phntxx
(bastian meissner)
24 سبتمبر 2017، 7:37ص
1
Hi,
is there any possibility of adding posts from a backup onto a working instance without replacing everything that’s already there?
fefrei
(Felix Freiberger)
24 سبتمبر 2017، 8:23ص
The best I can think of: Restore the backup to a temporary instance, then use this guide to export the topics you want and import them on your main install:
Need to move some stuff from one instance of Discourse to another?
There is a command line tool to export a topic, a set of topics, or an entire category, and another to import them in at the other end.
Topic Export/Import
one or more topics and their replies
the users who posted in the topic
Category Export/Import
the category and all its subcategories
its security settings
custom groups mentioned in the security settings
if any of the groups have ‘membership requests’ enable…
pfaffman
(Jay Pfaffman)
24 سبتمبر 2017، 12:03م
3
The caveat is that the category that the topics are restored in to needs to be a new one. You can move topics around after that.
But if you mean restoring posts into an existing topic, there’s no way that I know of.
Perhaps say more about your particular situation.
phntxx
(bastian meissner)
24 سبتمبر 2017، 3:30م
4
The post by @fefrei actually already helped me out - thanks again for that
