Redis used_memory가 1024mb로 제한되나요?
It seems like there is some limit preventing Redis from being able to use more than 1024mb?
I have noticed as soon as that amount is exceeded in the Sidekiq dashboard (MB RSS) is when I start getting logs like:
Your Redis network connection is performing extremely poorly. Last RTT readings were [96585, 101554, 97189, 99769, 94618], ideally these should be < 1000. Ensure Redis is running in the same AZ or dat
When I check using this:
./launcher enter app
redis-cli info memory
This is the result:
# Memory
used_memory:1072837696
used_memory_human:1023.14M
used_memory_rss:484577280
used_memory_rss_human:462.13M
maxmemory:0
maxmemory_human:0B
I set this in the app.yml:
UNICORN_SIDEKIQ_MAX_RSS: 8000
In the Sidekiq dashboard, there is 4,553 MB RSS being used and utilisation is 100%. This is with 2 UNICORN_SIDEKIQS with DISCOURSE_SIDEKIQ_WORKERS not being set (so the default of 5).
I was under the impression UNICORN_SIDEKIQ_MAX_RSS would allow redis to use more ram? I’m a bit lost, any guidance would be appreciated! :love_letter:
This is with Discourse 3.3.2 Stable.
Redis will only uses the memory it needs, the RTT errors are unrelated, they are more likely coming from an install being far away or a machine being out of juice to run Redis.
감사합니다! RTT 문제가 발생한 이유는 THP가 여전히 활성화되어 있었기 때문이라고 생각합니다. 저는 그렇지 않다고 생각했었거든요:
