When resuming the app, it shows a blanc page instead of my subscriptions. I have to force close the app to show the subscriptions again.
May be something to look into.
iOS 18.1.1 iPhone 16pro max.
Hello Frits.
I don’t quite understand what you are asking. Are you referring to the Discourse Subscriptions Plugin plugin?
Thanks for the report, will work on a fix this week.
Some of our community have been reporting the same issue on iOS and macOS, with Safari browser.
If they leave our Discourse site open as the active tab then close the browser for a period of time, when they come back they just get a spinner, the site never loads.
It’s as if something is disconnecting or timing out in the background, and the frontend UI is unaware of the disconnect.
Could this also be related to the hub-app issue reported here?
@Richie that looks a little bit different, it’s not completely a blank page. And it also looks like you’re on the PWA, which may have its own challenges.
The original issue in DiscourseHub here should be fixed in the next beta, available for public testing via: https://testflight.apple.com/join/mzqp6Bk3
Thanks, yes, I wasn’t sure if PWA would be functioning in a similar way to the native app ![]()
