Hey folks,
I am running the official docker setup. So far so gut.
I was always able to update everything from the web interface.
I am on 2.9.0.beta1 and 2.9.0.beta2 is available.
Suddenly I see this:
You are running an old version of the Discourse image.
Upgrades via the web UI are disabled until you run the latest image.
To do so log in to your server using SSH and run:
cd /var/discourse
git pull
./launcher rebuild app
More info on our support site
No problem I think, but when execute the ./launcher rebound app command but nothing happens afterwards:
root@test:~# cd /var/discourse/
root@test:/var/discourse# git pull
remote: Enumerating objects: 7, done.
remote: Counting objects: 100% (7/7), done.
remote: Compressing objects: 100% (1/1), done.
remote: Total 4 (delta 3), reused 3 (delta 3), pack-reused 0
Unpacking objects: 100% (4/4), 560 bytes | 140.00 KiB/s, done.
From https://github.com/discourse/discourse_docker
dc5b37c..65fa205 main -> origin/main
Updating dc5b37c..65fa205
Fast-forward
templates/web.template.yml | 6 ++++++
1 file changed, 6 insertions(+)
root@test:/var/discourse# ./launcher rebuild app
x86_64 arch detected.
You have less than 5GB of free space on the disk where /var/lib/docker is located. You will need more space to continue
Filesystem Size Used Avail Use% Mounted on
/dev/sda1 19G 14G 4.7G 74% /
Would you like to attempt to recover space by cleaning docker images and containers in the system? (y/N)y
If the cleanup was successful, you may try again now
root@test:/var/discourse# docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
c4830c85abab local_discourse/app "/sbin/boot" 2 months ago Up 31 hours 0.0.0.0:80->80/tcp, :::80->80/tcp, 0.0.0.0:443->443/tcp, :::443->443/tcp app
How much space do I need in order to update?
root@test:/var/discourse# df -h
udev 949M 0 949M 0% /dev
tmpfs 194M 796K 193M 1% /run
/dev/sda1 19G 11G 7.6G 58% /
tmpfs 968M 0 968M 0% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 968M 0 968M 0% /sys/fs/cgroup
/dev/sda15 253M 1.1M 252M 1% /boot/efi
overlay 19G 11G 7.6G 58% /var/lib/docker/overlay2/1ab2396bdd0b9c2fbc6110cdcc792dba2c2bc8a52650935ff7af0084bda62f07/merged
tmpfs 194M 0 194M 0% /run/user/0
I have more than 5GB available but it does not work.
