Activation Not send
The user jannikjbi is experiencing issues with email activation after reinstalling their Discourse server, specifically failing to send emails to the admin account. The logs show a successful registration process but no email delivery. Another user, 2 pfaffman, suggests checking the troubleshooting guide for email on a new Discourse install, implying the configuration might be incorrect. jannikjbi shares screenshots of their email server settings, showing smtp.strato.de on port 465, which NateDhaliwal confirms as a possible solution. Another user, newbie-on-discourse1, reports a similar issue with Strato’s mail service, encountering a Net::ReadTimeout error when testing email delivery, and asks about the correct mail server setup. jannikjbi provides further clarification with a screenshot, highlighting the importance of using the correct port numbers for email configuration.
Hi, I recently reinstalled my server with the forum on it and now I’m having problems sending emails to the admin account again, and I looked in the log and there’s nothing there except
Processing by FinishInstallationController#register as HTML
Parameters: {"authenticity_token"=>"don't give value", "email"=>"Jannik@Nordverkehr.eu", "username"=>"Jannikjbi", "password"=>"[FILTERED]", "commit"=>"Register"}
start
Redirected to https://forum.nordverkehr.eu/finish-installation/confirm-email
Completed 302 Found in 19ms (ActiveRecord: 0.0ms (0 queries, 0 cached) | GC: 0.1ms)
Started GET "/finish-installation/confirm-email" for 77.3.233.40 at 2025-01-31 19:14:22 +0000
Processing by FinishInstallationController#confirm_email as HTML
Rendered layout layouts/finish_installation.html.erb (Duration: 8.6ms | GC: 0.3ms)
Completed 200 OK in 11ms (Views: 9.3ms | ActiveRecord: 0.0ms (0 queries, 0 cached) | GC: 0.3ms)
done
I filled out everything correctly, my email hoster is strato
Probably not. See Troubleshoot email on a new Discourse install
Actually look here
Hmm, maybe set the port to 465? Not very sure.
(Taken from Using your email address with external email clients | STRATO)
Ahh, Thanks
Hi @jannikjbi
I got a similar issue. I bought a mail service from strato and would like to use it for discourse but get this error:
==================== MAIL TEST ====================
For a robust test, get an address from http://www.mail-tester.com/
Or just send a test message to yourself.
Email address for mail test? ('n' to skip) [admin.discourse@domain.net]: test-dj0qyymtu@srv1.mail-tester.com
Sending mail to test-dj0qyymtu@srv1.mail-tester.com. . .
Testing sending to test-dj0qyymtu@srv1.mail-tester.com using smtp.strato.de:465, username:discourse@domain.net with plain auth.
======================================== ERROR ========================================
                                    UNEXPECTED ERROR
Net::ReadTimeout
====================================== SOLUTION =======================================
This is not a common error. No recommended solution exists!
Please report the exact error message above to https://meta.discourse.org/
(And a solution, if you find one!)
Replacing: SMTP_PASSWORD
Replacing: LETSENCRYPT_ACCOUNT_EMAIL
Replacing: DEVELOPER_EMAILS
Replacing: DISCOURSE_DB_PASSWORD
Replacing: Sending mail to
Can I ask you which mail server you use?
I use Brevo which gives 300 emails a day on the free plan.
Without these numbers 465, I’ll give you a picture, that’s probably why
