The Density Toggle Component allows users to adjust the viewing density of a Discourse forum, offering default, cozy, and compact options. jordan.vidrine introduced the component, which includes a theme component installation guide and a beginner’s guide to Discourse Themes. Arkshine reported issues with the menu not appearing on iPadOS and mobile view, suggesting a z-index problem. They also noted that the current density value isn’t selected by default in preferences and mentioned the absence of a font size interface. Canapin highlighted several UX issues in compact mode, including avatar flair size, overlapping buttons, and alignment problems. jordan.vidrine confirmed that font size changes are planned but not yet implemented. tvavrda reported an installation button issue, which jordan.vidrine fixed. tvavrda also noted compatibility issues with the Enhanced view. Canapin and jordan.vidrine discussed whether compact mode should alter font size. twofoursixeight observed inconsistent gaps in cozy mode. patrickemin inquired about the component’s visibility on mobile, to which jordan.vidrine explained it’s hidden to minimize mobile use but accessible in user preferences.
I noticed on iPadOS 18.1.1 that the menu doesn’t appear when clicking on the button in the sidebar. I do see the button focused, but nothing pops up. If I switch to desktop mode, it works.
Another minor UX issue: The current density value is not selected by default the first time you visit the preferences. (On a side note, the labels don’t seem localized.)
Edit: I think it’s more related to the value that has not yet been saved to the browser storage.
User preferences have a font size setting.
I don’t think the compact view should alter the global font size at all. They should remain separate settings.
The topic map container doesn’t use 100% of the width. It should normally reach the right side.
The absence of the horizontal line that separates posts in the regular layout makes the post list right side look weird. The dates and reply buttons are too close to each other. Each button and the date below look like they’re parts of the same post, but they actually belong to different posts.
Hi again. Just tried the compact view together with Enhanced (AI summaries) view selected. The result is not likable. I guess the combination doesn’t make much sense but it’s possible to select it.
I’m not sure this is something to mention here but the gap between topics looks a little inconsistent
with the newline in the cozy density mode compared to the normal
density and the compact density.
Hi, I activated that TC for my FOUNDATION theme, I can see that TC settings on my PC (lower left side menu) but when using my mobile with that theme, that TC setting is not visible, any idea ? Thanks.
update: just found it in my preferences… (but not visible in the lower left side menu?)
