Since I needed to manually rebuild the Discourse image anyway for the current upgrade, I took the opportunity to do the:
wget -qO- https://get.docker.com/ | sh
for docker upgrades as well. This appeared to go OK, but there was a note near the end of the script about doing an “activate” command to enable the Enterprise version with signature checking. I did not do this – I did not run an activate command at the end of the process. Right? Wrong?
Also, as ordered in the upgrade process for this upgrade, I just did:
cd /var/discourse
git pull
./launcher rebuild app
This began with:
Unable to find image ‘discourse/base:2.0.20190217’ locally
then a bunch of downloads and pulls, and ended with
Status: Downloaded newer image for discourse/base:2.0.20190217
However, I’ve seen no actual build and I’m still on my old Discourse image, which is still saying that update is required. I must have missed a step somewhere. Any suggestions? Thanks!
