리빌드 관련 문제 발생
I am attempting an app rebuild and having a failure on ‘bundle exec rake db:migrate’. This is an existing installation that has been running quite a while. Most of the searches I’ve seen about this problem seem to be tied to plugins, but I have no additional plugins in use. Just stock Discourse. Plenty of disk space available. Related log below. Any thoughts?
Thanks!
I, [2024-10-18T01:38:00.111880 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2024-10-18T01:38:00.114128 #1]  INFO -- : > sleep 10
1793:C 18 Oct 2024 01:38:00.127 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
1793:C 18 Oct 2024 01:38:00.127 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=1793, just started
1793:C 18 Oct 2024 01:38:00.128 # Configuration loaded
1793:M 18 Oct 2024 01:38:00.129 * monotonic clock: POSIX clock_gettime
1793:M 18 Oct 2024 01:38:00.129 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
1793:M 18 Oct 2024 01:38:00.130 # Failed listening on port 6379 (TCP), aborting.
I, [2024-10-18T01:38:10.121847 #1]  INFO -- :
I, [2024-10-18T01:38:10.125839 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
rake aborted!
[checklist] Javascript files under `assets/javascripts` are automatically included in JS bundles.
Manual register_asset calls should be removed. (attempted to add javascripts/checklist_ui.js)
/var/www/discourse/lib/plugin/instance.rb:723:in `register_asset'
/var/www/discourse/plugins/discourse-plugin-checklist/plugin.rb:7:in `activate!'
/var/www/discourse/lib/plugin/instance.rb:780:in `instance_eval'
/var/www/discourse/lib/plugin/instance.rb:780:in `activate!'
/var/www/discourse/lib/discourse.rb:348:in `block in activate_plugins!'
/var/www/discourse/lib/discourse.rb:345:in `each'
/var/www/discourse/lib/discourse.rb:345:in `activate_plugins!'
/var/www/discourse/config/application.rb:232:in `block in <class:Application>'
/var/www/discourse/lib/plugin.rb:6:in `initialization_guard'
/var/www/discourse/config/application.rb:232:in `<class:Application>'
/var/www/discourse/config/application.rb:75:in `<module:Discourse>'
/var/www/discourse/config/application.rb:74:in `<top (required)>'
/var/www/discourse/Rakefile:7:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/exe/rake:27:in `<top (required)>'
I, [2024-10-18T01:38:12.504780 #1]  INFO -- :
I, [2024-10-18T01:38:12.506202 #1]  INFO -- : Terminating async processes
I, [2024-10-18T01:38:12.507158 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 38
2024-10-18 01:38:12.507 UTC [38] LOG:  received fast shutdown request
I, [2024-10-18T01:38:12.508420 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 106
106:signal-handler (1729215492) Received SIGTERM scheduling shutdown...
2024-10-18 01:38:12.514 UTC [38] LOG:  aborting any active transactions
2024-10-18 01:38:12.529 UTC [38] LOG:  background worker "logical replication launcher" (PID 53) exited with exit code 1
2024-10-18 01:38:12.530 UTC [48] LOG:  shutting down
2024-10-18 01:38:12.550 UTC [38] LOG:  database system is shut down
106:M 18 Oct 2024 01:38:12.583 # User requested shutdown...
106:M 18 Oct 2024 01:38:12.584 * Saving the final RDB snapshot before exiting.
106:M 18 Oct 2024 01:38:12.746 * DB saved on disk
106:M 18 Oct 2024 01:38:12.747 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 1796 exit 1>
exec failed with the params {"cd"=>"$home", "tag"=>"migrate", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
aa541b3e83ae7262e9352dc3a8f5da689f39fba35f9b43aa5643ea6e11109dd8
==================== END REBUILD LOG ====================
Failed to rebuild app.
Hey there, have you tried asking the Dr? ./discourse-doctor
Also, rebooting the server, albeit an extreme approach, has worked for me in the past.
Are you upgrading from a very old version?
I did try the discourse doctor. All it seemed to do was attempt the rebuild again and didn’t give me much useful otherwise. Rebooting server didn’t do anything :confused:
I’m two minor versions behind so no, not terribly old.
I had a similar error while doing some updates tonight. Running ./launcher rebuild app a 2nd tie did the trick. Maybe try again??
This is the issue
Can you please check which branch of Discourse you are on via git status and share here?
Your error message doesn’t make a lot of sense to me as if you look at the source code there is no such command.
“On branch main”
I am still experiencing this problem and all my attempts to resolve it have failed. Anyone have any ideas for me?
I finally managed to sort this out. While scrubbing the output of my build, I found a line that said something about an unrecognized plugin. I went into my app.yml and I only had two listed - docker_manager and discourse-checklist. When I went to look at discourse-checklist I noted that it had been merged into core so I removed it from app.yml. After this my build proceeded successfully.
