Add fixed-duration shortcuts for Silence and Suspend
סיכום מבוסס בינה מלאכותית
scavin proposes adding fixed-duration shortcuts (1, 3, 7, 14, and 30 days) to the Silence and Suspend moderation dialogs. Currently, these dialogs only offer date-based options like “Next Monday,” which result in inconsistent penalty lengths depending on the day of action. The suggested durations would calculate from the moment the action is applied, while retaining existing date-based options. The goal is to streamline moderation, reduce manual date calculations, and help communities enforce standardized policies more consistently.
Currently, both the Silence and Suspend dialogs offer date-based shortcuts such as “Next Monday”.
However, when moderating a community, we often need to apply penalties for a fixed duration, such as 1 day, 3 days, 7 days, or 30 days.
For example, selecting “Next Monday” results in different penalty durations depending on which day the moderator takes action.
This makes it less convenient to enforce consistent moderation policies.
Suggestion
Add fixed-duration shortcuts to both the Silence and Suspend dialogs:
  • 1 day
  • 3 days
  • 7 days
  • 14 days
  • 30 days
Each duration should be calculated from the moment the moderation action is applied.
The existing date-based shortcuts and custom date picker should remain available.
Ideally, both dialogs would use the same duration picker for a consistent moderation experience.
This would make moderation faster, reduce manual date calculations, and help communities enforce standardized penalty durations.
Would the team consider supporting this?
לייק 1
