我如何安装自己用 Ruby 编写的插件?
我有一个包含 discourse 用户电子邮件的 CSV 文件。我需要创建一个每天运行的脚本,向特定用户发送特定的电子邮件模板。然后,我需要每天使用下一组用户运行此脚本。我该怎么做?
根据 https://ask.discourse.com/,我需要创建代码来自动化此过程,并将代码和数据放在*plugins*文件夹中。代码建议如下:
# frozen_string_literal: true
# name: auto-email
# about: A custom plugin to send bulk emails using automation and CSV files
# version: 0.3
require 'csv'
after_initialize do
  if defined?(DiscourseAutomation)
    # Define a unique scriptable for the automation
    DiscourseAutomation::Scriptable::AUTO_EMAIL_SCRIPT = "auto_email_script"
    add_automation_scriptable(DiscourseAutomation::Scriptable::AUTO_EMAIL_SCRIPT) do
      # Define fields for the automations UI:
      field :email_template, component: :message # Email body to be sent
      field :csv_file_name, component: :text # Name of CSV file in the "data" folder
      script do |context, fields, automation|
        # Define the path to the data folder
        data_folder_path = Rails.root.join("plugins", "auto-email", "data")
        # Get the CSV file name from the admin automation field
        csv_file_name = fields["csv_file_name"]["value"]
        csv_file_path = File.join(data_folder_path, csv_file_name)
        # Ensure the file exists
        unless File.exist?(csv_file_path)
          Rails.logger.warn("CSV file #{csv_file_path} not found!")
          next
        # Parse the CSV file
        begin
          users = CSV.read(csv_file_path, headers: true).map(&:to_hash)
        rescue StandardError => e
          Rails.logger.error("Error reading CSV file (#{csv_file_name}): #{e.message}")
          next
        # Get the email message content from the automation field
        email_body = fields["email_template"]["value"]
        # Iterate through users from the CSV and send emails
        users.each do |user_data|
          email = user_data["email"] || user_data["normalized_email"]
          user = User.find_by_email(email)
          if user
            begin
              # Send an automated email using SystemMessage
              SystemMessage.new(user).send_email(
                "custom_email_template", # Ensure this email template exists
                message_body: email_body
              Rails.logger.info("Email sent to: #{email}")
              Rails.logger.error("Failed to send email to #{email}: #{e.message}")
          else
            Rails.logger.warn("No user found with email: #{email}")
我的插件结构如下:
/var/discourse/plugins/auto-email/
├── README.rb
├── data/
├── mamapedia_users_data_01.csv
├── lib/
├── plugin.rb
但是,当我重启或重建应用程序时,在管理面板中看不到新插件。日志中也没有任何错误。
我哪里做错了?我还需要做些什么?
我将从开发 Discourse 插件 - 第 1 部分 - 创建一个基本插件开始。
我试过那个了,很简单。但不幸的是,它对我不起作用。
我在两个不同的应用程序中测试了相同的解决方案。这是我使用的 plugin.rb 文件:
# name: auto-email
# about: A super simple plugin to demonstrate how plugins work
# version: 0.0.1
# authors: Xavier Garzon
我还检查了容器中的插件文件夹(/var/www/discourse/plugins),似乎我的插件没有被复制。也许这是问题的一部分。
对于第二个测试,我也尝试了:
./launcher rebuild app --clean
./launcher restart app
这是我正在运行的版本:
3.4.0.beta4-dev
(9f41ce7fce)
你的插件放在 GitHub 仓库了吗?
你不能只是把 plugin.rb 放在 /lib 目录下,它必须放在 plugins 目录下,并且在生产环境中,你需要按照 在自托管站点上安装插件 中的说明通过 GitHub 添加它。
是的。如果不在那里,它就不存在。
你真的应该阅读所有这些插件主题。你也应该在开发环境中进行测试。
