Challenges creating a custom color palette: mk0r is having trouble creating a custom color scheme in Discourse by defining colors in the about.json file. Some color definitions are not being respected, and instead, Discourse is computing its own values. Lilly suggests checking for inconsistencies in variable names, such as underscores vs dashes. mk0r is looking for a reference JSON file with all variables and correct syntax.
After reviewing the solarized theme and other example schemes, mk0r finds inconsistencies in variable naming conventions. Lilly points to an old topic that may help with color customization, but mk0r is still confused about the correct syntax and names for JSON and CSS variables.
Lilly suggests checking the color_transformations.scss file and theme configuration, and provides links to theme development topics. mk0r has read these topics but finds no complete reference for all color variables. They plan to start from a clean slate and use developer tools to troubleshoot the issue.
I’ve tried to create a completely custom color scheme by defining my colors in the about.json file of my theme on GitHub.
Unfortunately only some of my color definitions are being respected in the site.
For example, in my json scheme I define: "success_low": "DDE2B2”,
However my style guide shows a different (computed) color for var(--success-low)
I’ve read through all the guides and it seems maybe the json palette definitions are not all used and instead discourse is computing some of the values on its own and not respecting my definition.
Do I need to instead hard code the colors in a css variables file? Will these override the computed values? Where and how should I do this? I’d like to define every single color for both light and dark mode in discourse, I don’t like any of the computed values.
Thanks for any help. It’s been very hard to wrap my head around how all this stuff works, what takes priority in the final css, etc.
update: this post would seem to contradict my troubleshooting:
So it leaves me more confused about why discourse still seems to be auto generating colors
Thanks, I will go through and check all the underscores vs dashes. Is there any reference json file I could find somewhere that has a reference for all variables, with dashes and underscores in the right places?
Whereas in this (and other) example schemes they have underscores:
I am admittedly not the sharpest coding knife in the drawer, and I’m sure people who’ve worked on this for a long time find it more obvious and intuitive… but trying to wade through this feels like I’m going a bit crazy.
It’s really hard to get an intuitive grasp of all the logic for how light and dark mode colors are used. Between the multitude of scss files and transformations, json, admin GUI, palettes which are (somewhat?) independent of themes…
Sorry for my rambling, just struggling a bit over here
I’m still confused – is there no clear guidance available about how to set every color? And what the correct syntax/names are in the json vs the css variables?
Yes I’ve read them, but there’s no complete reference for all the color variables that I could see. I based my about.json file on the “solarized” theme which seemed to have all the variables declared. I’m going to try again from clean slate and report back and use developer tools to see what the issues might be..
