Yeah, it looks like ipinfo.io doesn’t support ipv6-Addresses at all 2001:4860:4860::8888 IP Address Details - IPinfo.io gives me Please provide a valid IP address.
@coderholic, any idea of any provider that does?
I’ve just added IPv6 support http://ipinfo.io, so hopefully this should now just work. Here’s what’s coming back for the example IP you posted:
$ curl http://ipinfo.io/2001:4860:4860::8888
"ip": "2001:4860:4860::8888",
"hostname": "No Hostname",
"city": null,
"region": null,
"country": "US",
"loc": "38.0000,-97.0000",
"org": "AS15169 Google Inc."
One thing I should probably draw your attention to is the fact that the free ipinfo.io plan is limited to 1,000 lookups per day, and beyond that it’ll return a 429 error. If you’re expecting to do more than 1,000 IP lookups a day then get in touch via http://ipinfo.io/contact and I’m sure we can work something out.
Awesome! As this is an admin-only on demand, manual click action I highly doubt any Discourse install would come anywhere remotely close to 1k lookups per day.
FIY: I fixed the issue when you were using HTTPS
This also makes IPV6 lookups work thanks @coderholic!
