iOS PWA, App: Обновление при вытягивании
Hello :wave:
A new theme component to make more friendly the iOS PWA usage. Pull to refresh is a huge gap in iOS PWA. This theme component tries to fill this gap.
I tested it on iOS 15.8 and this is why I create this topic to with your help test it on newer os / device too before publish it. Thanks :slight_smile:
Here is the Theme Creator for testing.
Please share you experience :hugs:
7 лайков
Changed the loader to keep the native scroll, more natural feeling and makes it more suit to Discourse…
2 лайка
I’m on iOS 18.
1 лайк
Hello :wave: Thanks for checking. Are you sure the component was active? :thinking:
1 лайк
Hey Don, my bad! I’m not super familiar with how the theme creator works. Could you guide me on how to activate the component? It’s asking for a repo link or a zip file.
Just click the link in the OP and click the View theme button. I asked it because if it was a reload on the theme creator site then the component inactivated. :slightly_smiling_face:
1 лайк
It looks to work on iPad.
2 лайка
Yayy it worked great :))
1 лайк
…and iPhone seems to be fine too.
It’s time to publish that component and make everybody happy :blush:
1 лайк
See Pull to Refresh for iOS App
