Add rel="nofollow" admin setting is not working right, its making parent domain link as nofollow
סיכום מבוסס בינה מלאכותית
The discussion revolves around a bug in Discourse’s admin setting “add rel nofollow to user content,” which incorrectly applies rel="nofollow" to links pointing to the parent domain (e.g., www.discourse.org from try.discourse.org). Users report the issue and debate the correct behavior: whether subdomains of the parent domain should be followed by default. codinghorror and sam highlight inconsistencies, while eviltrout identifies the flawed code logic (uri.host.ends_with?(site_uri.host)). techAPJ submits a fix via GitHub PR #3501, addressing edge cases like example.co.uk and myblog.blogspot.com. michaeld points out lingering issues with public suffixes, prompting techAPJ to adopt the publicsuffix-ruby library. Concerns arise over dependency bloat (sam), leading to proposals for a new site setting like follow_links_domains (techAPJ, sam) to explicitly define allowed domains. codinghorror advocates simplicity: use known domain suffixes (e.g., discourse.org, example.co.uk) and default to strict nofollow if unspecified. lovechopra1 confirms the fix works for new content but requires rebaking old posts via rake posts:rebake (codinghorror). A newbie (Aaron_Seminoff) asks about duplicate content handling, with riking suggesting Discourse’s embedding feature as a solution. The core resolution involves refining domain matching logic and adding explicit configuration for followable domains.
There is a setting in Admin panel:
add rel nofollow to user content: Add rel nofollow to all submitted user content, except for internal links (including parent domains). If you change this, you must rebake all posts with: “rake posts:rebake”
This setting is by default checked but all the links of parent domain is putting up with nofollow attribute.
Please use following steps to replicate:
1 Go to admin panel and search for setting “add rel nofollow to user content”, just to make sure it is checked
2 Create a new post and put link of root domain
3 Inserted link automatically append with rel=“nofollow” attribute despite of being a parent domain link
לייק 1
That does seem like a regression @sam
not following, how are you changing site setting on try.discourse.org?
He’s not, the idea that links to
are nofollowed from
does not seem in tune with the description of the setting:
add rel nofollow to all submitted user content, except for internal links (including parent domains)
לייק 1
I think @eviltrout wrote this but my guess is that www.discourse.org is not considered try.discourse.org … only discourse.org is.
Yes but I think it should be. Any subdomain of the parent domain should be followed.
Perhaps you can take this @techapj?
לייק 1
Looks like uri.host.ends_with?(site_uri.host) is the code that does it. It seems that try.discourse.org would not match www.discourse.org.
Are we sure we’d want it to do that? It might be weird from a security standpoint to make try match www.
2 לייקים
Speaking for Sitepoint, I could see use out of it with our article integration. Having sitepoint articles followed by default would make a lot of sense and in our case it would be community.sitepoint.com matching www.sitepoint.com
I would think other article integrated sites would see value in it too.
8 לייקים
It really should work this way.
3 לייקים
Fixed via:
https://github.com/discourse/discourse/pull/3501
Also there was bug when domain like foo.com is added in exclude_rel_nofollow_domains setting, then domain like nofoo.com was also being allowed to be excluded from nofollow. Fixed that too.
7 לייקים
It’s not that simple.
uri_domain = uri.host
uri_domain = "#{uri.host.split('.')[1]}.#{uri.host.split('.')[2]}" if uri.host && uri.host.split('.').size == 3
uri_domain = "#{uri.host.split('.')[1]}.#{uri.host.split('.')[2]}.#{uri.host.split('.')[3]}" if uri.host && uri.host.split('.').size == 4
This code fails when people use naked ccSLD’s like example.co.uk (will follow everything in co.uk).
Also myblog.blogspot.com will follow everything at blogspot.com…
You should use View the Public Suffix List to resolve this…
לייק 1
This is about “making links follow” (technically, not making them nofollow), not about making them nofollow.
Or is that what you mean?
לייק 1
Yes, edited. Thanks.
Thanks for pointing this out. Will fix.
This is the desired behaviour. If the instance is hosted at myblog.blogspot.com then everything at blogspot.com should be followed.
Yes I agree, initially I used publicsuffix-ruby gem to achieve this, but all tests broke.. :disappointed: Will try to fix tests.
Updated the PR to use publicsuffix-ruby gem. Tests are passing.
לייק 1
I am worried about this kind of stuff, how heavy is this dependency ?
This is a 150k file https://github.com/weppos/publicsuffix-ruby/blob/master/data/definitions.txt I bet this bloats us with 10k extra strings at least
לייק 1
I do not think a whole library should be necessary for this change @techAPJ
Why can’t the test be “ends with correct domain suffix” and then “anything else on front with a period between”?
It’s because the requirements are like this:
  • Discourse at forum.example.com:
  • example.com/ - followed
  • www.example.com/ - followed
  • blog.example.com/ - followed
  • www.2example.com/ - nofollow
  • Discourse at forum.co.uk:
  • co.uk/ - nofollow
  • example.co.uk/ - nofollow
  • Discourse at awesome.website:
  • website./ - nofollow
  • example.website/ - nofollow
You can’t tell those apart with the number of dots.
לייק 1
Number of dots should not be used.
Known domain name suffix of site should be used, e.g.
example.com
example.co.uk
example.website
With the rule being “any domain name with a dot plus this suffix is followed”
If necessary add another site setting to hold this value. If the value is not present, the nofollow will simply not be as accurate, e.g. it will nofollow stuff that it technically should not. It errs on the side of caution.
That’s much preferable to a giant library dependency…
2 לייקים
Worst case, default to the discourse domain, that way, once added, it only no-follows internal links; ie: community.sitepoint.com, and we’d have to make it more generic by changing it to sitepoint.com
However, it needs to be able to not match
example.com/sitepoint.com/mypage.php or similar related URL renderings.
