Ability to change the category of a post before approving
The discussion revolves around a feature request to allow moderators to change the category of a post directly during the approval process on the /queued-posts page. ggurbet initially proposed the idea, suggesting a simple category changer next to the approval buttons. sam suggested integrating it into the ‘edit’ function, which would also record the change. ggurbet acknowledged the suggestion but noted the front-end option could be useful for active forums. xrav3nz took up the task, sharing mockups of the implementation, including editing the category, title, and tags, with plans to record edits in the revision history. xrav3nz provided additional screenshots demonstrating the before and after states of editing, as well as the revision history, and welcomed feedback on the design.
Hello. We are using a forum where most of the posts are subject to moderator approval. When approving a post sometimes we need to change the category. Currently we approve the post first and then manually change its category by going to the topic. Can it be so that the category change is done in the approval page (/queued-posts)?
「いいね!」 4
Not yet but sounds like a nice feature request, can you do a visual mockup of how you think this should work? Perhaps someone in the community may want to contribute the change
「いいね!」 1
Hey Sam, how about this mockup?
「いいね!」 2
Simply adding the category changer to the right of the buttons would be sufficient I guess. Also maybe when the category is changed the Incorrect Category next to the topic gets strikethrough and the new one appears next to it. Clicking a x button reverts the category change. Like this:
I would recommend hiding it behind the “edit” function, once you click edit you can edit the body of the post, title, tags and the category. pr-welcome for that. Ideally it would also record that the edit happened.
「いいね!」 6
Yes, that seems more plausible. But having it on the front can also be good since this is somewhat a tedious task for active forums and can also stay outside the edit button. Thanks!
Started hacking on this earlier this week and have finished majority of the extended features.
I will hopefully have the PR up some time early next week; still need to look into ways to record the edit.
Screenshots from the current implementation. (Everything is from the existing editing components; will probably add some minor CSS tweaks to improving space between components, etc. )
Open to suggestions!
Pending Reply
Pending Reply - Edit View
Pending Topic with Tags
Pending Topic with Tags - Edit View
「いいね!」 10
Here are some screenshots for the feature to record the edit:
feedback welcomed and appreciated, especially if you feel overwhelmed by the number of input fields (I have and will continue to tweak the spacing.)
Before editing
After editing
The revision history - nothing’s changed here, just to demonstrate the effect
「いいね!」 10
A post was split to a new topic: Change category before approving topic
