Скачанные резервные коды двухфакторной аутентификации не разделены в Windows (только символ LF)
The downloaded file generated by the Two-Factor Backup Codes function includes the 10 codes separated by an LF (\n) character.
Windows users will only see 320 characters in one line in this file instead of 10 separate codes.
The string with the backup codes is generated here:
Can we add a carriage return character too? For Linux/macOS users, this will make no difference in viewing the file, but it fixes the problem for Windows users.
I can also open a PR for this issue myself if that makes the implementation easier, but I want this to be reported and possibly discussed first.
3 лайка
Very reasonable suggestion, a PR would be most welcome. Thanks!
1 лайк
Done: 2FA Backup Code Download: Use CRLF for Windows-compatibility by sebix · Pull Request #29400 · discourse/discourse · GitHub
4 лайка
Thanks @sebix1, we can’t merge your PR until you sign the CLA, though.
3 лайка
Just merged @sebix1’s PR
4 лайка
This topic was automatically closed after 15 hours. New replies are no longer allowed.
