카테고리를 편집할 수 있는 페이지에서 상단의 드롭다운을 사용하여 해당 카테고리의 하위 카테고리로 이동하면, 하위 카테고리 드롭다운이 표시되지 않습니다.
동영상에서 test-3 카테고리로 시작합니다. test-3은 test-category의 상위 카테고리입니다. 그런 다음 드롭다운을 사용하여 test-category의 편집 페이지로 이동합니다.
결국 보이는 화면:
기대하는 화면(페이지를 새로고침한 후 보이는 화면):
결국 보이는 화면:
This is a generic issue. Any changes to categories need a full reload to be into effect. Same goes for creating a category and then trying to create a post in it, or to assign a group to it. It would be great if the system would just issue a reload via the MessageBus if only for the user making the edit.
Could you explain which changes you mean? I didn’t edit anything. This problem only occurs if the subcategory I choose is a subcategory of the category I am looking at. If the subcategory has a different parent category, it works fine.
For example, switching from test-3 to Status, a subcategory of Team, works fine.
I’m confused
“When you are at the page where you can edit the category”
I will improve my post
I see what you mean. It’s even worse. If you choose “back to category” it’s an issue as well.
You are right.
When I choose “back to category” from the subcategory edit page, the subcategory dropdown is missing too.
This is test-category as the about topic indicates:
yea I can totally repro this - sorry Moin, I hadn’t seen this topic yet. I was like where is the missing subcategory dropdown, and I was just about to post a note about it. thanks for the heads up ![]()
This is only when you just created the category no? Regular case is working as far as I can tell:
Not saying we shouldnt fix the create case, but this is lower priority.
I think you need to start at “General”, use the wrench, and then use the dropdown at the top to navigate to “Test”.
Then the subcategory dropdown does not appear and is also missing when you go back
Ah ok I see, I misunderstood the problem (and found another bug :p)
I noticed the bug some time ago, but it became more annoying after I created Related category permissions because then I navigated to the subcategory more frequently.
이 문제가 수정된 것 같습니다 - 아마도 FIX: subcategory filter should be always visible on category view page - Pull Request #36050 - discourse/discourse - GitHub 을 통해 수정되었을 것입니다.
이 주제는 6일 후 자동으로 닫혔습니다. 더 이상 새 답변을 남길 수 없습니다.
