Hi guys!
I got failed during upgrading process from the admin. And then I tried to rebuild again, but I face constant problem:
Layer already being pulled by another client. Waiting.
Someone please help me
Hi guys!
Not sure, try rebooting. Or waiting a while.
Rebooting does not help. I leave it for 12 hours and then get no difference
Try uninstalling docker and reinstalling latest
Good idea try docker --version
and docker --info
as well.
@sam, @codinghorror
The system automatically generate the app.ml.save, and the app.yml becomes empty totally.
I deleted the app.yml, then transfer an original app.yml. And then it becomes empty with the size of 0.
I try nano containers/app.yml to modify it. After adding the content, it can not be saved by the error of “No space left on device”
Please help me guys @@
The error in nano says “No space left on device”. Have you checked that you haven’t run out of disk space?
Of course! I still have more than 10Gb of available disk
Well, that’s all I’ve got. I would recommend that you run docker -- version
and docker --info
for @codinghorror though, the results can be very helpful for them to see what is going on.
What does the df -h
command return?
@codinghorror, @sam, @jomaxro
I just want to let you guys know that the problems were solved by resizing my server for larger ram and disk.
Thank you so much for kind helps
