即使失败也记录用户名更改日志
This isn’t any serious bug as the username still does not change, however it is a little inconvenient for moderators when viewing action logs for a specific user and they see a username change but it hasn’t actually been changed.
  1. Go to /u/[username]/preferences/username.
  2. Attempt to change the username to something that is already taken.
  3. Press the ‘change’ box when it allows you to.
    • This was a bit hard for me, I will assume this will have different outputs and timings in different environments.
Despite the username not changing, it still logs in admin/logs/staff_action_logs as the username being successfully changed:
Just thought I would report it :smiley:
Thanks.
3 个赞
This seems like a bug @techAPJ?
4 个赞
Fixed in:
Thanks for reporting this issue @Zeemah :+1:
4 个赞
