Erro 404 ao alterar o nome de usuário e acessar o perfil do usuário
Repro steps:
  1. Change a user’s username.
  2. After successfully changing the username, click on Show Public Profile
  3. It should return a 404 page.
1 curtida
This is so minor. You’ve changed the username so you’ve changed the route to the page. It’s only possible for a moderator to do this.
Will only check if I can oneline fix it, and consider WONTFIX otherwise.
1 curtida
What happens for the user when an admin updates their username? Do their links under the user menu to their profile, preferences, etc. break?
I’ve been facing a similar bug in an authentication plugin I’m working on, a refresh is required to fix things for a user when the plugin updates their username.
@j.jaffeux if the fix is more involved, I’m happy to submit a PR as I imagine it would fix things in my plugin too
3 curtidas
