Send notification when someone edits a post you've liked
I’d like to receive a notification if someone edits a post that I’ve liked.
This would avoid users appearing to like posts that they don’t agree with, once they’ve been changed.
Sometimes I only spot the edit once my like has been ‘frozen’ (x time after I’ve liked the post, the like can’t be removed) but I expect there are other posts that I’ve liked whose edits I never spot.
Apologies if this idea is a duplicate, I did look.
「いいね!」 3
And/or to have the Likes automatically removed from an edited post?
Likes removed due to edit is not on the cards, this would have to be a plugin.
My preferred solution here, due to the rarity of the situation is just to flag and have moderators reset likes on cases like this where there “good post” → “like” → “edit to make post unreasonable” chain.
Notify on edit after like, is an interesting concept, but we are protective of attention so I am not super enthused about adding more noise.
「いいね!」 6
I have wanted this in some rare cases. Basically you need to ‘reset’ the post for a variety of reasons. Very very rare though.
「いいね!」 3
注意を保護することには同意しますが、通知は編集された投稿に「いいね」をしたユーザーにのみ送信され、トピックを「監視」している全員に送信されるわけではありません。
また、モデレーターに「いいね」のリセットを要求できるように、編集されたことを認識している必要があります。
