What would the box be prompting the user to do? A lot of customer service chat apps don’t require accounts and are staffed with someone live on the other end, so they can skip right to chat.
Would it be prompting them to create a new topic (would you get a lot of duplicates)? A new account? To search existing topics?
It would work like a customer service chat app using support data from Discourse.
The chat-bot would attempt to answer and if it could not then it would attempt to contact a live person.It would also encourage them to join the Discourse.
Oof, that sounds like quite a bit of work. I wonder if the shortest possible path would be a theme / theme component which puts Intercom on your instance?
I haven’t tried it personally, but I imagine throwing Intercom’s scripts with your app id into </body> or similar would get you close.
Oh, I meant your installation of Discourse. One of the customizations you can make to your site (by visiting /admin/customize/themes => Edit CSS/HTML) is adding (somewhat) arbitrary javascript which will run each time someone loads your site.
If that (somewhat) arbitrary javascript were to load Intercom, that might be an easier way to get where you want to go.
