因此,我从备份中恢复了我的 droplet,然后尝试手动升级。
cd /var/discourse
git pull
./launcher rebuild app
这会产生以下输出:
WARNING: Docker version 20.10.7 deprecated, recommend upgrade to 24.0.7 or newer.
x86_64 arch detected.
WARNING: We are about to start downloading the Discourse base image
This process may take anywhere between a few minutes to an hour, depending on your network speed
Please be patient
2.0.20240825-0027: Pulling from discourse/base
e4fff0779e6d: Pulling fs layer
04dda0e597e7: Pulling fs layer
0b0ac7902d91: Pulling fs layer
1ea0327cd622: Waiting
459f11cf96b2: Waiting
cd49b55154ee: Waiting
4f4fb700ef54: Pull complete
890a63bee26b: Pull complete
1d239a1092e9: Pull complete
7439767d748f: Pull complete
19e63282f9d1: Pull complete
6da4866029f1: Pull complete
3274548c87f4: Pull complete
fb2589b81eef: Pull complete
da453ab7ba03: Pull complete
260969aca4e8: Pull complete
0c7927423a10: Pull complete
cfdfd8bdc03e: Pull complete
f837c184a2c0: Pull complete
d14903daf553: Pull complete
01422fc4dc02: Pull complete
e918b15c8f19: Pull complete
3202b43401af: Pull complete
3fa0a48e923e: Pull complete
2f1f96b416a1: Pull complete
b5376d8069b5: Pull complete
259e102648be: Pull complete
807236570b2a: Pull complete
e98845c05b05: Pull complete
578a5e3e249f: Pull complete
6b0bf88c86e8: Pull complete
9551a14ee15e: Pull complete
8bbcc4c7a11d: Pull complete
5aff35532071: Pull complete
f73f45300530: Pull complete
42888ce727c0: Pull complete
e8467a663928: Pull complete
d2fb91f4643c: Pull complete
88fc9778a448: Pull complete
2a19d28a5a17: Pull complete
6a2d56837370: Pull complete
933885f686e0: Pull complete
aecf6df6a6bb: Pull complete
33fcdcfe61e2: Pull complete
12726a4d34c8: Pull complete
Digest: sha256:6de68cb49198b5281f79ed9401b3fe818c854d220dcf0238549fe2f2adb19146
Status: Downloaded newer image for discourse/base:2.0.20240825-0027
docker.io/discourse/base:2.0.20240825-0027
WARNING: containers/app.yml file is world-readable. You can secure this file by running: chmod o-rwx containers/app.yml
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 600 app
app
Status: Image is up to date for discourse/base:2.0.20240825-0027
/usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups.rb
/usr/local/bin/pups --stdin
I, [2024-10-15T06:14:37.390458 #1]  INFO -- : Reading from stdin
I, [2024-10-15T06:14:37.395803 #1]  INFO -- : > echo cron is now included in base image, remove from templates
I, [2024-10-15T06:14:37.398391 #1]  INFO -- : cron is now included in base image, remove from templates
I, [2024-10-15T06:14:37.408024 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2024-10-15T06:14:37.412237 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2024-10-15T06:14:37.416506 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2024-10-15T06:14:37.420758 #1]  INFO -- : File > /root/install_postgres  chmod: +x  chown:
I, [2024-10-15T06:14:37.424824 #1]  INFO -- : File > /root/upgrade_postgres  chmod: +x  chown:
I, [2024-10-15T06:14:37.425837 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/13/main/postgresql.conf
I, [2024-10-15T06:14:37.426590 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postgresql.conf
I, [2024-10-15T06:14:37.427073 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/13/main/postgresql.conf
I, [2024-10-15T06:14:37.427713 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13/main/postgresql.conf
I, [2024-10-15T06:14:37.428194 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.conf
I, [2024-10-15T06:14:37.428633 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/13/main/postgresql.conf
I, [2024-10-15T06:14:37.429175 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/13/main/postgresql.conf
I, [2024-10-15T06:14:37.429569 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/13/main/postgresql.conf
I, [2024-10-15T06:14:37.430001 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/13/main/postgresql.conf
I, [2024-10-15T06:14:37.430562 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/postgresql/13/main/pg_hba.conf
I, [2024-10-15T06:14:37.430964 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2024-10-15T06:14:37.431353 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*::1\\/128.*$) with host all all ::/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2024-10-15T06:14:37.431673 #1]  INFO -- : > if [ -f /root/install_postgres ]; then
  /root/install_postgres && rm -f /root/install_postgres
elif [ -e /shared/postgres_run/.s.PGSQL.5432 ]; then
  socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
fi
I, [2024-10-15T06:14:37.974529 #1]  INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2024-10-15T06:14:37.975013 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2024-10-15T06:14:37.976577 #1]  INFO -- : Terminating async processes
2024-10-15 06:14:38.136 UTC [36] LOG:  starting PostgreSQL 13.16 (Debian 13.16-1.pgdg120+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 12.2.0-14) 12.2.0, 64-bit
2024-10-15 06:14:38.138 UTC [36] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2024-10-15 06:14:38.139 UTC [36] LOG:  listening on IPv6 address "::", port 5432
2024-10-15 06:14:38.143 UTC [36] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2024-10-15 06:14:38.154 UTC [37] LOG:  database system was shut down at 2024-10-15 06:14:28 UTC
2024-10-15 06:14:38.176 UTC [36] LOG:  database system is ready to accept connections
此时升级停止,之后没有任何进展,并且服务器离线(完全没有网络连接)。
接下来我应该尝试什么?
UI 升级需要更多内存,因为您可能同时运行网站和重建。
确保您有足够的交换空间来应对——至少与您的 RAM 一样多。
因此,在 4GB 服务器上,请确保您有 4GB 交换空间。
顺便说一句,这里的 git pull 是多余的。构建脚本会为您处理。
我的服务器有 4GB 内存和 4GB 交换空间。重建过程在 database system is ready to accept connections 处停止,未能完成,论坛仍然无法访问。我可以将其恢复到 Droplet 备份(再次),这将使我回到一个可用的 3.2 论坛,但最好能解决这个问题。
# free
              total        used        free      shared  buff/cache   available
Mem:           3919         286        1443          20        2189        3360
Swap:          4095           2        4093
Total:         8015         288        5537
在这种情况下,我通常会(自行承担风险)重启,但这还没有让我失望。至少这样可以使网站恢复运行。
确保您的操作系统是相对较新的 LTS 版本,并且那个 Docker 警告似乎值得注意。
重建期间使用 htop 监控您的内存以确保安全?
看起来有很多交换空间。 :+1:
我的操作系统是 Ubuntu 20.04.6 LTS。
嗯。好的,我重启了,论坛又恢复了。
啊,但它仍然显示已安装 3.2.4,最新版本是 3.3.2,所以它没有更新。
所以我不知道该怎么办。我会再试一次更新。
是的,它在同一个地方停止了。我猜更新一个更新版本的 Docker 需要更新 Ubuntu 的主版本,我想我可以这样做,只是我当时没有计划这样做。
建议更新您的操作系统和 Docker 以确保万无一失。
构建脚本有时会在各个节点出现长时间延迟。多长时间算长时间?
我回来时它卡在了那个点,过了 15-20 分钟。从那以后我没有特别等待过。它可能只是在执行某些操作,但没有任何证据表明这一点。没有任何东西占用可观的 CPU。
此时您有两个选择:
  • 就地升级操作系统和 Docker - 然后重试
  • 新的 Droplet。
后者可能更快。
嗯,我有一个当前的快照,我想此时进行 Ubuntu 升级应该不会有什么坏处,我总可以撤销所有操作。
哎呀,它拒绝了,因为
抱歉,较新内核不支持此存储驱动程序
版本
aufs 存储驱动程序的内核支持将不再提供任何进一步的 Ubuntu 版本。
请确保您的任何容器均未使用 aufs 存储驱动程序,删除目录 /var/lib/docker/aufs 并重试。
唉。事情从来都不是一帆风顺的,不是吗?
新的 Droplet。 :).\n\nSteps involved to downgrade from 2GB to 1GB on DO? - #3 by merefield swap)
好的,整个升级过程可以说是彻底失败了。
我将把服务器恢复到之前的状态(Ubuntu 20.04.6 LTS 和 Discord 3.2.4),然后装作什么都没发生,暂时忘记 3.3 版本,改天再尝试。
感谢你的帮助。
附加功能 - 当我恢复液滴时,不知何故我会被注销 - 即使在网站处于只读模式下,您也无法登录,即使是管理员!
我刚想到,我无法将 Docker 切换到 overlay2,如 (Change the Docker storage backend) 中所述,以便能够更新 Ubunto,因为切换到 overlay 将需要 ./launcher rebuild app,而这会失败(除非切换到 overlay2 能解决问题,但这本身似乎不太可能)。因此,迁移到新的液滴似乎是唯一可行的方法,尽管这可能需要更改 DNS,而这通常非常缓慢。唉。
您也许可以通过以下方式重启容器:
  docker start app
您也许还可以通过以下方式解决问题:
 apt install docker-ce docker-ce-cli
不确定 overlay 的问题。您是否曾从旧版 Ubuntu 进行过操作系统升级?
如果您使用的是 digital ocean,您可以创建一个指向旧服务器的静态 IP,然后更新 DNS 指向它。然后,当您迁移到新服务器时,由于您可以将 IP 重定向到新服务器,因此不会有 DNS 延迟。
是的,这重启了容器,但没有进行任何升级。
我不知道在“数据库系统已准备好接受连接”之后升级过程会发生什么,但它最多只能到这一步,然后就再无进展(除非下一步需要很长时间)。
是的,Ubuntu 之前已经更新过。所以 Docker 一直都基于 aufs。
是否可以在不升级的情况下重建?如果那样可行,那么我或许可以把当前的 Docker 从 aufs 切换到 overlay2,然后这可能意味着我可以将 Ubuntu 升级到 22,这或许能让其他东西正常工作——但目前我不知道为什么升级会在那个点停滞不前,所以这基本上只是希望有什么能解决它。
不可以,它将升级到指定分支上的最新提交。
请记住,迁移到新服务器可能只需要 30 分钟。
是的,看来我必须走这条路了——别怪我多愁善感,但我真的不想仅仅为了升级论坛就得设置一个全新的服务器(该服务器除了 Discourse 之外还运行着其他一些东西,这些东西也必须迁移)。
唉,这就是任何运行自己服务器的人的生活。
是的,它似乎就是卡在那里,不知何故。我不知道为什么,但进行 docker 升级似乎帮助了几个站点。
你有没有尝试过我上面提到的升级 docker?
如果你尝试在别处搜索,你或许可以修复 overlay。这就是为什么我不信任操作系统升级。
我还没有,但我会尝试上面提到的方法——我需要安排另一次维护时段——我的流程总是先关闭 droplet,然后进行快照,这需要相当长的时间,也是停机时间最长的部分,但可以确保我能非常轻松地回滚,这在几次情况下都很有用。
所以,我将在周二安排另一个维护窗口,然后尝试更新 docker(如果成功,我还会尝试切换到 overlay)。如果失败,我将在下周尝试使用新服务器(或者我可能会并行进行,因为我可以在测试 droplet 上设置一个新服务器)。
谢谢。
