Add "Move to new message" option when selecting posts on topic admin wrench
The discussion revolves around adding a “Move to new message” option in the admin wrench when selecting posts, to simplify moving selected posts into a new private message. Currently, users must use undocumented workarounds involving creating a new message first and manually entering the topic ID. Several users reference previous requests for similar functionality, including bulk and single-post moves to private messages. The feature has now been implemented, as noted in a recent meta post techAPJ.
Currently, when you select one or more posts via the admin wrench, you get the modal below. This works well for the offered options, but if you want to move the posts into a new personal message you have to jump through some extra hoops, some involving undocumented features:
  • using + new message on the :link: modal, create new message first, which automatically includes the users and groups required
  • identify the message topic ID from URL (copy to clipboard)
  • using admin wrench, select posts to move, then select move to existing topic, then type in the topic ID (or paste from clipboard)
I think it would be very handy to instead see a “Move to new message” option here, which would start a new message including the same users and groups containing the selected posts. It would work similarly to the
Fair; didn’t someone else ask for this recently here on meta?
Close, but instead of bulk selection, for a single post
See also
https://meta.discourse.org/t/move-single-entry-in-public-topic-to-new-private-message/54203?u=tophee
https://meta.discourse.org/t/moving-selected-posts-to-private-message/49007?u=tophee
This feature is now implemented. Details here:
