Hey team,
Is it possible to also add Intercom to my Discourse forum?
I would need to add an Intercom javascript snippet to my Discourse forum.
I appreciate any ideas and insight.
Thank you!
Intercom Integration with Discourse
Ryan_Collins1 asks if it’s possible to add Intercom to a Discourse forum by adding an Intercom JavaScript snippet. Bas suggests adding the JavaScript code to the </head> or </body> section of the theme via Admin → customize → theme → Edit CSS/html.
Ryan_Collins1 attempts to implement the solution but encounters issues loading the Intercom messenger. tkrunning provides an updated solution based on Intercom’s setup guide for single-page apps, involving adding code to the </head> and </body> sections to initialize Intercom and fetch user data from Discourse.
Ryan_Collins1 tries the updated solution but still encounters issues. dax mentions that there are now plugins available, including Advanced Discourse Intercom and Intercom widget, which can simplify the integration process.
Ryan_Collins1 will continue to troubleshoot and potentially reach out to Intercom support for further assistance.
Hey team,
Thank you!
Go to
There you can add javascript in the head or in the footer ![]()
Thank you very much for the helpful reply!
I have placed the code below within the area (please see attached image).
So far I have not been able to load the Intercom messenger, but I will continue working on this and will post my results.
<script>
window.intercomSettings = {
app_id: "m866jl5z",
name: <%= current_user.name %>, // Full name
email: <%= current_user.email %>, // Email address
created_at: <%= current_user.created_at.to_i %> // Signup date as a Unix timestamp
</script>
<script>(function(){var w=window;var ic=w.Intercom;if(typeof ic==="function"){ic('reattach_activator');ic('update',intercomSettings);}else{var d=document;var i=function(){i.c(arguments)};i.q=[];i.c=function(args){i.q.push(args)};w.Intercom=i;function l(){var s=d.createElement('script');s.type='text/javascript';s.async=true;s.src='https://widget.intercom.io/widget/m866jl5z';var x=d.getElementsByTagName('script')[0];x.parentNode.insertBefore(s,x);}if(w.attachEvent){w.attachEvent('onload',l);}else{w.addEventListener('load',l,false);}}})()</script>
This is in part based on @jesselperry’s previous comment, but updated with the latest Intercom messenger and implemented according to Intercom’s setup guide for single page apps. The following is what I have and it seems to be working ok.
First add this to the </head> section:
<script>
s.src='https://widget.intercom.io/widget/[YOUR_APP_ID]';
</script>
And add this to the </body> section:
<script>
$.getJSON("https://[YOUR_DISCOURSE_DOMAIN]/session/current.json", function(json){
var currentusernamefromjson = String(json.current_user.username);
var currentuserflname = String(json.current_user.name);
var fulllinktojson = "https://[YOUR_DISCOURSE_DOMAIN]/users/" + currentusernamefromjson + ".json";
$.getJSON(fulllinktojson, function(json){
var currentuseremail = String(json.user.email);
var currentuserid = String(json.user.id);
window.Intercom('boot', {
app_id: '[YOUR_APP_ID]',
email: currentuseremail,
"discourse_username": currentusernamefromjson,
"discourse_uid": currentuserid
</script>
Make sure to replace [YOUR_APP_ID] with your Intercom app ID, and [YOUR_DISCOURSE_DOMAIN] with your domain (and change https to http if that’s what you use).
Thanks so much for posting this.
I tried inserting the code with my app ID and discourse forum URL, but I still can’t get it working.
Below is what I have added to my head section:
<script>
</script>
<script>
app_id: 'm866jl5z',
custom_launcher_selector: '#my_custom_link'
</script>
<script>
app_id: 'm866jl5z',
email: 'example@example.com',
user_id: 'abc123',
created_at: 1234567890,
</script>
<script>
$(window).scroll(function() {
if ($(this).scrollTop() > 120)
$('.crunchify-container').fadeIn();
else
</script>
<script>
</script>
And here is what I have added to my body section:
<script>
$.getJSON("https://community.myfishingcapecod.com/session/current.json", function(json){
var fulllinktojson = "https://community.myfishingcapecod.com/users/" + currentusernamefromjson + ".json";
app_id: 'm866jl5z',
</script>
I reached out to the Intercom support team as well, so I will post back any solutions if I find any.
Obviously I appreciate any insight anyone here on this forum may also be able to provide to help me get Intercom working with Discourse. Thank you all for the helpful posts thus far ![]()
Now there are an Advanced Discourse Intercom plugin and also an Intercom widget to integrate Intercom with Discourse.
