Ошибка: иконка темы отсутствует
When you make a PM into a topic the :speech_balloon: icon seems to be missing as you can see in the image below.
This is in the topic :wrench: admin actions in a PM
3 лайка
oh it’s there all right, it’s just not showing because of some shenanigans, possibly fontawesome 6 not being awseome… :thinking: lol
Thanks for the heads up!
2 лайка
I just converted this to a PM and back to a topic and it seems the icon appears correctly? :thinking:
it looks like this is expecting a different icon for some reason…
edit: looking at the code for small actions, it appears it falls back to “exclamation” when a matching icon can’t be found… but the public_topic does have an icon defined… the plot thickens
3 лайка
I’m not sure that’s ever worked on our forum, we have many silly posts that were made into actions as a joke, and none of those have icons visible.
1 лайк
That happens because Meta is a public site. The action code is different in that case.
There is different text when login required is enabled.
I think the problem is that while there is an icon for “public_topic”, there is no icon defined for “open_topic”.
4 лайка
Ah that explains it! thanks for figuring that out
This PR will add the icon:
5 лайков
