Загрузка в AWS S3 — не удалось подписать запрос без установленных учетных данных
Hey guys,
I´m using 3.4.0.beta3-dev, and I´m getting the mentioned error (but only in ui, not the logs) when trying to upload an image into a topic.
my config is thus:
["s3_upload_bucket", "<bucketname>/discourse-uploads"],
 ["s3_backup_bucket", "<bucketname>/discourse-backups"],
 ["s3_region", "eu-central-1"],
 ["s3_use_acls", "f"],
 ["enable_direct_s3_uploads", "f"],
 ["enable_s3_uploads", "t"],
 ["s3_access_key_id", ""],
 ["s3_secret_access_key", ""]]
and I´m using the ec2 instance profile and override the credentials
I get the error in ui:
but the log is telling me it was ok:
Started POST "/uploads.json?client_id=bb1ab05dbb9d4d1f9930d05f28b17f94" for 10.x.x.x at 2024-12-13 11:46:35 +0000
Processing by UploadsController#create as JSON
  Parameters: {"upload_type"=>"composer", "pasted"=>"true", "name"=>"image.png", "type"=>"image/png", "sha1_checksum"=>"a0f0fe1abd27ce137e0e1b2a28cd9348a08112ff", "file"=>#<ActionDispatch::Http::UploadedFile:0x00007f50b8b01db8 @tempfile=#<Tempfile:/tmp/RackMultipart20241213-386-i7xkqa.png>, @content_type="image/png", @original_filename="image.png", @headers="Content-Disposition: form-data; name=\"file\"; filename=\"image.png\"\r\nContent-Type: image/png\r\n">, "client_id"=>"bb1ab05dbb9d4d1f9930d05f28b17f94"}
Completed 200 OK in 36ms (Views: 0.1ms | ActiveRecord: 0.0ms (0 queries, 0 cached) | GC: 0.0ms)
Completed 418  in 23ms (Views: 0.2ms | ActiveRecord: 0.0ms (0 queries, 0 cached) | GC: 0.4ms)
The bucket is empty afterwards (just setting this up with a fresh bucket)
Any hints ?
Thanks,
WS
1 лайк
Make sure your EC2 instance has the right permissions to upload to S3, like s3:PutObject and s3:GetObject. Double-check your S3 bucket’s region and access settings. You might also want to try turning on s3_use_acls: true if necessary. You can also test uploading directly with AWS CLI to rule out permission issues. And if you’re not using direct uploads, just leave enable_direct_s3_uploads: f as is. Should help fix the problem!
1 лайк
hmmmm…
My EC2Instance Roles policy look loike this:
    "Action": [
        "s3:PutObject",
        "s3:AbortMultipartUpload",
        "s3:PutLifecycleConfiguration",
        "s3:PutObjectVersionAcl",
        "s3:PutBucketCORS",
        "s3:DeleteObject",
        "s3:PutObjectAcl",
        "s3:Get*",
        "s3:List*"
    "Resource": [
        "arn:aws:s3:::<data-bucket>",
        "arn:aws:s3:::<data-bucket>/*",
        "arn:aws:s3:::<backup-bucket>",
        "arn:aws:s3:::<backup-bucket>/*"
    "Effect": "Allow"
Bucket permissions look like this, but security hub already screams at me, that it´s too open :frowning:
I can upload files from ec2 instance without problems with cli (instanceprofile works in that regard)
UPDATE: noticed, that the upload progress reaches 100 %, and only after that I´m getting the error (had to be quick with Greenshot to capture this :smiley: )
hmmmm … seems he was successful uploading the multiparts, but couldn´t finish the process afterwards
Tried now, to set up IAM User with credentials and give it s3:* permissions, and now the upload works, but discourse can´t display it afterwards:
As I´m working in a company, and there are SCP (Service control policies) active for our accounts, it seems that public access is generally blocked
Seems to be no S3 for me (and everyone having the same restrictions for his accounts)
Giving up now … :frowning:
Hope this works for you: https://www.youtube.com/watch?v=qjebh5AOZ8E . This would work for you if it’s not explicitly blocked by your company.
I was getting the same error message as the original poster here, with a similar configuration. I verified that I could get and put s3 objects using the AWS CLI from my EC2 instance even though Discourse was unable to do that.
I created a new IAM user with the same permissions policy as my EC2 instance role and used an access key instead of EC2 instance profile and now uploads work fine.
So in my case it wasn’t an issue of changing permissions, which makes me think that there may be a bug in instance profile authentication. Is there any way for me to get more information about why this was failing?
