I don’t have a credit card or a TG account.There is not even a payment method.
I know vpsfree.es, but this vps is out of stock.
I believe it is difficult to solve this problem.
There isn’t a “free” option. Your best bet is one of those plans that offer credits when you signup, like DigitalOcean.
You can look at similar topics here.
I think you’re going to struggle to find a VPS that doesn’t want a way to pay… Discourse is ‘free’ as in open source but computer time isn’t free
You may want to look at GCP’s free tier. It wasn’t too bad.
‘wasn’t’ → past tense. I used to run a forum there, but shut it down when my trial ended and didn’t want to use the >$300 credits I had left.
the cheapest VPS provider i’ve ever used is Ionos, or
the data center designer, but that gets expensive rather than free after the initial trial period
initally with the data center designer you can do a onedrive migrate from one organisation to another in Office 365, using rclone, with data-center level bandwidth
I believe this is an excuse to have higher price than Ionos
Ionos data center designer, domestically/small business scale, it’s unlikely you’ll reach the monetry limit before the time limit
two things to note
- you don’t need Plesk for Discourse, though it didn’t matter that i irreversibly activated it
- they are strict about port 25 for outbound connections, which mail-receiver will never need as it receives email
