Based on this post and screenshot, there is a way to add a badge to solve answers. - Discourse Solved
But on the latest plugin, no option is available. How do I add or associate a badge to solve answers now?
Thanks!
Thanks!
Are you talking of this query?
SELECT p.user_id, p.id post_id, p.updated_at granted_at
FROM badge_posts p
WHERE p.post_number > 1 AND
p.id IN (
SELECT post_id FROM (
SELECT pc.post_id, row_number()
OVER (PARTITION BY p1.user_id ORDER BY pc.created_at) as rnum
FROM post_custom_fields pc
JOIN badge_posts p1 ON p1.id = pc.post_id
JOIN topics t1 ON p1.topic_id = t1.id
WHERE name = 'is_accepted_answer' AND
value IS NOT NULL AND
p1.user_id <> t1.user_id AND
:backfill OR
p1.user_id IN (
select user_id from posts where p1.id IN (:post_ids)
) X WHERE rnum = 1)
You need to follow this topic: Enable Badge SQL
Then create a new badge in your-site.com/admin/badges
Thanks @dax.
If I’m correct, once I enabled the creation a new bad, I can just add this code and no need to check something on the plugin to enable it?
OLD example of the plugin-solved:
Allow badges to be awarded in this category does not refer to the solved plugin in particular, but to all the Discourse badges in general. You do not have to check anything, just that the plugin is enabled globally or on the individual categories as @awesomerobot explained to you here https://meta.discourse.org/t/added-latest-version-of-plugin-solved-checkbox-for-op-is-not-showing/79128/3?u=dax
Credo che questo sia stato risolto dall’ultimo post di Dax.
